Old Jul 17, 2009, 05:46 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The shock absorber actually came from Patrick S. who used it several years ago on one of my Roswell designs. We forgot about if for a while then brought it back to reinforce the Peregrine tail. We were looking for a way to reinforce the motor area of the Assassin and so far we have not had any failures that we know of. It is simple, inexpensive, light and easy. Something that goes along with the ideas we are trying to post here.
Take a look at the second and third row of pictures of post #8. It shows you how to do it.
I keep updating the early posts in this thread as new ideas come along. I try to keep the first 20 posts current. Don't be surprised if we add new ideas and make old ideas better.
This plane has the shock absorber built in.
Assassin #9 (2 min 42 sec)
Lee is offline Find More Posts by Lee
Old Jul 18, 2009, 10:58 AM
Chico John is offline
Find More Posts by Chico John
Joined Jun 2009
Shock chord
Originally Posted by chewytm
Lee,
Pardon me, but I must have missed it. These late nite readings, you know, and nodding off in front of the pc. But, what is a shock cord? Could you please give a link to the description/pictures?
chewy
Chewytm, Did you get the explnation? This is post #167 or something on page #1 out of 12, yes the page numbers are oposit of normal. On the upper right of this page is the page number we are on and this space is indicated as to the thread number. Go to page number twelve, the first page, and scroll down. The page has the entire Assassin build, pictures of completed planes and subjects like the "string theory".
Good luck, Chico John
Chico John is offline Find More Posts by Chico John
Old Jul 19, 2009, 09:20 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Got it. Thanks
chewy
chewytm is offline Find More Posts by chewytm
Old Jul 19, 2009, 11:07 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Another PM topic I have seen several times on the complications of setting up the DX6i radio.
I just found this post tonight, maybe this explains my flight today with my new DX6i, I had a very fast roll rate to the left and a much slower one to the right.
I used your quik set up planfor the DX6i that you posted in the Assassin build.
hmmmmmmm I'm at work right now I need to go home and check this out!
I was using low rates would this still have made a difference?
"Did you know that when a "travel adjustment" is made on the DX6i Spektrum radio that you have to separately adjust the right and left sides. I thought that the single adjustment would adjust both and it doesn't.
Also if you are flying a plane with elevons and want to adjust the travel to 125% you need to make the same adjustment for up and down elevator and right and left aileron" from your "what I learned today thread"
This is correct. In post #9 at the first of the "Assassin Thread" I made several entries about this problem. It took several days for me to figure it out too.
Look at the bottom here: http://www.rcgroups.com/forums/showp...77&postcount=9
If you don't mind I am going to add this to the Assassin thread again to remind people.
Lee
Have to post a great video of one of the other planes we designed and kit called the (EPP) Snowball. Flown and shot by Dave it is a totally different plane but tons of fun.
Thanks Dave
Lee
Snowball thread, If you are like me and like videos we have a good group for the Snowball. http://www.rcgroups.com/forums/showthread.php?t=930241
Snowball's Chance in Heck! (4 min 29 sec)
Old Jul 23, 2009, 03:52 AM
ATONAL6173 is offline
Find More Posts by ATONAL6173
ATONAL6173's Avatar
Mount Vernon, WA
Joined Dec 2006
Here I go again...
Thanks to you too Lee. Just thought I'd let you know I decided to take a shot at the Assassin too. It's cut, glued, taped, and awaiting electronics in my shop. Wish me luck!
I'm so glad that you and others share so openly all your hard-won knowledge, as I am now able to get over my fears of cutting airfoils and the mystical geometry involved. Can't afford to support your Son at the moment, and had just enough foam left, so I dove in and started copycatting. Please excuse me as I drivel on about the minutiae of the process...it helps me understand what I'm doing.
I zoomed in on the pic of the 18% Clark in the beginning of the thread until it was 8" on my display, taped a piece of paper to the screen and used that to trace out the pattern. I cut my 8"x4" (root x tip), 24" wide wing blocks and set up the jig. I carried the lines of the LE and TE out via two long straight edges until they met and made that my pivot point.
