Your thought is the coupling is related to the bottom wing needing seperated from the fuse, moved down about an inch, extending the wing struts and having a cabane added below the fuse? |
Latest blog entry: Weak Signals Toledo 2012
One thing I can also point out. Some bipes require you fly all surfaces, to make a smooth turn you need ailerons and rudder to work together. This design is not at all like that, rudder turns will tip the wings and in a lower power the nose will drop. I have to wonder if it is the canted rudder, I may try more a fishtail style rudder and see what happens. Thanks |
No offense taken, I am asking for any suggestions. I dont use the cheap 9 gram servos, I mostly use the Futaba or Hitec since I am very picky about control throws ans centering. Had an issue during the build of the silo with centering, 3D arms caused rods to bind on wood horns. YUCKY
The rudder is a simple blenderm tape hinge, I can change the rudder out very quickly, got EPP foam all over the place. ![]() Any chance the offset of the top and bottom wing could be related since the bottom wing is aft between an inch or 2? |
Lost the silo today. Pretty windy flying, gust twisted her on take off, tried to correct but went down hard. Lesson learned.....
Still had 80 flights and learned so much, so can't really complain, removed all gear from airframe and will be building another in the New Year. Thanks for everyone's help and suggestions, cause now I will make the build a little different and do all the mods from the outset. Try and keep her close to 15oz this time. Cheers Y'all. Andrew |
Dam, Just in time for the after X-mas sales!! ![]() Hey, second time around is better, you can do all the mods from the outset and make it that much better! For me, when i lose an airplane, it is just an excuse to get another one! whether it is the same one or different. ![]() Take care Bro, Mikeeee |
and patch material for the next one. Happy Holidays Guys |
Merry Christmas |
Here is one forsale in Dallas
http://www.rcgroups.com/forums/showthread.php?t=1163871 80 bucks ready to go. |
| Thread Tools | |
| New Product **NEW** Great Planes ElectriFly Riot 3D EP ARF | Mandy | 3D Flying | 259 | Jul 06, 2012 03:44 PM |
| New Product Electrifly E-performance Series Extra 330s 3d Ep Arf | Jim T. Graham | Product Announcements | 2 | Jan 24, 2009 01:59 PM |
| New Product **NEW** Electrifly Riot 3D EP ARF | Mandy | Product Announcements | 0 | Aug 07, 2006 12:46 PM |
| New Product **NEW** Electrifly Reactor 3D EP ARF | Mandy | Product Announcements | 0 | Aug 07, 2006 11:37 AM |
