Old May 19, 2009, 03:02 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
United States, OH, Cleveland
Joined Dec 2006
Build Log
GWS micro Mustang free flight conversion to DSM2 5 channel RC with BL upgrade
These are on sale for $20 so i got one. This thing is about the same size as a cox micro warbird @ 20'' wing span. I think this could be done as a 1 cell lipo plane.
edit..looks like is 24.5'' wing span..my bad
flight video http://www.rcgroups.com/forums/showp...3&postcount=28
modfly is offline Find More Posts by modfly
Old May 19, 2009, 03:11 PM
rusty gearz is offline
Find More Posts by rusty gearz
rusty gearz's Avatar
Joined Jul 2007
interesting, where did you get it?
Your plan is gut it out and put fresh up-dated gear in it?
rusty gearz is offline Find More Posts by rusty gearz
Old May 19, 2009, 03:20 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Well, its a kit so no gutting is involved.
http://www.caliberhobby.com/p51d_kits.html
I have a 1 cell radio setup from a P3 Swoop that should work well in here.
Old May 19, 2009, 03:54 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
I think this is a much better plane than the Cox warbird kits as this one has landing gear and battery's and motor and Gear box. The motor is setup for 3 nimh cells 3.6v so a 1 cell lipo will be perfect. Its a 130 motor same as the CWB but has a different winding (low impedance 3v). If wanting to do a 2 cell setup, just swap the motor with a 6v or 7.2 v winding. I think if Cox had added a Gear Box to their kit they would have been a much Better kit as DD motors are very inefficient.
I have not really decided which way to go with this kit but I plane on doing a light weight build of some kind. I may not even use the motor that comes with it and may go with a small BL setup.
Old May 19, 2009, 04:04 PM
SporadicIdiocy is offline
Find More Posts by SporadicIdiocy
Sakura Ultimate graduate
SporadicIdiocy's Avatar
Richmond B.C. Canada
Joined Oct 2007
Is it the same as this one?
http://www.rcgroups.com/forums/showthread.php?t=472937
SporadicIdiocy is offline Find More Posts by SporadicIdiocy
Old May 19, 2009, 04:20 PM
trust416 is offline
Find More Posts by trust416
Toronto, Canada
Joined Jan 2005
damn that is sweet!
I have to get one of these...like now
trust416 is offline Find More Posts by trust416
Old May 19, 2009, 07:01 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Originally Posted by SporadicIdiocy
Yep. nice little kit for $20. I ordered it and some spare GWS parts from caliber hobbies. shipping was reasonable and I got it in a week.
Old May 19, 2009, 08:00 PM
flyn_brian is offline
Find More Posts by flyn_brian
fly it crash it fix it
flyn_brian's Avatar
Joined Feb 2009
The p51 is one of my favorite war birds. Mod on modfly. Make it cool put in a pz brick and a bl motor.
flyn_brian is offline Find More Posts by flyn_brian
Old May 19, 2009, 09:22 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
yea, that is a possibility
Old May 20, 2009, 02:34 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
RC Conversion in progress
Started work on this plane today..Started with H-stab. The foam on this plane has a lot of flaws and mold release marks. The molding although decent is not up to GWS standards. There was also some dents in the foam here and there and I'm sure thats why all sales are final on these planes. They are still worth $20 IMO.
Old May 20, 2009, 05:54 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Tail feathers hinged and H-V stabs installed.
Got this phase done.
edit. I had to redo the H-stabs because the wire joiner I used was too thin in diameter and caused unequal deflection So I had to rip it all out and redo it. When you see pics of the H-stabs, they will be white depron foam.
Old May 20, 2009, 07:33 PM
rodair is offline
Find More Posts by rodair
What goes up must come down..
Canada, QC, Saint-Laurent
Joined Jan 2002
Mod you're coming better then ever!
Nice mod. I'll follow this one.
Roger B.
rodair is offline Find More Posts by rodair
Old May 20, 2009, 09:41 PM
trust416 is offline
Toronto, Canada
Joined Jan 2005
looking good man.
I want that Ryan STA, it looks sweet...that site only has the p-51 it would seem though
Old May 22, 2009, 12:03 AM
modfly is offline
modfly's Avatar
Joined Dec 2006
Fitting the motor and Gear box and prepping for radio control
Started by adding filter caps to the motor so I had to take the gearbox apart and thats when I discovered that the pinion was very loose on the motor shaft. I had another that fit tighter so I used that and reassembled the gear box and wired a connector to the motor and tested with a single lipo cell. Motor drew 1.5 amps which if the plane was empty like in free flight mode, that would probably be enough power. Tried it with a 2 cell lipo and got about 3 amps draw WOT. That should be plenty! So I decided to go 2 cell lipo and conventional radio gear more on that later. Installed the gearbox to the fuselage with GWS glue and went to install the cowl, thats when things got tricky as the cowl did not want to fit as there was way too much right thrust and interference with the gearbox and the cowl. So removed the gearbox and cleaned off the contact cement and added some shims and test fitted till it fit then epoxied the gearbox to the fuselage. then pressed on the cowl. This would have been more than most newb modelers could have done. Nothing on this plane fits like its supposed to Its actually fun for me to over come these problems as a modeler but I bet some people would not enjoy or expect all these misfitting parts that are poorly finished etc. Now I know why it says all sales final To me, these are just little problems to fix and no biggy and most modelers with experience will be able to work around the minor issues.
Discussion GWS P-51 Free Flight mthomas Foamies (Kits) 21 Apr 01, 2009 04:14 PM
Question Where are ready built free flight toy planes to convertt to micro R/C sold? poobs Scratchbuilt Indoor and Micro Models 31 Oct 17, 2004 05:54 PM
Need GWS Micro Flight pack. jocappy Aircraft - Electric - Airplanes (FS/W) 2 May 17, 2002 12:09 AM
GWS free flight P51 RC conversion iamDerrick Parkflyers 10 Mar 13, 2002 10:00 AM
