Hi guys there is a build thread running on RC NETWORK.
http://www.rc-network.de/forum/showthread.php?t=138194 |
Joined Mar 2009
and another things here http://forum.modelisme.com/viewtopic.php?id=178625&p=2
and here http://www.airstage.ch/index.php?opt...=74&Itemid=148 |
Australia
Joined Oct 2000
DG1000 is 1st generation of Fly Fly scale gliders, if u look the at jump in build quality between the DG and the Condor..they have learnt alot. They do not use Gelcoat..it is some sort of heavy paint which crack easily. Fun Per $ spent Fly2 is good value for money.
TFLG (who likes a cheap kit but will not be spending $400 on a flyfly unless it's close to HF or S2G in quality) |
Hi guys
I just got one of those kits and do not really agree with you. Fuselage: I was impressed. Very nice layup, seamless and painted using 2k paint. On other models I often had to put 2 layers of fiber cloth to strenghten thr structure, but on the fuselage there is no need. and I love the seamless fuselage, way better than the HF DG-505 I owned. In the interior there are already formers glued in, all the parts are laser cut. Negative pointa: There is a wheel mounted, but due to the glued in formers it would be very hard to put a retract. the other point is the weak canopy frame made of abs, which has a poor fit on my model. Wings: Straight, well made, I do not like balsa as sheeting but I planned anyway to glass the wings with a layer of carbon or fiber (80g). The winglets are painted too and are well made. I was impressed by the quality of the iron-on film. Very well ironed, but the film is too transparent for my taste. Negative point: The wings come in two parts. The outer panel (about 12") are having joints I would not trust, they are too weak. The idea is not bad for easy transport, but I am not sure about the strength. I will glue them before glassing the wing. ++ price + elevator mount ++ fuselage quality - - canopy frame, material and fit - Weak jointer for the outer panels regards, chris |
| Thread Tools | |
| 4 meter Duo Discus install and fly | Jeff Meyers | Scale Sailplanes | 51 | Dec 26, 2009 09:45 PM |
| Discussion 4 good places to fly going to waste.... | 1987tc | USA - District VI | 3 | May 21, 2007 10:33 AM |
| New P-82 Twin Ready To Fly Twin 4 Strokes | comtech001 | Aircraft - Fuel - Airplanes (FS/W) | 7 | Jan 14, 2005 10:37 PM |
| should you fly inverted 4' off the deck and hit your photographer ? | Goleith | Parkflyers | 0 | Nov 04, 2003 08:09 PM |
| Pics from Grand Haven MI fun fly going on now | rojoyinc | Electric Heli Talk | 1 | Apr 14, 2002 04:43 PM |
