Old Jun 24, 2009, 05:37 AM
Rcmeca is offline
Find More Posts by Rcmeca
Rcmeca's Avatar
Sydney , Australia
Joined Sep 2006
Congradulations on your maiden flights , I have had my eye on this model for a while,wanting a Mustang with retracts ,the EP Phoenix P51 doesn't have retracts . I was waiting for someone to do an electric conversion of this model.Thanks for sharing your building experiences , I now feel confident in buying one.Happy Fying regards Rcmeca.
Rcmeca is offline Find More Posts by Rcmeca
Old Jun 24, 2009, 06:13 AM
GOK is offline
GOK
Find More Posts by GOK
GOK
Turkey, Izmir
Joined Aug 2005
Rcmeca,
I'm glad this thread has been useful for some one.
The build and conversion with this bird was pretty straight forward. The model is not the most scale looking P-51 out there but still looks damn good in air. Maybe a coat of mat varnish would help the ugly non-WWII warbird shine as well.
The pros of the model IMHO are
- Can be built light for its size (5.5-6 lb)
- Retracts (They are metal, easily adjusted and are quite durable)
- The build is easy and the conversion is straight forward
- Has good flight characteristics (not a trainer but neither a tip stall monster, goes where you point it)
- Looks really good in the air
- The quality of the kit was more than satisfatory but you might want to check the factory glue in critical points (read firewall)
Cons:
- Not very scale (I was particularly bothered by the thin ailerons spanning mostly the whole wing, and the tailwheel not being located where it actually should be)
- No flaps
- Dodgy looking pilot
- Dodgy looking wheels -I am not sure what they are called but the kit did not included the rectengular-like plaques that cover the LG wires.
Anyways, I hope you enjoy your P-51 as much as I have been enjoying mine
Cheers,
GOK
GOK is offline Find More Posts by GOK
Old Jun 01, 2010, 03:39 PM
GOK is offline
GOK
GOK
Turkey, Izmir
Joined Aug 2005
It's nearly been a year since I've completed and started flying this model, and finally I have had a photographer friend take some beautiful in-flight photos of the model.
By the way, she is a fantastic flyer, the retracts are still hanging in there with no issues, haven't had any mishaps with this model and the power setup has proven to be just great for my sort of scale flying.
Enjoy the photos
Old Jun 04, 2010, 09:54 PM
1st timer is offline
Find More Posts by 1st timer
Inverted tail dragger
1st timer's Avatar
Australia, WA, Kalamunda
Nice looking plane GOK.
I've been looking at this one for a while now ..but was not sure,but after seeing your blog on this aircraft i'm a lot more closer to getting this plane.
Thanks again
Jeff
1st timer is offline Find More Posts by 1st timer
Old Jun 08, 2010, 10:42 AM
ezrydr is offline
Find More Posts by ezrydr
what goes up...
ezrydr's Avatar
Alton Iowa
Joined Aug 2006
wow - nice photos!
ezrydr is offline Find More Posts by ezrydr
Old Jun 13, 2010, 02:33 AM
GOK is offline
GOK
GOK
Turkey, Izmir
Joined Aug 2005
Below is a link to a video of my P51.
Enjoy,
GOK
Gokcen's p-51 mustang (2 min 9 sec)
Old Mar 19, 2013, 03:28 AM
Watdazit is offline
Find More Posts by Watdazit
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
This thread is very old and I hope someone flying one of these Mustangs is paying attention. I have a problem with the COG. The manual says the COG should be 105mm back from the leading edge of the wing at the fuselage. This appears to be wrong. As one will know with the Mustang there is a triangular section extending out the front of the wing at the fuselage. If I measure 105mm from where this triangular meets the fuselage and try a COG balance I have to put over 200 grams of lead behind the firewall. Should this 105mm be from a line of the leading edge of the main part of the wing extended to the fuselage? That being the case I have to put 140 grams of lead in the tail.
