Yeah, why don't you just use the bolt on prop adapter and attach the prop to the front of the motor with the shaft pointing out the back?
Latest blog entry: 3D Hobby Shop 58" Edge
Like this. |
United States, NC, Spring Lake
Joined May 2005
Why not use the Prop Adapter I am running an NTM 28 series just fine mounted on bottom. |
Originally we used the Razor 400 motors (can design not outrunner) and mounted them behind the mount or on a mount built into the back of the wing. We installed the spar farther forward and cut out the space for the motor on the back of the wing. Mounting a motor this way causes problems with inserting the shock cord and actually the motor cut out weakened the back of the wing even more.
The bottom of the wing is designed to be 90 degrees to the thrust line of the motor but this will change if the point of thrust if the motor is significantly higher or lower. For example: a motor over the wing will tend to push the nose down and under the back of the wing will tend to push the nose up. Is this a problem??? You will have to adjust the motor angle to get the thrust line right. Look at the motor angle on our Albatross. This is all to compensate for thrust angle. |
Hi friends,
Remember that I lost an Assassin a few days ago? So, I discovered what caused my wing lost: brownout of the ESC ![]() As I was using the garbage Hobbyking 25 30a esc, it could not feed properly the servos and Optima 6 Receiver ![]() As I have a new Assassin and dont want to loose also it, so I bought the following a GWS ESC: http://www.hobbyking.com/hobbyking/s...4S_3A_BEC.html Is it good or I need something better? My setup is: CF2812 with 7x6 2 x mg90 servos 3s 1000 mah lipo Optima 6 Hitec Aurora 9 Thank you, Luis ´Here what a friend post to me: You would need only one ESC with a switching-BEC. The main power outlet of that ESC should have, let's say, 40 Amp, combined with a switching-BEC of 3 Amp power outlet, maximum peak at least 5 Amp, that would be sufficient. But, you shoul by an ESC of good quality, I personally have made good experiences with the "sentry"-series of Hobbyking. Solder the extra-cable, which came with the receiver to the ESC-side of the connection socket between the Battery and the ESC and put the socket of that cable into the SPC-socket of the receiver, put the other, normal socket of the ESC into the normal "motor"-port of the receiver ....... that's all. Now you power your receiver (but only the receiver, not the servos!) directly with the voltage of your battery, the effect is, that a brownout from that battery can't happen, because the whole power of your battery powers your receiver directly, the other effect is, that the receiver knows this way the voltage of your main battery and this inforamtion will be send to your radio, where you will have this interesting information. Set a warning level for this voltage according to the number of cells. On the other hand, your servos are still driven/operated by the BEC-part of your ESC. You will have no problems with this configuration. Udo |
Hi Lee / friends,
Take a look please where I installed my motor. It´s not in the middle, once in my lost wing it was so near the floor, and when landing the asphalt could hurt the motor, so I decided to put it a few higher in my new wing. What thrust angle do I need to put? Or leave as it is, with 90º ? This is my new Assassin, I´ll use Optima 6 on it, and I still need a good esc bec ![]() Thank you so much, Luis Quote:
The thrust angle is a trial and error thing.
Usually works best at 0 degrees but with it mounted high like that you may see issues. Get your plane trimmed in and flying level at around half throttle. Whack the throttle open and watch for abrupt attitude changes. If it noses down, bend the mount so the motor angle slightly upward. That's one thing the steel motor mount that comes in the Assassin kit is really good for. It can be bent and rebent many times before the metal is fatigued enough to cause a problem. |
| Thread Tools | |
| WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 22 | Sep 23, 2009 06:56 AM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 04:05 PM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 0 | Jan 28, 2004 12:40 AM |
| Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 01:05 PM |
| It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
