This thread is privately moderated by feathermerchant, who may elect to delete unwanted replies.
Old May 19, 2009, 06:06 AM
feathermerchant is offline
Find More Posts by feathermerchant
Trader Rating: 56
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
For Sale
12V Power supplies 42A $50 and 12/24V 47A power supplys for your chargers
I have 2 kinds of supplies to power your chargers wherever you have access to 120V. They are pulled from file servers and so they provide a well regulated supply suitable for any charger that needs 12VDC. They will not burn up if overloaded but will just shut down. Just disconnect everything and wait about a minute and reconnect.
The first will provide 12V up to 42A. I have used one of these every week at the field for about a year. I can power two Astro 109's and 2 Triton II's.
I have found I can also use one to power my Hyperion Duo and charge two 6S 5000 packs at once at 5A on each pack.
All this supply needs is a PC power cord and for you to solder/clip/etc your charger onto it.
I am selling these for $50 shipped in the CONUS.
The second is about the size of the first and will put out 47Amps. It also needs a PC power cord plugged in to it.
You can order here:
http://www.feathermerchantrc.com/
The wires soldered to the supplies as shown on the website are not included.
I also have plugnplay 24V 47A power supplys with output wiring for big chargers.
PM me if you want any special work. I can supply a power cord for $3 each.
There is an email which is also my PayPal on the website.
feathermerchant is offline Find More Posts by feathermerchant
Old May 19, 2009, 09:57 AM
NumbSkull is offline
Find More Posts by NumbSkull
Trader Rating: 191
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
Trader Rating: 191
Hey James,
I'm loving the 46 amp supply I got from ya. I tried to shut it down the other day, by running two Hyeprion 610iNet chargers, and two Astro 109s all charging 6S 5000 mah packs at the same time... that little puppy didn't even blink!!!
Awesome power!! Thanks again!!
NumbSkull is offline Find More Posts by NumbSkull
Old May 19, 2009, 02:31 PM
elkman817 is offline
Find More Posts by elkman817
Trader Rating: 9
Tennessee
Joined Sep 2007
Trader Rating: 9
I"ll take one of the 30A for $40. At work now, but will send PM tonight. -Bryan.
elkman817 is offline Find More Posts by elkman817
Old May 19, 2009, 03:48 PM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
You can payapl me using the website above.
Old May 19, 2009, 05:27 PM
termite is offline
Find More Posts by termite
Trader Rating: 555
Utica Il.
Joined Dec 2002
Trader Rating: 555
James,
I'd like to get the 46 amp WITHOUT the power cord and didn't see that on website
Can you PM me with PayPal info and total with shipping to 61373
Randy
termite is offline Find More Posts by termite
Reply With Quote  (Disabled)
Old May 19, 2009, 05:46 PM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
Sure Randy. Just use the email address on the website and Paypal me $40. Make sure to include your mailing address. That's a specail price just for you. Be sure to tape it like I did in the pictures. It helps prevent shorts.
Old May 21, 2009, 06:46 PM
termite is offline
Trader Rating: 555
Utica Il.
Joined Dec 2002
Trader Rating: 555
James,
I just sent that PayPal
Thanks a heap
Randy
Old May 21, 2009, 08:24 PM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
Randy -- Remember to install tape like in the pics on my website. It prevenst surprise flashes. Also you cannot see but the power cord passes thru the plastic Molex connector and the wires are soldered inside. I cut 4 cells out of the 'eggcrate' to make room for the wire. Then I use a tiewrap inside the connector as a strain relief.
Old May 28, 2009, 06:32 AM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
Randy - did you get yours finished?
Old May 28, 2009, 07:45 PM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
It's been asked again so to figure out about how many amps you need from 12 Volt power supplies to run your chargers:
For each battery, take the number of cells X 4.2 X the charge rate in Amps divided by 10. Add the results for all batteries you can charge at once together.
Example:
6S 5,000 pack charged at 1C
6 X 4.2 X5 / 10 = 12.6 Amps
The Hyperion duo has 2 outputs and uses 26 Amps to charge 2 of these packs at once.
If you need more than one power supply, I can ship more than one in a box and so you can save some money. PM me and I can give you a total.
Old May 28, 2009, 08:01 PM
PerlAddict is offline
Find More Posts by PerlAddict
Trader Rating: 37
PerlAddict's Avatar
USA, TN, Murfreesboro
Joined Sep 2006
Trader Rating: 37
Sold some stuff so I could afford the upgrade. Sent you $50 for a 42A PSU a couple of days ago, just in case you needed any confirmation from here.
Thanks James!
- Dave
PerlAddict is offline Find More Posts by PerlAddict
Old May 28, 2009, 08:28 PM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
USPS says it left FtWorth May 27:
http://trkcnfrm1.smi.usps.com/PTSInt...34711694447109
Old May 28, 2009, 09:09 PM
Trader Rating: 37
PerlAddict's Avatar
Joined Sep 2006
Trader Rating: 37
Sweet. Just thought I'd let you know it was me, since my Paypal doesn't have any info that would make it obvious who it was here on the forums.
Thanks again. I'd imagine it'll get here tomorrow.
Old May 28, 2009, 10:44 PM
Trader Rating: 56
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Trader Rating: 56
Yeah I had to pair your name above with the date and what you ordered. I'm sure you'll like it.
Old May 29, 2009, 12:04 PM
Trader Rating: 9
Tennessee
Joined Sep 2007
Trader Rating: 9
Got mine in the mail on Tuesday, but just got around to use it yesterday...works like a charm! Thanks!
For Sale 12V Power supplies 30A $40 and 46A $60 for your chargers feathermerchant Aircraft - Electric - Batteries & Chargers (FS/W) 51 Sep 03, 2009 07:49 PM
Discussion Samlex regulated 12v power supplies 83GT Batteries and Chargers 0 Jun 02, 2006 10:18 PM
Discussion N-Am 12v power supplies, Euro outlets ptxman High Performance 9 Mar 23, 2006 11:03 PM
For Sale: Pretty Unbelievable 12V Power Supplies for Chargers Quacker Batteries and Chargers 13 Aug 22, 2005 10:03 PM
2, 12v power supplies FS Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 7 Sep 26, 2004 12:24 PM
