Old May 21, 2012, 08:48 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
A windmilling prop is like a disc, not very aerodynamic.
but the prop has the same surface area, whether it's spinning or not. It looks like a disc to the naked eye, but allowing it to spin doesn't actually increase the surface area to that of a disc. At any given point in time, only so much air is moving past each blade. Allowing it to windmill should let the air to move past it easier, because the blade gives less resistance, rather than the air running into a fixed blade that deflects it almost directly sideways, like a sail.
I almost never try to catch my wings anyway, but yes, you're right, putting your hand near a spinning prop is quite dangerous. No stitches, but I've been sliced pretty good. I get around the safety issue by just programming a throttle cutoff switch.
Edit
Unless you were able to put the brake on the prop exactly when the prop was sideways, with each blade behind the trailing edge of the wing... Then you might get a better glide, I guess
elCapitan is offline Find More Posts by elCapitan
Old May 21, 2012, 08:52 AM
Ferndale Flyer is offline
Find More Posts by Ferndale Flyer
Flight Enthusiast
Ferndale WA
Joined Dec 2006
Electrical connections for LED's
Could some of you post pictures of how you hook up the power to your LED strips?
I got some info from Bombay on it today, but I would like to see how and where that you do it.
Thanks!
David
Ferndale Flyer is offline Find More Posts by Ferndale Flyer
Old May 21, 2012, 08:56 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Plane Insane has some leads you solder on to the end of the LED strip that plugs right into the balance plug of your lipo. Super handy, only have to solder one side! Works great.
There's a picture on his page here.
Old May 21, 2012, 09:34 AM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
led's
AND of course " out of stock "
.........te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old May 21, 2012, 09:43 AM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
Tom,
The controller on the top of the page is sold out but the balance connector towards the bottom isn't. Only $2.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old May 21, 2012, 09:59 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
This is how I do most of mine (on the Assassin). I just crimp the ESC leads and a JST connector into my PowerPoles (battery connectors). You would solder the same kind of connector onto the LED strips.
For a little more complex wiring and in-flight electronic switch control, I wire in one of the HK electronic switches. I made a diagram in case it helps anyone.
The balance tap lead is also a good way. I plan to get some of those from HK in the future.
Bombay is offline Find More Posts by Bombay
Old May 21, 2012, 10:31 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Thanks!
David
I like to intentionally make the plane look confusing so spectators can't easily tell what they are looking at.
I use the balance plug. Here is a link to our web site explanation.
http://crashtesthobby.com/articles/night-flying
Here are a few pictures to go with the text. The first two pictures are of the eclipse this weekend.
Lee is offline Find More Posts by Lee
Old May 21, 2012, 10:53 AM
rcairnut is offline
Find More Posts by rcairnut
"Still Crashing since 1960"
rcairnut's Avatar
Pierre, SD, USA
Joined Dec 2001
where do we get these balance plugs?
anyone have a link?
nut
rcairnut is offline Find More Posts by rcairnut
Old May 21, 2012, 11:02 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
As usual they are out of stock but they come in occasionally. It doesn't matter which plug is on the other end so that gives more options.
http://www.hobbyking.com/hobbyking/s...r=&LiPoConfig=
Old May 21, 2012, 11:05 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Or Plane Insane, like I linked above
Old May 21, 2012, 12:06 PM
mdmowrey is offline
Find More Posts by mdmowrey
mdmowrey's Avatar
United States, OH, Urbana
Joined May 2010
anyone have a link?
nut
EPBuddy has some but the female end may have been beefed up which might add a small amount of weight.
http://epbuddy.com/index.php?main_pa...roducts_id=124
mdmowrey is offline Find More Posts by mdmowrey
Old May 21, 2012, 02:35 PM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
The comment above is totally incorrect.
ScotY is offline Find More Posts by ScotY
Old May 21, 2012, 02:55 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Hey, I'm not saying I'm the highest authority on this, but it seems logical and the physics are sound. If I missed something, let me know, but simply saying it's incorrect doesn't help any of us.
Where did I mess up? You can't be saying a spinning prop actually has more surface area to resist the wind, so...?
I'm totally open to correction, if you can show me where my explanation fell short! If I am wrong, I like to learn, so I'd be curious why, truly.
...and when it comes down to it, your own experience trumps any explanation on a forum. If you feel like your plane glides better with a brake, by all means, put on the brake!
Old May 21, 2012, 02:57 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Brake vs. windmill
If you are ever bored and really want to kill some time do some internet searching on this topic. Some very smart and very experienced people still continue to disagree on this subject.
I suspect the only way to truly get the answer is with computerized wind tunnel testing (I don't have one) and probably the results would vary with the pitch of the prop and the style of the plane.
But seat of the pants tells me I glide further with the brake set.
I also find that very often (sure, not every time) the prop lines up with the TE of the wing when it stops.
Mark me up in the "set the brake" camp.
Lee advises people not to use the brake.
I set the brake.
jetpackninja is offline Find More Posts by jetpackninja
Old May 21, 2012, 03:00 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
anyone have a link?
nut
LED Balance Port Connector
http://www.planeinsanerc.com/index.php?PageID=128
about halfway down the page
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 3 Sep 04, 2016 05:47 PM
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 32 Aug 31, 2016 08:21 AM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
