Old May 14, 2009, 06:00 AM
toyheli is offline
Find More Posts by toyheli
Joined Oct 2008
Angle of flap deflection in FUNJET
I'm using JR ES375 servos and set the servo arms at 90 to the servo case. How much should the flaps move up when full elevator is applied?
toyheli is offline Find More Posts by toyheli
Old May 14, 2009, 06:05 PM
istandalone is offline
Find More Posts by istandalone
life is an oyster. shuck it!
istandalone's Avatar
bennington, VT
Joined Mar 2008
probably get an answer faster in the funjet thread.
istandalone is offline Find More Posts by istandalone
Old May 15, 2009, 02:33 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Excerpt from the instruction manual:
The elevon travels must be set correctly in order to obtain a balanced control response: the elevators should deflect up (stick back towards you) by about 12 mm, and down (stick forward) by about 10 mm. Set the aileron travels to + 10 mm / - 13 mm (negative differential). If you cannot set these
travels by making adjustments at the transmitter, you will need to re-position the pushrod connectors on the elevon horns.
The neutral position for the first flight should be approximately 2 mm “up”. With the model set up in this way, you will usually need to apply slight down-trim for general flying. After the first landing mark the correct elevon setting on the fins using a waterproof felt-tip pen. When you fly the model, trim both elevons “up” by about 1 mm, i.e. 1 mm above the marked points. After the initial climb to height, move the elevator trim back to centre for the remainder of the flight.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Discussion LS in Funjet rsoucie Power Systems 1 Mar 12, 2007 03:04 PM
Question Flap Deflection Kaan Sailplane Talk 7 Oct 30, 2006 02:53 PM
Need help setting flap deflection ToddL Hand Launch 2 Apr 16, 2005 12:13 PM
zagi flap video in slo motion Ronbo Foamies (Kits) 2 Dec 18, 2001 02:29 PM
