Joined Jun 2008
Motor Recommendation?
Hey, I'm going to be in need of motors real soon & finding the 2812's in stock seems impossible. To make matters worst I need shipping to canada, If anyone knows a place which currently has them it would be of very helpful!!
-If I cant find any, what motors would you guys recommend using? BTW: Ill have the stock 25-30amp ESC & a bunch of 7x6 props. |
Hey guys, finally got my Widowmaker all taped and laminated with elevens attached. Very excited with how it's turning out.
Any advice for the next few steps that's not in the instructions? I'm a little worried to make cuts with my soldering iron, will that have any negative impact to the iron or wing? Also don't want to cut to deep, that's something I should be mindful of right? Thanks! |
Joined Jun 2009
Tools
This methoud works very well when cutting all the necessary holes in the wing. Good luck! |
sean.....x2 what chico said. also.... there is several videos that detail what he described.... both on the crashtest hobby site and youtube. I think they are titled assassin though ...exact same technique...anything that you can rig that is heat proof and a positive depth stop and riding on a steel rule that is push_pinned in position.
use a seperate iron for melting foam cuz they dont work well for soldering electronics once contaminated....at least in my experience! |
What is the advantage to the rewound motor?? sorry if it is a dumb question ..
Joined Jun 2011
Porky Assassin
I built an assassin flying wing but somehow got it tail heavy and too heavy overall. Not sure where i went wrong, but I am looking for some suggestions on a fix. CoG is about 6.75 back and the overall weight is ~18.3 ounces. I havent tried to fly it yet in fear that it will fly poorly due to weight and CG. One thing that i didnt notice until the wing was built is that it isn't 34" as described in the RCGroups post, it is 38 inches tip to tip. Any help is appreciated.
spaten....that thing looks awesome.... mine`s 19 oz. flies like a champ.! make sure your max travel on elevons is 3/8ths or less from center to max up and center to max down.... just a very slight amount of up at neutral trimand stick setting with radio on.....
AND TOSS THAT THING UP..... ITS FINE.... read earlier posts.... the only way to trash it is fly it into a working wood chipper or incinerator!! (oh and make sure your not gonna hit anyone) and take video! have fun! P |
Joined Jun 2011
Where was your CG at out of curiosity? |
| Thread Tools | |
| WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 22 | Sep 23, 2009 06:56 AM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 04:05 PM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 0 | Jan 28, 2004 12:40 AM |
| Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 01:05 PM |
| It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
