Jan 08, 2012, 08:00 PM
Eugene, Oregon
Joined Feb 2011
Wheelspinner
No prob on the scale...I doubted its accuracy and did the comparison check out of curiosity.
The build is pretty much as per the instructions, the "don't do the/do this list" and the vids on Crashtesthobby.com website. Here's the parts list:
Emax CF2812
apc 7x4e (waiting for 7x6 to arrive from lhs; a website indicates the 4" pitch prop
has more thrust and less amp draw than the 6" pitch; the 4" provides
plenty of speed, power to me, but this is my first wing; will try the 7x6 after it arrives)
TowerPro MG90 servos, secured to wing with 2-sided sticky tape, holding good
AR6115E
E-flite 30amp esc, going to replace this with 18 amp esc for additional weight saving, secured using 2-sided sticky tape
Crash Test Hobby stainless motor mount, attached with 2-sided sticky tape and the Extreme tape and laminate. Seems very solid after 10 flights.
prop saver
I taped and laminated as per the instructions, but I did not tape the control surfaces. They seemed stiff enough w/2 layers of laminate.
Metal set-screw type pushrod connector on both ends of both pushrods.
1.37 mm piano wire pushrods. Going to get a Z-bender, eliminate 2 of connectors.
Velcro only holding the battery to the wing top.
Horns are stock, cut off as per instructions and hot glued, top and bottom
Stock corex fins
These first few flights were to get the crashing done and over with, test the cg and handling of the plane. I'll improve attachments and do a few things to reduce the weight a little more. Probably install a battery strap, eliminate 2 of the pushrod connectors, smaller esc, eliminate the esc/motor connectors by soldering, etc.
Flew 3 more batteries today. All self-launched. No crashes or even close calls. Stable, predictable flying.
