Old Mar 05, 2011, 06:59 PM
Done Crashing is offline
Find More Posts by Done Crashing
Almost out of epoxy
Done Crashing's Avatar
Salt Lake City
Joined Sep 2007
Great news. The slop is virtually gone!
The tip about the heat shrink was very helpful. I wrapped CA'ed thread around the pushrod under the servo arm, and it doesn't budge.
I did a glide test with a 2200mah battery pack (AUW: 19oz), and it has about a 5:1 glide ratio (with large amounts of upward elevon deflection). I think this bird will actually fly, despite the best efforts of its builder.
I plan to use 1300mah batteries when my hobbypartz.com order arrives, and I suspect the AUW will be exactly 16oz.
Thanks for all the help, and thanks for the great design and helpful support Lee!
Done Crashing is offline Find More Posts by Done Crashing
Old Mar 05, 2011, 07:02 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
This plane will be at the unCivil war right? I can't wait to run into it
jetpackninja is offline Find More Posts by jetpackninja
Old Mar 05, 2011, 07:09 PM
Almost out of epoxy
Salt Lake City
Joined Sep 2007
I'll be there (I'm Dave Smith) from the north. Please hit me.
Old Mar 05, 2011, 07:13 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Will do- provided I can keep a plane in the air long enough
Old Mar 05, 2011, 09:54 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Most common combat damage?
In regard to the Assassin, what is the most common damage resulting from full-contact combat?
- broken props
- broken motors (fried, bend shafts)
- bent motor mounts
- cut electronic wires
- damaged linkages
- damaged batteries
- torn elevons
- etc, etc
Does damage usually occur from strikes or from hitting the ground?
Bombay is offline Find More Posts by Bombay
Old Mar 05, 2011, 10:24 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
My vote for the most common damage is broken props.
Old Mar 05, 2011, 10:45 PM
chewbaccah is offline
Find More Posts by chewbaccah
Combat: You're doing it wrong.
chewbaccah's Avatar
United States, UT, Layton
Joined Sep 2009
I would have to agree, they are so vulnerable to a hit, with planes or the ground.
chewbaccah is offline Find More Posts by chewbaccah
Old Mar 05, 2011, 11:24 PM
jwjohnson is offline
Find More Posts by jwjohnson
Hit Me! Please!
jwjohnson's Avatar
Provo, UT
Joined Jan 2005
If you are using a prop saver the most common problem is losing the prop.
Then broken props, bent control rods, broken horns (servo and elevon), then the rest occur, but not super often. Damaged batteries are a lot less common now that we bury the batteries the way we do. Another real common damage is prop slashes in the plane just about anywhere. They do occ damage wiring or electronics, but again not too often.
If your plane is a bit tail heavy or has large throws it's easy to stall it and go into the ground. That can certainly cause damage, but most of the damage is just an accumulation of small injuries that eventually need to be fixed.
jwjohnson is offline Find More Posts by jwjohnson
Old Mar 06, 2011, 02:45 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Speaking of damage, broken props and such, how do you guys keep the small ring adapter thing for the prop from coming out? With the extra props I bought from plane insane that small peice has nothing to keep it secure and I've lost a few of them. Even with a dab of CA my son's came out in combat.
Mike Freas is offline Find More Posts by Mike Freas
Old Mar 06, 2011, 03:23 PM
Hit Me! Please!
jwjohnson's Avatar
Provo, UT
Joined Jan 2005
file a flat area on the motor shaft for the set screw to fit in. Then use blue locktite on the set screw.
Old Mar 06, 2011, 03:35 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Mike:
If you are speaking of the plastic prop adapter sizing ring, a very small dab of epoxy should do it...if CA does not.
Old Mar 06, 2011, 05:41 PM
bamabaxter is offline
Find More Posts by bamabaxter
bamabaxter's Avatar
United States, MS, Clinton
Joined Apr 2010
Originally Posted by Lee View Post
Got any vids of this baby in action?
bamabaxter is offline Find More Posts by bamabaxter
Old Mar 06, 2011, 06:35 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
Lee, would you agree that my motor angle in this screen shot of todays video, has too much down thrust? Just looking for a second opinion. It was not flying well today. Could have been the wind, combined with the key cam taped to the left wing tip.
I will spare the video, there is not much to see, i couldnt keep it steady enough in the wind to get any good video.
Thanks in advance.
Pat.
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Mar 06, 2011, 07:14 PM
fishon2 is offline
Find More Posts by fishon2
Joined Mar 2010
Hey guys, I have an off topic question, but I really need an answer and since you helped me out before I thought i would give it a go.
I have some 5 gram servos from hobbypartz, and I have them for the basic 4 channels. I am using them in a sail plane I made and when I put a receiver battery in (that runs off of 4 AA batteries) and they work flawlessly. But when I use a 2c 800mah Lipo the servos have this HORRIBLE twitch that is unflyable with. The lipo is brand new. I am using all this with an ar500 and dx6i. I would love to know what is happening.
I do have one theory, the servos are rated to 7.2v and the battery is 7.4v, could this be the problem? Thanks so much for the help.
fishon2 is offline Find More Posts by fishon2
Old Mar 06, 2011, 07:29 PM
S.E.Michigan
Joined Jul 2010
Fishon, a fully charged 2s lipo is actually supposed to be 8.4v but I'm not familiar with that set up that you mentioned.
Kind of confusing statement. 4 standard aa batteries is only 6 volts correct??
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 05:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 12:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
