Old May 18, 2009, 08:53 AM
chris_jacques is offline
Find More Posts by chris_jacques
United States, WI, Hartford
Joined Sep 2007
Help!
KF-airfoils on an F-20 foamy pusher prop
Hello to all,
I want to know if anyone could help me with the size KF-airfoils should be and the best placement of them also. I will tell you what I did and how the plane reacted.
I built an foamy pusher prop F-20 from a plan on Parkjets.com and it originally flew well but I wanted more speed out of it for low passes and I also wanted more lift so I could land it at slower speeds.
When I added the KF-airfoils it was VERY pitch sensitive and on the turns it seemed that it was not responsive until I had the stick all the way to the right or left and then it was too much. It almost wanted too roll.
Now Iíll tell you how I set them up on the plane.
I used the airfoils on top and bottom of the wings. I over lapped the
leading edges of the KF-airfoils over the leading edge of the wing about
ĺ of an inch and on the trailing edge the airfoil was 1 inch from the ailerons.
Should I have put the leading edges of the airfoils even with the wing and further
from the control surfaces and then should I have also made the bottom one shorter than the top I donít know. I need help.
You can see my videos of the plane with and with out the airfoils at www.youtube.com/gwsslowstick to see for your self.
Thank you for any help you can give.
chris_jacques is offline Find More Posts by chris_jacques
Old May 18, 2009, 11:38 PM
adamdb is offline
Find More Posts by adamdb
United States, CO, Denver
If the KF step is on top of the wing it should only go back to 50% of the chord of the wing. If on the bottom, it should only go back to 40% of the chord. You can put the KFm on both the top and bottom, just end the top at 50% and the bottom at 40%.
adamdb is offline Find More Posts by adamdb
Old May 19, 2009, 12:19 PM
JimW is offline
Find More Posts by JimW
North Kent, England UK
Joined Jan 2005
It seems that if the KFm strip is too close to the ailerons it causes turbulence. That could be your turning problem. I'm sure someone more knowledgeable will chip in with the technical answer. Did you move the centre of gravity back after adding the KF strip?
Jim
JimW is offline Find More Posts by JimW
Old May 19, 2009, 01:01 PM
magic612 is offline
Find More Posts by magic612
Bernoulli+Newton=Lift
magic612's Avatar
Somewhere south of Chicago, IL
Joined Jan 2006
I don't know an enormous amount about airfoils and aerodynamics, but I think these two points are at opposite ends of the airfoil spectrum. An airfoil that excels at high speed is not going to be ideal for low speeds, and vice versa.
There may be a practical solution in the KFm universe (or other airfoils, for that matter), but I think at some point it will have to be a compromise of some sort, especially as you increase speed and still want slow landings. The question is: Which aspect is more important to you? Perhaps using flaps might be a reasonable option for getting the slower speed landings you're looking for while maintaining a thin airfoil profile for high speed maneuvers?
Just a thought.
magic612 is offline Find More Posts by magic612
Old May 19, 2009, 02:17 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Yup, adding a K-F may reduce overall top speed (as wittnessed by other posters here), but does wondes for slower speeds.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old May 19, 2009, 04:35 PM
uhupor is offline
Find More Posts by uhupor
uhupor's Avatar
Joined Dec 2006
KF (Kentucky Fried) Airfoil on Pusher Jets
I have built the Shumate Saab Grippen and made a kind of KF-airfoil on it. Mainly so it does not look like a piece of flat cartonage with prop when flying slower. At least you have some lift and can fly more horizontal.
I hope, I did not Maiden the thing until now. It should have enough speed with the Mega 16/15/2 with 4'100 RPM we will see with the tiny airfoil what happens.... ;-)
uhupor is offline Find More Posts by uhupor
F-20 Tigershark Pusher Jet Tim H. Pusher Prop Jet Models 125 Nov 27, 2009 06:58 PM
Discussion GWS F-15 Eagle Pusher Prop version kent1201 Pusher Prop Jet Models 102 Sep 08, 2008 12:02 PM
Discussion alfa f-86 as pusher prop? yucafrita Pusher Prop Jet Models 19 Jan 30, 2008 07:25 PM
Help! Foamy pusher prop jet for a Park 400 inrunner? edge5foamy Pusher Prop Jet Models 0 Jun 27, 2007 06:07 PM
Re-Winging Kyosho edf F-16, making pusher prop Aten W Arthog Electric Ducted Fan Jet Talk 0 Oct 27, 2002 06:04 PM
