Old Oct 03, 2012, 08:45 PM
Ogrestud is offline
Find More Posts by Ogrestud
KI4KRA
United States, NC, Spring Lake
Joined May 2005
I sprayed 3M 90 to "seal" the epp then used Walmart acrylic paint before laminating it. Added nearly no weight. Kept it to light thin coats. Sprayed it with an $8 spray gun from harbor freight.
Ogrestud is offline Find More Posts by Ogrestud
Old Oct 03, 2012, 09:50 PM
blunight is offline
Find More Posts by blunight
Chess club geek with wings
blunight's Avatar
United States, FL, Cape Coral
Joined Aug 2008
Originally Posted by Left Coast DJ View Post
I know reflective tape is the recommended method of decorating these wings. Anyone try spray paint? If so, which ones stick? Krylon Fusion?
I tried Krylon Fusion on the bottom of my first wing (applied to the surface of the laminate) - I dont recomend it.
It scratches and looks like poo after just a few flights.
blunight is offline Find More Posts by blunight
Old Oct 03, 2012, 10:05 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Will the laminate adhere / be able to be ironed on to Krylon Fusion painted foam?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Oct 03, 2012, 10:32 PM
Chipped Rotor is offline
Find More Posts by Chipped Rotor
Blythewood, SC
Joined Dec 2003
Hello LC, Valspar Paint for Plastics sticks like a charm to EPP---from your local Hardware Store.
Chipped Rotor is offline Find More Posts by Chipped Rotor
Old Oct 04, 2012, 12:18 AM
KC Flyer is offline
Find More Posts by KC Flyer
KC Flyer's Avatar
Lee's Summit, MO USA
Joined Jan 2001
Sounds like a great bet: If anyone can burn out a 9 turn MD hi temp rewind, I'll send them a stock one. Go for it! I have over 700 flights on a single rewind (same bearings too) and have tried my best to abuse it.
Originally Posted by jetpackninja View Post
Awesome- if it doesn't smoke on the bench you've probably done it right.
Mine do get quite hot but I suspect that the MD hi temp rated wire is what makes this such a successful option. Get out there and feel the difference.
Hey- you guys that run the rewinds, some have said the their motors do get quite hot. Do you do a cool down between flights or do you just go for it?
KC Flyer is offline Find More Posts by KC Flyer
Old Oct 04, 2012, 05:04 AM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
hahahaha- challenge accepted!
I've burnt plenty with the radio crap wire.
So far so good with the MD 24 gauge
jetpackninja is offline Find More Posts by jetpackninja
Old Oct 04, 2012, 06:40 AM
moray is online now
Find More Posts by moray
Destroyers of Props Europe
moray's Avatar
Switzerland, ZH, Oberengstringen
Joined Jun 2012
Going to order some MD 24ga wire. Don't worry I don't join the challenge.
moray is online now Find More Posts by moray
Old Oct 04, 2012, 10:29 AM
blunight is offline
blunight's Avatar
Joined Aug 2008
The laminate should stick better to painted foam as compared to bare foam, I know this is the case when laminating epoxy/fiberglass to foam.
If your painting the foam, spray it with 3M77 (or 3M90 as Ogrestud suggested) before painting - the glue will help seal the foam and make your image brighter.
Old Oct 04, 2012, 10:54 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Never done it myself, but I know previous discussion has stated the opposite--lots of people with lam peeling off their fainted foam.
I think a few people have figured out a combination of paint brands, drying time, etc. to make it work, (you'd have to wait for one of them to chime in), but the general consensus is it's a lot of work to go through, when you could just laminate and use stick-on color sheets or tape afterwards, and avoid potential problems. So unless you're really set on a painted color scheme...
elCapitan is offline Find More Posts by elCapitan
Old Oct 04, 2012, 10:56 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
A lot of people have done pretty well drawing designs on the stick-on color sheets, then cutting them out and putting them on. A few have even designed things on their computer and printed it on special paper, then just peel off and stick. Even that sounds easier to me than the paint.
Old Oct 04, 2012, 01:31 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
even a graphic printed on white paper and stuck to the foam with a spray adhesive works pretty well. Looks nice with the laminate over top.
Old Oct 04, 2012, 03:07 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
thats how this one was done...
Old Oct 04, 2012, 03:38 PM
blunight is offline
blunight's Avatar
Joined Aug 2008
Here's another...done with Avery Label stock
Old Oct 04, 2012, 04:08 PM
Bluhammer is online now
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Here's the motor I'm going to try next on my Assassin
Powerup 370 Zoom
Blu
http://www.headsuprc.com/servlet/the...70-Zoom/Detail
Bluhammer is online now Find More Posts by Bluhammer
Old Oct 04, 2012, 05:47 PM
StreetCred is offline
Find More Posts by StreetCred
StreetCred's Avatar
USA, WI, Cedarburg
Joined Sep 2010
Bumper Stickers
I applied the bumper stickers prior to laminating. Worked like a charm!
StreetCred is offline Find More Posts by StreetCred
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 06:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 05:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 01:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 02:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 02:55 AM
