Old May 19, 2009, 01:14 PM
knukS is offline
Find More Posts by knukS
Aberdeen
Joined Mar 2007
How do the engine tests test HP?
Just wondering - do they have a proper dyno?
knukS is offline Find More Posts by knukS
Old May 19, 2009, 02:35 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Where did you see the figures quoted? Some are run on a dyno, most are not.
Greg
gkamysz is offline Find More Posts by gkamysz
Old May 19, 2009, 10:55 PM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Some use a set of calibrated props, some use a torque reaction dyno while the best use an inertia dyno. Manufacturers throw darts and high score wins .
downunder is online now Find More Posts by downunder
Old May 20, 2009, 09:50 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I don't think I've ever seen an inertia dyno used on an airplane engine. I don't think it's appropriate either. We tune airplane engines to the actual load. An inertia dyno doesn't allow that, but does represent how a car engine is used. I mean that if the needle is set correctly for 10kRPM on a four stroke, it will be far too lean for 8kRPM, let alone the 4-5kRPM the test would normal start at. It might be fun to watch though, as the engine and dyno attempt to beat each other into submission.
Last year I think I watched an ebay auction for a set of aluminum calibrated load props (Graupner or Kavan?). It went for a very reasonable price and I regret not bidding on them. Oh well, a reaction torque dyno will have to do.
Greg
Old May 20, 2009, 10:18 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
A good way to do it:http://www.mh-aerotools.de/airfoils/...erformance.htm
very precise
coriolan is online now Find More Posts by coriolan
Old May 21, 2009, 01:25 AM
rc_sjo is offline
Find More Posts by rc_sjo
Beaver Boy
rc_sjo's Avatar
Joined Nov 2001
Originally Posted by coriolan
This would only allow you to measure torque (and thus power) at one speed though, as you wouldn't be 'braking' the engine until you go full throttle.
rc_sjo is offline Find More Posts by rc_sjo
Old May 21, 2009, 08:35 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
That is how dynos work. Most people are interested in wide open throttle power figures, but auto engine designers spend a lot of time on dynos at part throttle settings.
To get different loads one would use different props.
Old May 21, 2009, 11:07 AM
unattainium is offline
Find More Posts by unattainium
Chicago
Joined Jan 2009
The classic model engine dyno used an eddy current brake. It could be adjusted to match the torque and the torque measured by the torque reaction using a balance. This method is very accurate and permits the plotting of torque (and hence power) against RPM.
A simple rig would be to use a generator with a variable load and a balance to measure the torque. The load would only have to handle less than 1KW for most engines. The generator would have to be able to handle 30,000 RPM or more.
A fan in a duct which can be throttled might also make a simple brake for a dyno.
unattainium is offline Find More Posts by unattainium
Old May 21, 2009, 12:53 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
All of those methods have been used for engine dynos. I don't think anyone actually dynos engines in any of the American magazines anymore.
Greg
Old May 21, 2009, 05:42 PM
rc_sjo is offline
Beaver Boy
rc_sjo's Avatar
Joined Nov 2001
It may be some peoples perceptions, but unless model flying only spend their time at WOT then I think the other engine speed figures are important.
I can't remember the last time I saw a torque curve for a glow engine.............
Old May 21, 2009, 07:33 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I don't understand. How is part throttle information useful for a model airplane? Besides if you have the WOT figure you can calculate any part throttle figure.
Greg
how do I connect Whattmeter to test brushless? joey221 Power Systems 9 Jun 25, 2002 02:44 PM
How do I test for good and bad cells nigel99 Power Systems 3 Apr 28, 2002 07:16 PM
How do I test my speed controller? repo32 Electric Plane Talk 1 Sep 25, 2001 07:02 AM
How do YOU test/discharge your packs? hardlock Electric Plane Talk 2 May 28, 2001 10:02 AM
How do you test battery cell? stevesteve Beginner Training Area (Aircraft-Electric) 1 Apr 30, 2001 08:59 PM
