We are located in Urbana, about 2 hours directly south of Toledo via I-75 to SR 68. Google Maps Link http://www.flyurbana.com/ |
Latest blog entry: Pan/Tilt servo mods
Our club always welcomes visitors. AMA membership is required for flying since the property is city owned. We have a few events a year that include lunch, dinner, tour of the Champaign Aviation Museum... Maybe dinner in the Champaign Aviation Museum... |
DC:
1 - I painted the outside of the laminate on my first wing (Titan). Looks nice, but the paint has a tendency to get scratched, etc. I've had to touch it up several times. BTW - I only painted the top of the wing. Paint will not hold up very long unprotected on the bottom. This time (Assassin), I am leaving the wing white, but using decals underneath the laminate and holographic tape outside of the laminate for color. Hope that helps. 2 - On both the Titan and Assassin, you are correct in that there is a curve in the bottom of the wing and the formica does not sit flush. On the Titan, I used contact cement around the edge of the formica and Gorilla glue in the middle. The contact cement allows the formica to be pressed against the wing...thus removing any gap around the perimeter. In the center of the formica piece, the Gorilla glue expands, and fills the center gap. Worked well and is solid. This time, on the Assassin, I used contact cement around the perimeter of the formica and hot glue in the center. I replaced the Gorilla glue with the hot glue so that I could goop on the hot glue to fill the center gap, but didn't have to worry about the Gorilla glue foaming up and seeping out of the edges. Worked well...seems to me a little easier than the Gorilla. Steps: 1 - Line everything up and draw a guideline around the formica plate. 2 - use contact cement and place a 1/4"-1/2" band on the foam (inside your lines) and on the formica plate...and let the contact cement dry. (do not mate them yet) 3 - heat up the glue gun while the contact cement is drying 4 - when the contact cement is dry, quickly glop enough hot glue in the center of the lines on your foam and then press the formica piece down so that the contact cement grabs. The contact cement offers an instant grab on the foam around the edges of the plate. The hot glue takes a little longer to grab, but oozes a little and fills the gap under the plate. BTW - I position the formica plate, so that when viewing from the top of the wing, a 1/8"-1/4" of the plate pertrudes from the back between the triangle area created by the wing halfs. I found that it sits better this way and gives me a little more flexibility when mounting the steel motor mount. Hope that helps. Then again, you can just follow Lee's queue on the videos and knock that sucker with hot glue, press it down, and be done.
For less experienced wing flyers it would be nice to have a 2 piece tool for incidents involving hard nose-ins. One piece would grab or clamp on to the edges of the long bottom portion- and the other would grab the back vertical portion of the angle with 12" handles so that one could more easily bend the angle back to 90 deg. while isolating any force to not include glue or screws to bottom of wing. or even put force on motor which can loosen set-screw/collar shaft joint.
Ive looked at doing this several times but lately have not had use for it because flight time has improved my skills enough to avoid nose-ins (knock-on-wood) lately. |
spar position:
beginning of thread - 6.25 - 6.5 first video - 6.5 instructions on the website - 7 which one is it =P The ailerons or whatever you want to call them look like they're too long and you call tell the 2 pieces where ones one and snapped in half so the edges are rough. They are super thin and are not cut on the ends like in the video either. What gives? |
The ailerons need to be cut to length. One of the videos shows how to do it. You also need to add extreme tape and laminate to make them more rigged. Once done they will still flex but I didn't have any issue pulling high G moves. |
I'll go with the 6.5 i guess and see how it turns out as that should be made more clear and not in 3 different spots =) thanks! EDIT* Found the 2 second part in the 3rd video on cutting them but what's odd is they are 2.5 inches thick on one end of an aileron and 2.75 on the other end. I guess you can't be specific when building these as there's just too much info out there that's not spot on. |
| Thread Tools | |
| WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 22 | Sep 23, 2009 06:56 AM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 04:05 PM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 0 | Jan 28, 2004 12:40 AM |
| Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 01:05 PM |
| It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