I remember you saying (in the Roswell build, I think) that you offset the TE of the wing jig 4" or so away from the pivot point to get a consistent TE.....but...I couldn't wrap my head around this and was worried that if I didn't have the right distance of offset, it would screw up the airfoil. Anyway...my way, parallel with the pivot point, did not end up with nice thick TE. But I think it will suffice, they came out pretty well for my first airfoil, if I do say so myself! I had to forgo the string around the TE, but will try to reinforce in another way.
Cutting the toe-in and the flat spots for stabilization was easy, but I encountered something curious cutting the sweep. I measured twice and cut on a line from the LE corner and one inch back on each wing TE. Put them together and the sweep did not appear anything like the pictures, so what the heck! Two inches each side. Now it looks right. Still scratching my head over that one... ...The wing core blocks are supposed to have a right angle at the TE center, right? Maybe I'll draw some pictures...
Here's something I can contribute...I had an epiphany (or nightmare - we'll see) about my motor mount for this bird. I couldn't exactly copy what you've modeled, but I think/hope my solution will work. Currently I don't fly combat with anybody and I don't think I can get the wife and kids to come to Utah with me , so it looks sturdy enough for my self-inflicted abuse.
Ruminating about it, I mean staring at it, for a while, it occurred to me that the wing core beds make a nice negative for the wing core positive. That is, could I make a 2 or 3" wide section of the wind core bed into a motor mount? They have the same angle, there's a nice flat spot at the back for the motor, and there's lots of surface to spread the forces out.... Well I did. I thought I'd have to use part of the L wing and part of the R, but the angles seemed acceptable using 3" of just one side. Anyhoo, it's all glued and taped together and feels as strong as others I've used and liked well enough! When I'm able, I'll post some pics...
Dave
ATONAL6173 is offline Find More Posts by ATONAL6173
Old Jul 23, 2009, 09:50 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I'm sorry to hear you can't move to Utah. We are one of the sunniest places on earth without all the humidity. Great place to live.
I have always encouraged people to learn to cut foam and am pleased that you are trying. Our foam cutting tutorials have more action than the threads where we discuss plane ideas. Foam cutting however takes space and a very tolerant wife. It also has a learning curve. Most people in our club who have helped cut foam still have TJ and I do it for them. There is this nasty little learning curve and the cost of the EPP makes it so miscuts add up quick.
I flew combat yesterday with the club and all but one of the combat planes flying was cut in my shop.
Look at these threads for motor mount ideas. We have 2 Pinata building tutorials where we have described several ways to build a motor mount: I was using plumbing parts most of the time before we started to have the stainless steel motor mounts machined for us.
Notice also how the planes are covered. We have always used the reinforced tape but used it under the Ultracoat covering.
http://www.rcgroups.com/forums/showt...49#post9812220
http://www.rcgroups.com/forums/showthread.php?t=754139
As far as trailing edge. Just cut the wing it and trim the trailing edge after the cut. Even now if the blocks of foam are off even 1/8" we will have to trim the trailing edge again after the airfoil is cut.
Good Luck
Lee
PS here are some real combat planes.
Old Jul 24, 2009, 09:04 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
ALERT!!!!
We have recently had some reports of the reinforcement tape yellowing and the tape drying out and adhesive releasing over time possibly due to UV affect on the tape. We may be jumping the gun and giving an alert before we need to but I want you to know what I am hearing so that you can watch for problems.
This is a slow process and does not happen all at once and can be easily fixed so there is no immediate danger if it is happening. I need some help to accurately diagnose and come up with the best solution to fix the problem.
We have used the reinforced tape for years under Ultracoat but having it exposed to the sun may have some consequences that we did not anticipate. Please give us feedback if you start to see problems. I peeled the Ultracoat off of a flying wing that had been covered for more than 2 years to inspect the tape and the tape is fine. Paint over the tape also seems to offer some protection so we are assuming that it is a UV problem.
