Old Jul 30, 2012, 10:04 PM
Montrose CO
Joined Apr 2012
Originally Posted by Lee View Post
You don't replace it you add another flat carbon spar by cutting a clean slit through the laminate and foam and sliding another flat carbon in and gluing it in place and laminating over the top. Don't over do it. Let the old spar stay in the wing.
I love simple solutions. Thanks Lee
not2fast is offline Find More Posts by not2fast
Old Jul 31, 2012, 12:40 AM
Fly for fun
LoneWolfRC's Avatar
Joined Nov 2011
Regarding ESC, I use a 30 amp. I cut the insulation/heatshrink to expose the heatsink. I pull 17 amps WOT. I often fly WOT the whole flight. The ESC comes down cool and motor come down cool. Actually, flying half throttle is harder on the ESC, and I often fly the whole flight half throttle or less (I like to harrier the flying wing), and it still comes down cool, even on 100 degree days. I have a 1640 kv motor, but I haven't tried it yet. I use a 1420 kv if I remember correctly, swinging a 7x6.
Another possibility is that the bearings went out in your motor, you had a short between bullet connectors to your motor, a servo stripped or was for some reason drawing too much current.
LoneWolfRC is offline Find More Posts by LoneWolfRC
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
Old Jul 31, 2012, 06:34 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Last time I did this I just used clear 2" tape over the top so the repair took only a few minutes and it is stronger than the original.
Lee is offline Find More Posts by Lee
Old Jul 31, 2012, 10:50 AM
Joined Jul 2012
Thanks, for the info. I have a new ESC ordered and will expose the heatsink to see if that helps. One wire running to the motor is in question after a closer inspection, so hopefully with the new ESC and exposing the heatsink the problem will be solved.
Tarzan3307 is offline Find More Posts by Tarzan3307
Old Jul 31, 2012, 03:24 PM
Blythewood, SC
Joined Dec 2003
You are correct Lee, I tried slightly lower rates on the elevator and the wobble was almost completely eliminated. I did the same with aileron and I just don't think there was much if any difference.
Chipped Rotor is offline Find More Posts by Chipped Rotor
Old Jul 31, 2012, 05:25 PM
United States, CA, San Diego
Joined Jan 2012
Well, after some motor issues I finally got my 4s - Microdan 2505 -2500kv Widowmaker in the air. (Great customer service from the Microdan guy(s) fixing my mistake btw).
First trimming flight was fine, brought it down to swap in a fresh battery and on the second run it ended up folding the wing in half under full power. It started to pull to the right and as I went to correct, the load just completely buckled the wing. I had extra carbon spars down the entire length of the wings but it failed about 3 inches from the center line of the plane.
Had this setup in my Assassin and it held up just fine at 115mph, I was hoping the Widowmakers slimmer profile would make it a little faster, but I guess is just a bit too thin.
All part of the game, the plane did it's job and protected the components. Everything will be used in another project. Might just build another Assassin, keep one for combat and the new one for speed.
nofreee is offline Find More Posts by nofreee
Old Aug 01, 2012, 12:21 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
It is a type of stall and with the big elevons you don't need much movement in the elevator.
Old Aug 01, 2012, 11:04 AM
Lee's Summit, MO USA
Joined Jan 2001
That's Awesome! Would love to see some video!
KC Flyer is offline Find More Posts by KC Flyer
Old Aug 01, 2012, 11:57 AM
Joined Jan 2012
Wasn't recording that flight, but as soon as I get another wing built with that power setup I'll be sure to get something going.
I learn something with each iteration, so the next Assassin should be faster and better.
Old Aug 01, 2012, 12:17 PM
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Assassin wing 1st build
Here's my 1st wing build, getting close to finishing. I like polka-dots on the bottom of my planes
Blu
Bluhammer is offline Find More Posts by Bluhammer
Latest blog entry: 2013 Blog extra
Old Aug 01, 2012, 01:09 PM
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Looks great. Do you have a group down there to knock foam with?
elCapitan is offline Find More Posts by elCapitan
Old Aug 01, 2012, 02:36 PM
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Ohhhh yeah! Two of my friends are joining in. One has already got his order and the other will be ordering soon or he'll never hear the end of it!
Blu
Old Aug 01, 2012, 09:22 PM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
You can build the thin wings strong enough for big horsepower. I think you should double the spars and put E-tape and double laminate to the tips with minimal foam cut out in the middle.
Old Aug 03, 2012, 09:29 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have received several E-mails asking which motors will give 100+ mph.
Open question to everyone....... Which motors have you tried to get the high prop speed and high MPH?
Old Aug 03, 2012, 10:58 AM
United States, NC, Raleigh
Joined Jun 2011
Is that tape, stickers, or paint that you used? Have a friend building one this weekend and want to recommend the best way to put color/patterns on it. I painted mine but it always chips if I crash or have a rough landing.
Blu
Ceradinimp is offline Find More Posts by Ceradinimp
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 22 Sep 23, 2009 06:56 AM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 12:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