Watdazit is offline Find More Posts by Watdazit
Old Mar 20, 2013, 01:17 PM
ucarkus is offline
Find More Posts by ucarkus
Denmark, Capital Region of Denmark, KBH
Joined Aug 2009
I don't have this one but have a H9 40 size P-51 which is marginally larger than this and it balances @ 120mm measured at the wing root, so, 105 mm does not sound way off to me. I think you might consider to move the battery forward as seen in the previous posts.
ucarkus is offline Find More Posts by ucarkus
Old Mar 20, 2013, 05:22 PM
Watdazit is offline
A geriatric flier
Watdazit's Avatar
Joined Nov 2008
Thanks for that Ucarkus. It appears Phoenoix did change the design layout a bit as my wings are in two sections which bolt on from the side whereas the one in the photos bolt on in one piece from below. I have the battery as far forward as I can go without removing the motor box and rebuilding it. At 105mm it is nowhere near the 1/3rd rule of thumb position for the CoG. 140mm is closer. I think the triangular section of wing at the root confuses the matter. If I set up at 105mmm or even 120mm the plane feels very nose heavy. I am not willing at this stage to do a test flight until I am sure it is about right. By the way the difference in balance 105mm to 120mm will be quite noticeable. It does not sound much. I will do some more more tests and posts some photos.I might get someone who has a Pheonix P51 speak up.
Old Jul 24, 2013, 10:59 AM
Dee Double You is offline
Find More Posts by Dee Double You
Joined Jul 2013
I have a very similar electric set up that came out of another air frame which i recently converted to glow. I was running the NTM 3546 900 kv which is rated at 810 watt output. I cant remember the exact specs but with a 13 x 8 apc prop it was delivering just above 700 watts on 4 cell. I have had my eye on this particular model for a while and have ordered one recently. I noticed that on the phoenix website the wingspan spec is slightly larger, perhaps they made a mistake or maybe its an improvement. The retracts look different too. Anyway, thanks for all your build tips im sure they will come in handy. Im looking forward to getting this bird up.
Dee Double You is offline Find More Posts by Dee Double You
Old Sep 08, 2013, 06:59 AM
Kennyglide is offline
Find More Posts by Kennyglide
Southern Darling Downs Qld, Australia
Joined Sep 2010
Hi , could anyone tell me if i could fit a OS65ax all up weight of 653g into a Phoenix Mustang P51 1420mm w/span ( PH068)ARF.... i have already removed the 3.5 oz of lead from behind the mounting box but have still to buy the motor... it is designed for a ..46 2stroke or. 52 4stroke ...... there is an overall weight difference of 77g from the .46 to the 65ax after factoring in the 3.5 oz of lead i removed. Is It tail heavy with an OS55ax? I am still in beginning of this build so any info would be greatfully appreciated... Regards Ken
Kennyglide is offline Find More Posts by Kennyglide
Old Sep 30, 2013, 07:29 PM
zulmr2 is offline
Find More Posts by zulmr2
Crazy about RC
zulmr2's Avatar
Kuala Lumpur
Joined Mar 2009
Good day,
Watdazit,
I believed you have maidened your Mustang by now. Care to share your CG sweet spot for us here.. I am still a bit puzzled with the manufacturer's CG recommendation. It just doesn't look quite right. Between 130mm to 140mm looks right to me if measured from the leading edge wing root at the fuselage.
*Phoenix P51 owners- Please share your experience too.
Thanks in advance!
zulmr2 is offline Find More Posts by zulmr2
Discussion Alfa model p-51 mustang "balloning" effect?? DeuUaH Electric Warbirds 50 Jun 04, 2007 09:49 AM
Discussion P-51 Mustang by Model Tech skaiwaaker Fuel Warbirds 4 May 02, 2006 11:40 PM
P-51 Mustang Herr Engineering New!!! In Box!!! karl446 Aircraft - Electric - Airplanes (FS/W) 4 Oct 19, 2001 11:46 AM
ModelTech PSS conversion ( P-51 Mustang) bibblebum Scale Kit/Scratch Built 6 Jul 03, 2001 03:30 AM
Help!.. Robbe Shulter P-51 Mustang tic Scale Kit/Scratch Built 8 Jun 14, 2001 07:56 PM
