Old Apr 14, 2012, 03:55 PM
Chico John is offline
Find More Posts by Chico John
Joined Jun 2009
Set screws
Originally Posted by Ferndale Flyer View Post
I have read about not tightening the motor mount screws in to tightly. Are these the screws they are talking about? My pen is pointing to a motor mount screw.
Also, are only two bolts required to attach the motor mount base to the stainless motor mount angle that came with the Assassin kit?
If you have a dremel tool grind a couple flats where the set screws will meeet the motor housing. The motor isn't going to fall out but it will spin on the mont and if you get the screws too tight the bearing distorts and burns the rollers, it's a balance of tight but not too tight.
I just rewired mine and doubled the power, at least it feels that way, but I'll have to cut some flats to prevent it from spinning on the mount.
For sure get lock-tite for the set screws, the prop saver on the shaft too.
Good luck.
Chico John is offline Find More Posts by Chico John
Old Apr 14, 2012, 05:30 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
wow, I completely mis read the question sorry.
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Apr 14, 2012, 05:47 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
This is a Titan video but Mike explains how he painted under the laminate at the first
Titan by Crashtesthobby flying finless (4 min 19 sec)
Lee is offline Find More Posts by Lee
Old Apr 14, 2012, 10:07 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I caught Ninja Tom flying today. Here is a video.
Ninja Tom's Assassin by Crashtesthobby (3 min 56 sec)
Old Apr 14, 2012, 11:00 PM
Ferndale Flyer is offline
Find More Posts by Ferndale Flyer
Flight Enthusiast
Ferndale WA
Joined Dec 2006
Thanks guys. It's so great to be able to ask questions.
Ferndale Flyer is offline Find More Posts by Ferndale Flyer
Old Apr 16, 2012, 05:18 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I frequently get asked for tips on how to hand launch a plane. I realized that I had a few launches on the last couple of cards that I had shot so I threw a few of them together to let you see what we do.
The planes shown are an Assassin, Titan, Reaper, Deep Reaper, Hercules pusher and Storm Chaser.
Enjoy.
How to Launch a flying wing (3 min 21 sec)
Old Apr 16, 2012, 11:00 AM
Burma is offline
Find More Posts by Burma
Burma's Avatar
United States, ID, Idaho Falls
Joined Dec 2009
bushless motor
I have my Assassin on the way but I need some advise. I am looking at a rimfire 400(from great planes) for the motor with a 8x6 prop. will it have to much torque? is it the "right" motor for this plane?
Burma is offline Find More Posts by Burma
Old Apr 16, 2012, 11:35 AM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Burma-
What's the kv?
I can only guess, but I think it'll be fine.
Scroll up to the vid and see the blue Assassin, the motor in that guy is basically a 480 class 1700kv motor and 7x6
jetpackninja is offline Find More Posts by jetpackninja
Old Apr 16, 2012, 12:05 PM
ttabbal is online now
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
Ok, launching and I don't get along.
My assassin wants to roll left at launch. Cg feels ok, but I'm no expert. What's the best thing to try? I'd try meeting up at a field, but it's hard to get time on weekends right now.
I lifted the left elevon and got some improvement, but it needed a lot and didn't really level out.
It sure is tough though. A number of decent hits and no damage.
ttabbal is online now Find More Posts by ttabbal
Old Apr 16, 2012, 12:21 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
So, where is your cg?
Is the prop on backwards?
How much throw do you have on your elevons?
Are you sure your controls are set up properly (reversed channels etc?)
Old Apr 16, 2012, 12:34 PM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
launch
After some ha trial and erros - I had been trying to let it go when Horizonal
no good AS it would roll to the left PDQ and ya had to be quick on the right stick to level .
so Watched my friend, as he had some time on Wing and I found by letting it go when Wing was in a kinda in a right bank , then I had time to get on the stick and fly off level............te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Apr 16, 2012, 12:59 PM
ttabbal's Avatar
Joined Jan 2012
Just noticed I neglected to specify cg. Lol it's about 7" back from the nose tip.
Prop feels like I'm putting it on backward, but reading here that's normal. The side that has the deeper recess that fits the little plastic adapter it comes with better is facing rear, away from the motor. thrust feels good.
I'm not sure how to measure the throw. Going from the back edge on the elevons I get about 1/2 inch on left/right about an inch at the diagonals.
I compared my stick vs elevon programming to the videos and directions, everything looks good. I haven't really touched the stick yet though. I give about 1/2 throttle and attempt to launch. I'm doing it sidearm like lee, but not really throwing it, more just letting it go. I tried holding the middle under the prop, but tossing that way gets me a nosedive before I get a chance to throttle up. I could be to slow on the throttle though.
Old Apr 16, 2012, 01:00 PM
ttabbal's Avatar
Joined Jan 2012
Thanks, I'll try that. I was trying to release more level.
Old Apr 16, 2012, 01:16 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Sounds like your CG is too far back.
Recommend CG on the Assassin is 6.25 to 6.5 in
Probably the 6.25 is around where you want it to be until you get it flying well.
Throws are a little big for the Assassin especially for a newer flyer.
The plane flies well with about 3/8 in throws.
Set the throws up so that you are in the topmost hole on the elevon horn, and kind of middle-to-inner-ish on the servo arm.
When you pull straight back on the stick, both elevons should travel 3/8 in. upwards.
Old Apr 16, 2012, 02:45 PM
ttabbal's Avatar
Joined Jan 2012
I thought I had it closer to 6.5 before. I'll try adding some nose weight. Hopefully that helps. I'll lower the throws as well.
I need to get some practice and keep it in the air, so you ninjas can have something to hit in a couple weeks.
The rods are set up as you describe already.
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 06:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 05:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 01:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 02:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 02:55 AM
