Old May 19, 2009, 08:38 PM
Gun Jam is offline
Find More Posts by Gun Jam
Got guns that can kill a ghost
Gun Jam's Avatar
Joined Feb 2009
Build Log
House of Balsa "Grim Reaper" P51 Mustang
Im starting work on a HOB k-72 kit. Its the electric mustang with the 46.5" wing.
I have quite a few mods planned for it from flaps to retracts as well as wing mods so it actually has p51D style wing...If wanted to build an Extra 300 I would have bought that kit..I'll see what I can do about that.
Hopefully unlike so many others this one actually gets finished.
-Gun
Gun Jam is offline Find More Posts by Gun Jam
Old May 21, 2009, 11:59 PM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
some progress
I got most of the fuse and wing completed.
The next step is to add the flaps and finish the almost complete wing fillet mod. (not shown)
-Gun
Old May 23, 2009, 11:44 PM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
Made some good progress with the over all kit construction and the mods
Next step is to build the tail and nose hatch then add retracts and servos
-Gun
Old May 24, 2009, 01:26 AM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
Your input!
Im going to need a 4 blade propeller...What do you think is my best bet... Varioprop?
Basically Ill get a power system to match the propeller I want 330 watts...
-Gun
Old May 24, 2009, 05:25 AM
Wilit run? 353 is offline
Find More Posts by Wilit run? 353
No such thing as overpowered
Wilit run? 353's Avatar
Suffolk, England
Joined Sep 2008
I am going to watch this. It loos a good plane. are there going to be retracts?
Wilit run? 353 is offline Find More Posts by Wilit run? 353
Old May 24, 2009, 11:51 AM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
yes robart 601s 85 deg....maybe retract tail wheel too if it will not become too complicated..
-Gun
Old May 24, 2009, 03:46 PM
Suffolk, England
Joined Sep 2008
so far it looks very good!!!
Old May 25, 2009, 01:02 AM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
tail section is done.. and pinned in place. the nose hatch is also finished.
I have to order retracts and servos...might be a few days before I get to do any more work.
-Gun
Old May 25, 2009, 01:08 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Wow!! That is gorgeous, Gun Jam!!
These props are getting good feedback and they're gorgeous (IMO).
http://www.hobby-lobby.com/scale_4-b...hQueryId=12128
As for a motor, I think an Eflite Power 10 might fit the bill.. you might be able to go cheaper but they're high quality and proven... 1100kv is usually a good target for a warbird on 3s in my experience. You probably know more about this stuff than I do...
http://www.horizonhobby.com/Products...odID=EFLM4010A
Smokescreen38 is offline Find More Posts by Smokescreen38
Old May 25, 2009, 01:26 AM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
Awesome thanks for the link...Ill have to compare those to the vario prop...at least I have some options now.
Im thinking this plane will weight about 2.5 lbs when done I would like close to 250 watts but not less so 250 to 330 is a good range...I think the power 10 may be a bit small. maybe a 15 size...still kinda depends on the prop I go with too i guess.
Thanks again
-Gun
Old May 29, 2009, 03:17 PM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
I got the tail covered while waiting for parts to arrive...
I still haven't ordered the main gear yet as robart 601 85 deg are more difficult to find than I had intended. The retract tail wheel and main wheels should be here today. I have power unit coming tomorrow...a 15 and a 25 ill see how they fit and deiced on which one I should go with. The 25 sounds good but the lighter weight of the 15 also sounds good hummm..
Yeah its the wrong tail number....maybe ill make it right someday...I figured that was close enough....for now
Old May 29, 2009, 04:00 PM
nicoyenny is offline
Find More Posts by nicoyenny
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
looking nice!!!
But I must warn you, a roll of paper won't hold those wings strongly enough
nicoyenny is offline Find More Posts by nicoyenny
Old May 29, 2009, 04:35 PM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
house of balsa assured me that the paper roll wing spar would indeed suffice
Old May 31, 2009, 08:31 PM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
Got the motor installed...I went ahead and used the .25
Got the retractable tail wheel system mostly installed waiting to be glued pending installation of mains...which I am still trying to find for a decent price.
-Gun
Old Jun 20, 2009, 12:20 AM
Gun Jam is offline
Gun Jam's Avatar
Joined Feb 2009
Got quite a bit of work done its almost ready for covering and test flight.
I still have to finish the bottom of the wing where the wheels will fit when retracted and thats about it.
I drove it around on the sidewalk and it has great ground handeling. That steerable tail wheel is a really nice setup.
So far things are looking good but the plane has swallowed up a few more servos than planned but reliability, simplicity, rigidity, and over all quality of component function has been greatly improved. The cost was perhaps 1.3 oz additional weight.. im using futaba s3114s and hs 55s for almost everything...There a 4 hs 81s for elevator, aileron, and 2 for the gear.
-Gun
New House of Balsa P-51 Mustang Bill Germanson Sport Planes 248 Oct 01, 2012 08:32 PM
For Sale RTF House of Balsa, Nick Ziroli P51. CooHead Aircraft - Electric - Airplanes (FS/W) 4 Jun 26, 2008 01:06 AM
House of Balsa .15-.20 size P-51 Mustang Bayou Boy Fuel Warbirds 24 Jul 31, 2007 10:31 AM
Anyone own the P-51D Mustang From House of Balsa? spoonie 1/2A Planes 30 Jun 03, 2004 09:05 AM
House of Balsa p51 Zhack Scale Kit/Scratch Built 9 Mar 16, 2002 01:47 PM
