Old Mar 06, 2011, 07:39 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
http://www.rcmodelreviews.com/forum/....php?f=44&t=19
http://www.rcmodelreviews.com/ar500problem2.shtml
Here is a link to a couple scources of info on that specific rx.... it doesnt look good.
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Mar 06, 2011, 08:03 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Originally Posted by wheelspinner20 View Post
Lee, would you agree that my motor angle in this screen shot of todays video, has too much down thrust? Just looking for a second opinion. It was not flying well today. Could have been the wind, combined with the key cam taped to the left wing tip.
I will spare the video, there is not much to see, i couldnt keep it steady enough in the wind to get any good video.
Thanks in advance.
Pat.
It is hard to tell with the angle and the picture. The motor mount should be at 90 degrees and should mount flat against the bottom of the wing.
Lee is offline Find More Posts by Lee
Old Mar 06, 2011, 08:08 PM
Done Crashing is offline
Find More Posts by Done Crashing
Almost out of epoxy
Done Crashing's Avatar
Salt Lake City
Joined Sep 2007
fishon2: You are definitely over-volting those servos.
4 AA batteries will provide 6 volts.
2 lipo cells will provide 7.4 volts (higher when it's charged up)
Most servos are rated in the 3-7 volt range. A 2S lipo is too much voltage. In fact, it's too much for most receivers, which is why you can buy these:
http://www.dimensionengineering.com/DE-SW050.htm
Done Crashing is offline Find More Posts by Done Crashing
Old Mar 06, 2011, 08:32 PM
fishon2 is offline
Find More Posts by fishon2
Joined Mar 2010
Ok, so I need to either get a BEC or a true receiver battery?
fishon2 is offline Find More Posts by fishon2
Old Mar 06, 2011, 09:10 PM
Almost out of epoxy
Salt Lake City
Joined Sep 2007
fishon2: You do have a third option: buy a high voltage receiver and servos, which you can use with your 2S lipo pack with no voltage converter. This is probably the most expensive option.
Old Mar 06, 2011, 09:14 PM
S.E.Michigan
Joined Jul 2010
actually the rx is rated from 3.5 to 9.6 volts.... and I really have never seen a rx that you dont just plug the esc into.... witha 2s or 3s or whatever plugged into the esc for power.
I am inclined to believe there is a problem with that rx. Or the esc . Were you able to successfully bind the rx to your tx? I've seen the dancing servos before when I selected PCM output on the tx instead of PPM.
Other than that I have no clue.
Sorry
Old Mar 06, 2011, 10:35 PM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
Originally Posted by Mike Freas View Post
Speaking of damage, broken props and such, how do you guys keep the small ring adapter thing for the prop from coming out? With the extra props I bought from plane insane that small peice has nothing to keep it secure and I've lost a few of them. Even with a dab of CA my son's came out in combat.
Hey Mike,
I used to use those little inner plastic rings too and I wondered why I was the only one that was loosing them. Turns out, nobody I fly with is using them! They told me you just ream out the prop a bit until it fits over the prop adapter. I tried it and it works great! No more stupid plastic pieces to loose!
Hope that helps.
Ryan
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old Mar 06, 2011, 10:50 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
or flip the prop saver over.
Old Mar 07, 2011, 08:19 AM
Almost out of epoxy
Salt Lake City
Joined Sep 2007
Is there an ESC involved? It seems like he is powering the rx directly with the battery.
Old Mar 07, 2011, 09:59 PM
KC Flyer is offline
Find More Posts by KC Flyer
KC Flyer's Avatar
Lee's Summit, MO USA
Joined Jan 2001
Originally Posted by Telemachus View Post
Yes, a 9 wind with about 24 guage wire works great for a 1700 kv motor. It really screams, and will burn through your battery (and eventually the wires) if you don't down prop.
11 wind works well on a slow stick...
I rewound my motor and learned a bunch of stuff about these motors in the process (Wikipedia, Google, etc.).
When I unwound the stock 28-12, I found that there were +/- 12 turns around each tooth (3 strand wire). So, not to reinvent the brushless wheel, I followed the instructions in the video by Steve (Post #2) and did 10 turns and used the 26 gauge green single strand Radio Shack wire.
Before I took the motor apart, I hooked up a battery and a power meter to my ESC, put a couple pieces of electrical tape across from each other (180 deg) on the bell of the motor, and used a tach with a flashlight to measure Kv without prop (rpm/v). The stock motor was 1480, the rewound motor 1780. So, it looks like I increased Kv 20% by going from 12 to 10 turns.
I haven't tested amp draw yet with a 7x6 prop but will probably look for a 7x4 prop before heading out to the field.
KC Flyer is offline Find More Posts by KC Flyer
Old Mar 07, 2011, 10:16 PM
Britnkurt is offline
Find More Posts by Britnkurt
Aerobatics?
Britnkurt's Avatar
Joined Oct 2010
Am I the only one that is having trouble accessing crashtesthobby.com?
Britnkurt is offline Find More Posts by Britnkurt
Old Mar 07, 2011, 10:28 PM
PnoT is offline
Find More Posts by PnoT
PnoT's Avatar
USA, NV, Las Vegas
Joined Jan 2011
Yup
PnoT is offline Find More Posts by PnoT
Old Mar 07, 2011, 10:29 PM
chewbaccah is offline
Find More Posts by chewbaccah
Combat: You're doing it wrong.
chewbaccah's Avatar
United States, UT, Layton
Joined Sep 2009
I was just able to get on.
chewbaccah is offline Find More Posts by chewbaccah
Old Mar 07, 2011, 11:28 PM
Aerobatics?
Britnkurt's Avatar
Joined Oct 2010
Stupid government internets.
Old Mar 08, 2011, 03:09 AM
Telemachus is offline
Find More Posts by Telemachus
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Are you sure?
I though that most of the motors I unwound (stock) had 10 winds. Its been a while since I looked at it, but I also thought this calculator showed 10 winds to be about 1500kv:
http://www.rcgroups.com/forums/showp...&postcount=768
Telemachus is offline Find More Posts by Telemachus
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 05:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 12:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
