Old Dec 29, 2009, 06:08 PM
littleoak is offline
Find More Posts by littleoak
Goats & Glocks Eat Anything
littleoak's Avatar
Houston, in the Great State of Texas
Joined Jan 2009
Originally Posted by vinmech View Post
One thing to check, when installing the wing, I glued the wing to the bottom saddle. there is a little wiggle room there, if you glued middle or top saddle??
Mike,
In preparation for build of Silo 2 - Here you said you glued the wing to the bottom of the saddle. So you perfectly aligned the wing to sit symmetrically in the bottom of the saddle and then CA'd that first? I take it you also glued the top of the wing to the fuse after the bottom had set (sounds like a stupid question, but I'm just checking)? You are right that there is some 'wiggle room' to slightly miss-align the main wing by a fraction. Please let me know. Thanks! Anyone else feel free to chip in.
Also anyone flying with 5g servos. I built my last one with HXT900 (9g) servos and they were great, but I was wondering if I should order HXT500 (5g) for a little weight saving, but was a little concerned that they would not be able hold surfaces firm in harder 3D moves (blenders for example).
littleoak is offline Find More Posts by littleoak
Old Dec 29, 2009, 06:19 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Originally Posted by littleoak View Post
Mike,
I'd not use the HXT500s. The HXT900's are the best imo
Xpress.. is offline Find More Posts by Xpress..
Old Dec 29, 2009, 06:40 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Cheers
Let me first say that I completely agree with Xpress on the 5 Gram "any" type servos. I like to build light, but that is one thing I dont mind the extra weight. I run the Futaba s3110 or s3008 servos and they are 9 gram.
I did a very simular thing that mikeeeeeee did, I set the wing in the saddle and noticed the play space so I used UHU Creativ on the bottom of the saddle, it has a tad more body <and flex> then the CA.
I turned the plane inverted with the wing in the saddle, used Masking tape on the wing and fuse and then squeezed the UHU inbetween, cleaned off the excess, flipped it over and trued it all up. 30 minutes later it was set, did the same on the top side, the UHU has the body to fill the little bit of gap. I finished it with a smidge of hot glue on each corner which makes a quick check point after a rough landing if anything tweeked enough to pop it loose.
Glad to hear you have another one getting ready to go.
Ron
Mike,
DaOldGuy is online now Find More Posts by DaOldGuy
Old Dec 29, 2009, 07:44 PM
littleoak's Avatar
Joined Jan 2009
Ron,
Where do you get your UHU creativ from? I think Michaels may sell it, but I'll have to swing by and check.
Old Dec 29, 2009, 07:52 PM
DaOldGuy's Avatar
Joined Dec 2007
Ron,
They pulled it from the shelf, I have been ordering it off Amazon in 6 packs. 8)'
RCFoam sells UHU Por which is the UK Version <same stuff>. Or let me know, I postal a tube to you.
Old Dec 29, 2009, 08:59 PM
littleoak's Avatar
Joined Jan 2009
This one ?
http://www.amazon.com/1-12-POLYSTYRE...141906&sr=1-19
Old Dec 29, 2009, 09:01 PM
DaOldGuy's Avatar
Joined Dec 2007
That is the stuff. I use it on all "eattable" foams and on EPP
For EPP I use Welder.... It eats all other foams. 8)
Old Dec 29, 2009, 11:40 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
I used the HXT900s on 3/4 planes but have been retro fiting them back to Hitec 55s. The HXT900s just don't center as well after a period of time. I lost both a Silo and Pluma due to these servos.
I stated noticing that after launch/takeoff I'd have to trim the plane. Then after a few manuevers have to trim again. After 20/30 flights I couldn't trim them that well as it seemed the floated and never centered correctly anymore. After going back to the HS 55s the problem went away.
