Old Nov 08, 2009, 05:35 PM
littleoak is offline
Find More Posts by littleoak
Goats & Glocks Eat Anything
littleoak's Avatar
Houston, in the Great State of Texas
Joined Jan 2009
Originally Posted by daoldguy View Post
I may look into the motor you have,
http://www.hobbyking.com/hobbyking/s...idProduct=2112
Just back in stock today. Unlimited vertical on an 11x3.8SF.
Spent today repairing my warbird after a stupidity crash and some great flights on the Aeroworks Stingray. Back to Slow Fly tomorrow.
littleoak is offline Find More Posts by littleoak
Old Nov 08, 2009, 08:05 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
I "Think" this Park 400 will outlast the airframe but you never can tell. The Turnigy motors are good motors, I just wish they would get their stats on the a bit more refined since they tend to slide one way of the other.
I have a Turnigy SK on my Typhoon 2 3D;
TGY AerodriveXp SK Series 35-30 1100Kv / 345w
and it is plenty of motor, but the prop suggestions were off, there is now way to get the WATT output with the suggested prop.
I flew it, the Silo, and the i3D all today, they are 3 different speeds of planes. None of which near as fast as the one you have. Its indoor season, I got to get my slow stuff all tuned up.
DaOldGuy is offline Find More Posts by DaOldGuy
Old Nov 08, 2009, 09:15 PM
vinmech is offline
Find More Posts by vinmech
Old skool speed freak!
vinmech's Avatar
Napa, Ca
Joined May 2004
Hey guys, been following this thread for a while and have picked up quite a few good tips here, and have enjoyed flying my Silhouette immensely. It is an excellent 3d learner ship.
However,......Do a quick preflight next time, especially on those funky wood control horns! My elevator linkage at the stab control horn ripped out the hole and resulted in complete loss of control! Looking at the aftermath(stuffed straight in and obliterated) my other wood control horns were still ok, but the elevator control horn was delaminated around the linkage hole area. It was missing all the wood sandwiched in between the two outside layers!
I was doing a inverted spin blender kinda move when I lost all response to elevator at about 50 feet up! I had time to shut off the throttle before it hit the ground and that was it. In hindsight I was thinking the only way to save it might have been to pull out with throttle and knife edge maybe,.... but then it woulda been a challenging landing, though albeit much less damaging!
Anyway, next one will be even better with carbon fiber horns on it!
I've been running a turnigy 2830 1kv blue/red motor with 25 amp turnigy esc,
turnigy 8 gram servo's, turnigy 1000 mah 3s 15c. futaba 6 ch fasst reciever(the new one) 11-3.8 apc prop. Hovers at half throttle and punches out like I wish all my planes would!! Did the hatch mod with mags( the only time i lost it was when it crashed, but is still usable!lol) Gave up on the wheel spats in favor of collers. They jusy keep breaking off,lol.
Well, if i've prevented one plane from an early demise such as mine, it has been worth the time writing this!
Mikeeee!
vinmech is offline Find More Posts by vinmech
Old Nov 08, 2009, 09:30 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Mikeeee!
Well Mikeeee, I was very lucky <and complained about this a few posts back> that during assembly my Elevator Control Horn started doing the same thing. The problem appears to be that the lazer did not drill through the last layer of the ply fully. When I stuck the z bend through it pealed the last layer outward and then the inner layers just started coming apart. Mine was broke before I finished hooking the rod to the servo. Lawd Dart avoided.
I made repairs to mine and have been monitoring, sounds like a bug in the build too me.
I looked at the Red and Blue version of the 28 30, they are a tad more cash then the Gold ones.
The Spats are just not playing nice. I think it could use a tad talled tires for the ROG and Landing. Other then that, it is WAY to easy to fly, I really like it.
Old Nov 08, 2009, 11:23 PM
vinmech is offline
vinmech's Avatar
Napa, Ca
Joined May 2004
Well Daoldguy,
I read your post about the wood horn,......after the crash......lol.
I was to busy Flyin her to read the posts after I got her together,lol.
The taller lightweight tires are a must, especially when doing harrier landings.
The flaps help out a little too, on Rog. In stock configuration, the plane is sitting level when on the ground, it can't rotate properly to lift off easily.
Taller wheels and flaps if you have them setup ,cures this!
As far as the spats go,........I've got a set of real looking foam wheel pants that came from a Tribute that should look great on the next one!
Mikeeee
Old Nov 09, 2009, 04:41 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Well Daoldguy,
Mikeeee
Isn't that the way it always happens?, after the crash....
Its little quirks are forgivable with all the good stuff it does.