The plane design is sound and conventional covering methods shown in these threads will fix the problem.
So far only the exposed tape is a concern. We can cover the plane with an iron on covering like Ultracoat to eliminate the problem but we like the simplicity and weight of the bidirectional tape method.
If you see deterioration of the tape gently warm the tape with an iron and peel off the tape and replace it if you need to. It will not damage the EPP foam cores.
We are testing the tape exposed, under paint, under laminate and under ultracoat at this time trying to get more information.
Lee
Old Jul 24, 2009, 05:39 PM
Phiber Optik is offline
Find More Posts by Phiber Optik
Womb Drifter
Phiber Optik's Avatar
NC, USA
Joined Dec 2004
WOW! What an awesome thread!!!
I'm really starting to dig the Assassin. When my swift 2 gets trashed, this looks like my next plane!
Phiber Optik is offline Find More Posts by Phiber Optik
Old Jul 24, 2009, 05:58 PM
Jimmi is offline
Find More Posts by Jimmi
Jimmi's Avatar
Los Angeles Area
Joined Dec 2005
Its a very nice plane phiber, I got a few issues with my motor at this time and havn't put any time into as of yet. I just finished my superfly for one and thats out of the way now. I have the motor taped but looks like I'm going have to remove the tape and re tape it. Also my screws backed out some so the motor is a bit loose. Nothing serious at all but it takes time I havn't had. I have flown it twice already and until its fixed and everything is ok. then I will give my 2 cents worth. So far I'm very happy with it
Jimmi is offline Find More Posts by Jimmi
Old Jul 24, 2009, 07:13 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Don't worry about the tape until you have trouble with the tape. The plane is strong enough to fly without any tape. I have been flying mine without problems for months.
Lee
Old Jul 24, 2009, 08:36 PM
spad7 is offline
Find More Posts by spad7
what is a rudder for?
Sarasota, Fl
Joined Jan 2005
DX6i Differential
Lee; Do you set up your radio for differential and if so what settings do you use?
If I understand it right, you can dial in less down throw on the ailerons than up throw. This is supposed to result in a more axial roll.
Thanks Mike
spad7 is offline Find More Posts by spad7
Old Jul 24, 2009, 09:57 PM
hobgood is offline
Find More Posts by hobgood
Newbie
Bailey CO
Joined Mar 2009
Hey, all you guys flying combat with the $11 MG servos from HK mentioned in the parts list (http://www.hobbycity.com/hobbycity/s...idProduct=8610)
Have you broken horns? Found replacements? I hear that HiTech HS-50 servo horns work but want to confirm. I'd like to get something like this if they do:
http://www.amainhobbies.com/product_...o-Saver-Mini-T
If not please make a recommendation on servo savers that work with these!
Ben
hobgood is offline Find More Posts by hobgood
Old Jul 25, 2009, 12:04 AM
Telemachus is offline
Find More Posts by Telemachus
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
I got 4 of those servos, and the output shaft had no threads for the screws. Ended up having to tap them and install my own screws.
I have not broken any horns yet, and have no HS-50 to try, but I bet a hobby store would let you open up a pack of horns to try out.
BPhobbies now has the DElite LED system in stock. About the same price for the lights as the HC variety, but they run off of the receiver, so only gunna get a max of 5-6V power out of them.
http://www.bphobbies.com/view.asp?id...1&pid=D2378791
Not going to be as bright as the HC lights, but might be an alternative for night flying.
Telemachus is offline Find More Posts by Telemachus
Old Jul 25, 2009, 12:41 AM
Jimmi is offline
Jimmi's Avatar
Los Angeles Area
Joined Dec 2005
Lee its the tape that holds the motor down, it has some play in it and I think I need to shoot it with some adhesive so it can stick better. I will take the old tape off and redo it.
Old Jul 25, 2009, 08:00 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
More planes. I am still using tape but trying to put paint on it to block some UV.
The Roswell is a delta we used to cut that I am now playing with again but I am now trying to go finless.
Lee
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 05:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 12:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
