Old May 17, 2009, 01:41 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
Bullseye Delta, RET w/no dihedral delta-- the finest RET Delta w/ Video
Got a new plane in the air yesterday. It is a hybrid between my Nutball Delta and Glen's Bullseye. I will try to get some video in the next week. Perfect slow flier. Speeds right along. Should handle winds or calm. Absolutely NO DIHEDRALyet it turns, loops, rolls just fine. It also flies inverted. Hobby-Lobby foam core with paper removed and painted with Krylon H20 Yellow. Spars are bamboo slats out of a roman shade because it was available to use. The hole is the same shape centered and one third the size CG about at the LE edge of the hole. Doubler is used. I had originally planned to use this frame as a replacement 4ch NBD before I revised the plan and had cut a 40%doubler for the bottom. However, I put it on top to simulate the S curve of the original Bullseye. You can also see the little triangles in the corners of the TE that hot hot glued back in solid (in case that looks confusing) that I had intended for tailerons for the 4ch model.
Glens' Bullseye thread: http://www.rcgroups.com/forums/showthread.php?t=77455
My Nutball Delta thread: http://www.rcgroups.com/forums/showthread.php?t=893481
Plans used was this. http://www.rcgroups.com/forums/showp...2&postcount=71 I shrunk them again to one third the full size and centered for the bullseye hole.
Specs:
Length: 20"
WS 18.5"
Rewound Turnigy 2730 by Dave North 16.+oz thrust on 2s with GWS 8040 1900+Kv
hextronik 10A esc
hextronik 5g servos
berg4l
Airframe weight 158g (no battery)
AUW with ABF 900mAh battery 208g (7.4oz)
CG for all models is about 28% or so of the chord. The front of the hole is a good place to start. Adjust to suit your taste and conditions.
Bullseye Delta 7 31 10 (4 min 32 sec)
15" WS 6mm EPP Version 116g AUW w/ 240mAh 2s 2204-14t 5g servos 7035prop 2.4g rx
6mm EPP Bullseye Delta.wmv (5 min 38 sec)
Bullseye Delta indoor landing skid and walk around (3 min 13 sec)
tymbrewolf is offline Find More Posts by tymbrewolf
Old May 17, 2009, 03:14 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Got plans ???
gpw is offline Find More Posts by gpw
Old May 17, 2009, 03:36 PM
Joined Feb 2007
Well, actually the plans are on the Nutball delta thread post #1 except for the center cut. I just used them and shrunk them down until they were 1/3 for the hole and centered it. Unlike the plans though, I have increased the 20" size control surfaces on the model shown to 3 1/2 inches instead of 3.
Also plans for the NBD drawn by Gene Bond for me.
Last edited by tymbrewolf; May 17, 2009 at 04:17 PM. Reason: added Gene Bond's plans for my NBD
Old May 17, 2009, 03:44 PM
dean_85 is offline
Find More Posts by dean_85
Alberta, Canada
What benifits is there cutting a hole in the middle?
dean_85 is offline Find More Posts by dean_85
Old May 17, 2009, 03:51 PM
Joined Feb 2007
Well, that would be discussed in the Bullseye thread to some extent. Perhaps it is a pressure relief valve that helps allow it turn with out tips on RET. Perhaps Glen could fill in the reason for it. I merely modified one of his seeminly partially forgotten well flying designs to a delta. It works very well. I can't answer that, just know it works.
Old May 17, 2009, 05:30 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Dean , I defer to the Lee-Richards annular wing planes ... http://www.internetmodeler.com/2006/...e-Richards.php
It has been written ,that the hole makes the wing behave more like a tandem or JWA ...
Old May 17, 2009, 05:59 PM
Joined Feb 2007
BTW, some other disk aircraft although mine is a delta.
http://discaircraft.greyfalcon.us/Wo...evelopment.htm
Old May 17, 2009, 10:20 PM
Joined Feb 2007
I was planning to borrow my daughter's nice digital camera for the week for some video. However, she took it home with her. Looks like I can practice some inverted RET before I might get to document the fun you can have.
Old May 18, 2009, 01:51 AM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
I think I now know where the inspiration comes from for some of the foam contraptions that have showed up at our field.
No, it's not that site on disc machines and it's not imagination, it's gotta be the BC Bud.
goldguy is online now Find More Posts by goldguy
Old May 18, 2009, 06:53 AM
Joined Feb 2007
Frank, had to google your comment. I didn't know cannabis and RC flying went together. To each his own I guess. I lean more to the conservative side of thngs.
Old May 18, 2009, 08:41 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
From the looks of those old planes , seems like nothing is New eh ??? We're just re-inventing the Foamie wheel ...hahahaha
Old May 20, 2009, 09:44 PM
Joined Feb 2007
Lumifly FAA lighting system from HC on the plane.
Poor video: http://www.rcgroups.com/forums/showt...4#post12285790
Old May 23, 2009, 09:44 AM
Joined Feb 2007
Two batteries thru this morning. Perfect and calm. I still get so confused inverted with a rudder. I like this challenge. So easy to fly.
Old Jun 11, 2009, 06:37 PM
Joined Feb 2007
Continues to be about the only plane I fly. Now that I can fly at dusk with the lights, it is great in close and fast on the wing. I am going to try another soon with another motor so I can do 16oz on 2s 9x5 and 22oz thrust on 3s on a 8x4 ion a Dave north motrofly 2205 rewind. I did lose my rudder a few days ago trying to fly in 15+ gusts. I was floating near the ground and a gust caught it in a turn and it got pile drived in the ground and cracked the vert stab. HG and I added a little half bamboo skewer up the side for more support.
Old Jun 12, 2009, 06:11 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Very Cool !!! Mind that wind !!! hahahahaha
Discussion Simple Delta... a quick build "prop on the front" delta dekan Foamies (Scratchbuilt) 3023 Sep 26, 2016 07:51 PM
Discussion Simple Delta BIG QUESTION POST #10 DRITCH Foamies (Scratchbuilt) 22 Jan 26, 2008 03:29 PM
Discussion Simple Delta Donald Santee Foamies (Scratchbuilt) 0 Nov 05, 2007 10:15 AM
Discussion Simple Delta EDF JDExsquid Foamy EDFs 0 Jul 24, 2007 10:20 PM
Sold Dymond Super TURBO Delta peak charger lecofly69 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 23, 2006 03:30 PM