I have yet to see someon who has use the recomended motor <RimFire> on these threads, that motor os low cost compared to a Eflite of Axi, I just wander how it performs.
Old Nov 09, 2009, 05:11 AM
Fast Guy is offline
Find More Posts by Fast Guy
Canada, ON, Thunder Bay District
Joined Apr 2007
I used the Rimfire 28-30-750 because I already had one which is close to the 28-30-950 recomended by the manual. Also used a Castle Thunderbird 18 ans a Hyperion CX 3s 850 25c battery. I had to go to a 12x3.8sf because of the lower kv. It performes very well with this combo. Check out the video I posted of the Silhouette on floats on page 6 of this thread.
http://www.rcgroups.com/forums/showt...ast+guy&page=6
Fast Guy is offline Find More Posts by Fast Guy
Old Nov 09, 2009, 05:31 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
[QUOTE=Fast Guy;13539052]I used the Rimfire 28-30-750 because I already had one which is close to the 28-30-950 recomended by the manual. Also used a Castle Thunderbird 18 ans a Hyperion CX 3s 850 25c battery. I had to go to a 12x3.8sf because of the lower kv. It performes very well with this combo. Check out the video I posted of the Silhouette on floats on page 6 of this thread.
Ah...I remember that video well, nice work btw. Yes, the 750 would provide more byte, nothing wrong with that at all. It handles those floats very well.
Old Nov 09, 2009, 06:12 PM
littleoak's Avatar
Joined Jan 2009
Checked the power on the Turnigy 28-30b. Static WOT was 200W @ 18a with an APC 11x3.8SF prop and 30c pack. That's some serious punch!
Old Nov 09, 2009, 08:45 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
I dont trust their numbers 100%, but when you compare them to like motors, these are somewhat in the ball park.
Model: TR2830-1050
Max Eff: 12A>>>>> Peak efficency is at 12 amps times 11 volts which is 132 Watts, this would be the longest flight times if their numbers are accurate.
Max Load: 14A>>>> Max amps of 14 times 11 volts 154 Watts. This is the typical range for the size and style motor to put out.
Kv: 1050
Weight: 57.9gr
Pull: 400~900gr
Prop: 10x5 or 10x6
Voltage: 6~10v>>>>> 3S lipos are 11.1 volts so 10 volts is odd.
No Load Curr: .9A
30C, now that is some battery for a foamie. I have one 25C for a small balsa project this winter.
Old Nov 09, 2009, 09:03 PM
littleoak's Avatar
Joined Jan 2009
Maybe not clear, those numbers were my readings on my meter connected to the silhouette. The 11x3.8 prop is overpowering the motor (15A rating), but given that my test is static, then in flight I will not be nearing that, except in short bursts perhaps pulling out of a hover etc.
Old Nov 09, 2009, 09:08 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Oh..No question, with that power and throttle management, those higher numbers would seldom be needed. I was more questioning how they <HC> is inconsistant with their numbers.
Reading the feedback "helps" get an idea how the motors run out <often they fall short>, but your static tests shows the motor is more then capable of delivering....And then some.
Old Nov 09, 2009, 10:04 PM
vinmech is offline
vinmech's Avatar
Napa, Ca
Joined May 2004
I never did put a watt meter on it, even though i have one. Guess i just had no reason to. 25 amp esc and the 15 c batt and motor were just barely warm after a 9-10 minute flight of mild 3d!
When I get the time I'll put the meter on it and let you know what it is.
My guess is about 130 watts or so.
Regardless, reinforce the firewall with low temp hot glue!!!
Old Nov 10, 2009, 04:52 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Wise words Between littleoak and just looking at how the firewall was made.... I had the hot glue gun out from the start.
Old Nov 10, 2009, 03:36 PM
littleoak's Avatar
Joined Jan 2009
Hot glued around the motor mount this morning and flew 3 packs at lunch. No problems, but I did decide to gently land in nice soft knee length grass, which gave me no issues.
Great flights in 10-15mph winds, maybe the slightly bigger pack helps with stability here. I still have the 750's for when conditions are calmer.
Rolling circles and harriers were a blast heading into the steady breeze.
New Product **NEW** Great Planes ElectriFly Riot 3D EP ARF Mandy 3D Flying 261 Sep 22, 2013 05:21 PM
New Product Electrifly E-performance Series Extra 330s 3d Ep Arf Jim T. Graham Product Announcements 2 Jan 24, 2009 01:59 PM
New Product **NEW** Electrifly Riot 3D EP ARF Mandy Product Announcements 0 Aug 07, 2006 12:46 PM
New Product **NEW** Electrifly Reactor 3D EP ARF Mandy Product Announcements 0 Aug 07, 2006 11:37 AM
