Old Aug 27, 2012, 06:28 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Originally Posted by Bluhammer View Post
I have 2 issues.
1. VERY poor vertical. This I hope to fix tonight by resetting the throttle range on ESC/TX. If not I'm concerned. I have two stock motors and they both do vertical poorly. It seems to totally stall after40-50ft of vertical at full throttle.
2. Should I TX program some differential in? How much? My Assassin wobbles and yaws too much in turns, really pronounced in winds.
Thanks for any suggestions.
Blu
Vertical is totally thrust vs weight. I have some planes that will do unlimited vertical and others that won't. It has very little to do with the design of the wing. Even the condition of the prop and size of battery will make a difference in the climb rate.
Yaw is affected by how sharp the corners are in the angles you cut in the front of the tips. If the corners are rounded the effect they create is reduced.
Adding fins will stop the yaw but I have all of my Assassins flying well without fins. Other things that affect yaw are too much throw in the elevons, CG too far back, plane too heavy, to slow of flying speed.
Lee is offline Find More Posts by Lee
Old Aug 28, 2012, 05:48 PM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
I have 2 issues.
Blu
With the suggested CF2812 and a 7x6, you should have unlimited vertical. They aren't extremely fast going vertical, but it is still unlimited.
As Lee said, the yaw can be partially attributed to the finless design. Assassins really like to fly at speed, when you slow them down they do have a tendency to waggle a bit, but it is very predictable and easily corrected with your left stick.
nofreee is offline Find More Posts by nofreee
Old Aug 28, 2012, 06:12 PM
jwjohnson is offline
Find More Posts by jwjohnson
Hit Me! Please!
jwjohnson's Avatar
Provo, UT
Joined Jan 2005
Whose left stick? Did you put a rudder on yours? Do you fly Mode 1?
jwjohnson is offline Find More Posts by jwjohnson
Old Aug 28, 2012, 07:23 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
I was very much confused by it's terrible lack of vertical. I hope resetting the throttle travel resolves the issue. Mine is all stock using 1300mah batteries and it shouldn't be overly heavy. Hope to try it again soon.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Aug 28, 2012, 08:39 PM
CaribbeanBlue is offline
Find More Posts by CaribbeanBlue
Joined Jul 2010
Blu
Have you tried changing the timing on the ESC?~~~~~H
CaribbeanBlue is offline Find More Posts by CaribbeanBlue
Old Aug 28, 2012, 08:58 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
I am enjoying so much this Assassin! To prove that, here some pictures showing what I am doing: another one! I bought a lot of colored tapes that leave me confused about the design of the new one. How to cover it? What draw, colors? I was thinking about blue dark down and yellow on top. Ill decide it this week
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Aug 29, 2012, 12:13 AM
Promo is offline
Find More Posts by Promo
Livin' the Dream
Promo's Avatar
United States, UT, Vineyard
Joined Dec 2011
Shock Cord
I've lost my shock cord....what should I use?
Promo is offline Find More Posts by Promo
Old Aug 29, 2012, 01:47 AM
TM1 is offline
TM1
Find More Posts by TM1
TM1
Joined Jan 2012
new Assassin on the way. set-up advice needed ...
Hi guys,
ordered the Assassin and I have a set-up I'd like you guys to comment on.
it's a first wing for my son and I. we will be flying it calm and light at first and do basic acrobatics, with fins on and later we will probably advance in our control of it and start to run it all over the place ...
first, BIG Thanks to Lee !!!
I've been on the mail with him the last few days. great guy.
so, the set-up I have in mind (all HK) :
motor :
FC 28-12 Brushless Outrunner 1534kv
http://www.hobbyking.com/hobbyking/s...idProduct=5423
prop:
TGS Sport 7x6E Precision propeller
http://www.hobbyking.com/hobbyking/s...idProduct=7942
or:
APC style propeller 7x6-E
http://www.hobbyking.com/hobbyking/s...idProduct=5436
battery (I want a light wing as possible) :
Turnigy nano-tech 1000mAh 3S 45~90C Lipo Pack
http://www.hobbyking.com/hobbyking/s...dProduct=18205
I have some 1600mAh of the same model.
what is the battery weight that puts CG spot on ?
ESC:
TURNIGY Plush 30amp Speed Controller
http://www.hobbyking.com/hobbyking/s...idProduct=2164
servos:
Turnigy TGY-9025MG Metal Gear Servo 1.8kg/11g/0.09
http://www.hobbyking.com/hobbyking/s...dProduct=17321
please let me know what you think.
thaks,
TM1 is offline Find More Posts by TM1
Old Aug 29, 2012, 04:16 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7 N 8.9 W
Joined Jul 2007
Originally Posted by TM1 View Post
Hi guys,
motor :
prop:
or:
ESC:
servos:
thaks,
I find the TGS props a bit heavy for this application ...... I would go for the APC style ......
Get a programming card for the Tgy Plush esc ..... set brake on ...cut off voltage high ... and timeing medium or high ......
I would go with the 1300 lipos (as high a C rating as you can afford) ......
I fit a prop saver adapter when using the 28-12 motors .....
hobie14 is offline Find More Posts by hobie14
Old Aug 29, 2012, 05:32 PM
nofreee is offline
nofreee's Avatar
Joined Jan 2012
Hi guys,
thaks,
1600's are perfectly fine. You will be able to get nearly 6-7 minutes of wide open throttle and close to 10 with mixed flying on the CF2812. There are guys that fly 2200's in my combat group with no issues, they can stay up for 10-12 minutes at a time with heavy throttle.
Balance is not an issue, the Assassin has plenty of room to adjust your components around and find your CG.
Old Aug 29, 2012, 09:16 PM
Joined Apr 2005
This is an amazing flying wing! But you have to fly it fast. It just need it
Assassin combat flying wing (1 min 21 sec)
See in the video in when it reaches 1 minute, when I go vertically to the sky, also 1:44m
And Im enjoying it so much
Old Aug 29, 2012, 10:27 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
You mean pre-build? You just can't find the shock cord to put into it?
Just get a length of nylon string from Home Depot or your junk drawer. Most people seem to have nylon string around and can never remember why they got it in the first place
elCapitan is offline Find More Posts by elCapitan
Old Aug 29, 2012, 10:30 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Remember, there's no set location for the battery. Just follow the pdf instructions on the website, and you'll see that once you get to the point of digging in your electronics, you first have to arrange and shift them on the surface to attain the proper CG.
Therefore, you could probably use any battery between 1000 and 2200 mAh, and still get the right CG, you'd just have to shift things forward or backward. Like I said, just follow the pdf instructions. Good luck!
Old Aug 30, 2012, 03:22 AM
TM1 is offline
TM1
TM1
Joined Jan 2012
Thanks guys,
I'll stay with the 1000mAh for lower AUW.
A question about glue :
I don't like low temp hot glue because it tends to loosen when temp is high. And it's very high here.
will CA do the job ? What about UHU ?
Old Aug 30, 2012, 05:58 AM
jhark37 is offline
Find More Posts by jhark37
Flyr John in Floyd VA
United States, VA, Floyd
Joined Nov 2007
Thanks guys,
Try Welders; works great.
John
jhark37 is offline Find More Posts by jhark37
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 06:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 05:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 01:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 02:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 02:55 AM