I've also been experimenting with the Parkzone PKZ1061 digital mini servo (same as on stock Stryker) and must say I think I'll be using this servo in the future instead of the HS55. It's by far the best mini servo I've used yet for consistancy and durability. It's only a $12 servo so it doesn't add a tremendous amount of cost to a small model and I like the piece of mind I'm getting from them.
Carlo
cayars is offline Find More Posts by cayars
Old Dec 30, 2009, 12:12 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Weight?
Old Dec 30, 2009, 12:23 AM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Honestly I don't know but it's the same form factor as the HXT900. I've got two still in the package so I'll weigh them on my gram scale at work tomorrow and let you know.
Overall however I'd guess they are an 8-10 gram servo. Definately worth the upgrade IMHO.
Carlo
Old Dec 30, 2009, 12:30 AM
vinmech is offline
Find More Posts by vinmech
Old skool speed freak!
vinmech's Avatar
Napa, Ca
Joined May 2004
Mike,
Hey Littleoak,
On the wing what I did was align the wing to the bottom wing saddle, square to the fuse and spot ca glue it to hold its position. Then I used RC/56 glue, which I have found works great with this foam. Similar to Uhu glue in its properties, and dries clear as well, but may take a little longer to dry. I happen to have it, that is why I used it. Uhu is tough to find around here.
RC/56 goes on pretty much like white caulking, keep a little bit of water to dip your fingertip into to smooth out the beads with and when it dries clear overnight, you will hardly know it is there! This stuff is easy water clean-up before it dries!
I ran a bead on the outside as well as inside the fuse on the wing and stab.
I also used a bit around the motor mount and bulkheads to beef up the weak factory glue jobs.
I don't recommend the 5 gram servo's, I used these 8 gram turnigy's, after having used the 9 gram hxt servo's and they seem to be better at centering and torque. I probably have over 50 flights on these so far without any problems!
Good luck buddy, Mikeeee
vinmech is offline Find More Posts by vinmech
Old Dec 30, 2009, 05:34 AM
DaOldGuy's Avatar
Joined Dec 2007
Those Turnigy servos seem really nice, I have a couple of the 5 grams just to test. I agree on the centering of the hxt 9 grams, that is one reason I stick with the Futaba and I also have some HS-50 and HS-55 as well. I have stripped a couple HS-55s, knock on wood the Futabas have held up.
I have a Parkzone Typhoon 2 3D, I am not sure what servos it has but them silly things make soooo much noise even when they are not moving, its funny.
Old Dec 30, 2009, 08:51 AM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
They are noisy servos but most digital servos are noisy. I know they hold up very well and I've never had a centering issue with them. If they work on the Typhoon 2 3D and Stryker models you know they will work just fine on light weight foam planes.
Old Dec 30, 2009, 09:37 AM
DaOldGuy's Avatar
Joined Dec 2007
These are heavy / heavier then what I use on most foamies <sub 1 pound>. They do seem to hold a load well and center.
Old Dec 30, 2009, 05:46 PM
littleoak's Avatar
Joined Jan 2009
Thanks for all the advice, I will order the Turnigy 8g or the Parkzone servo's and give them a try. I never had any centering issues with the HXT900's that I have noticed to date, but I will take your advice and switch. I have used them in all my planes and my heli. I have another build in the production line ahead of the Silo, so maybe another couple of weeks before she's up, cause I'll have to wait for the servo's to arrive.
All the best for 2010!
New Product **NEW** Great Planes ElectriFly Riot 3D EP ARF Mandy 3D Flying 261 Sep 22, 2013 05:21 PM
New Product Electrifly E-performance Series Extra 330s 3d Ep Arf Jim T. Graham Product Announcements 2 Jan 24, 2009 01:59 PM
New Product **NEW** Electrifly Riot 3D EP ARF Mandy Product Announcements 0 Aug 07, 2006 12:46 PM
New Product **NEW** Electrifly Reactor 3D EP ARF Mandy Product Announcements 0 Aug 07, 2006 11:37 AM
