Amelia Island, Flrida.
Joined Sep 2007
Scale firing cannons and carronades.
What a coincidence, two approaches to scale firing guns. CANNONS The resin cannons supplied with the Surprise kit are cut roughly in half, just at the reinforcing strap. The inner piece s drilled 3/8, and a slot cut in to allow for the wires. The outer piece is replaced with a replica machined from brass. The bore is 5/32, then 3/16 and lastly glow plug tapping drill size. The inner end is tapped for a glow plug. The assembled cannon is front heavy. A support bar is glued to the front of the carriage to hold the cannon horizontal. The carriage is now front heavy so a 1/4 square piece of brass is glued to the underside of the carriage at the inboard end. Female Deans 2 pin plugs are glued at the bottom of the carriage. Wires lead from the plug, one to a"C" clip that fits the glow plug base, the other to a piece of tubing attached to the center connection. CARRONADE The end cap of the carronade is cut off and retained. A 1/4 inch piece of 1/2 inch dowel is drilled 1/4 and glued to the end cap. The dowel is then slotted to allow for the wires. A replica of the carronade is machined from brass. It is drilled glow plug tapping size, tapped, and a glow plug inserted. The carronade is front heavy, just like the cannon. A 2-56 S.S. screw is added to the front of the carriage to hold up the barrel. This is one of the electrical connections. A clip that attaches to this connection is soldered to one of the wires.The other wire is soldered to a piece of tubing for the center post, just like the cannon. A 2 pin Deans plug is glued to the bottom of the carriage. Most of these ideas came from Danl. I may change to his new firing system as soon as it is fully debugged. I will also use Danl's firing system of a slow servo rotating over contacts.
Scale blocks - sourcing for larger scales
CORRECTION - Feb 2010
JB MODEL informed me that they now have larger sized block and deadeyes. They have also added a cheek groove in the blocks for easier rigging. See their website (shown below) for more info. Here are some sources of confirmed good looking scale non-working blocks. Many sources are cast metal or really shabby boxwood blobs. The following are really nice looking. Warner Woods No website. Ask for price sheet at warwoods @ infowest.com (note the spaces after warwoods and before infowest) JB Model (http://www.jbmodel.eu/product_info.p...roducts_id/605) Arch Navalis http://arch.navalis.pl/index.php/cPath/169_191_233 The largest available from the above are 7-8mm, too small for the larger block sizes neede for 1/24 models. I have communicated with Jarek at Arch Navalis, He may make larger blocks if there is enough demand. Please let me know by a post here if you would be intersted and I'll follow up. He makes up to 8mm now. I'm thinking of asking for 9, 10, 11 and 12mm singles, and 10 and 12mm doubles and triples. Thanks, Dan |
Dan: Thanks for the photos, I am in the process of rigging Surprise as you have it shown here.
I finished the forecourse yard today and the sail maker spent the day in the sail loft sewing up the sails. They are all ready to go. I have also rerigged the stuns'l yards on this new yard and I plan to go ahead with a similar installation on the main course yard. I want to retain the removable stuns'ls and yards on the rest of the ship in case the winds are light and I am intending to sail down wind. I have also rerigged the foretop sail sheets to something similar to what you did on Syren. I have attached the small eye on the back third of the yard and ran the sheet down through the eye on the end of the yard (I someday may invest in blocks but they are not a priority right now) and up to the bolt rope on the foretop sail. I do not have a lathe so I used a belt sander and a cordless drill to 'turn' the ends of the yards. It is not necessary to chuck the yard in tight but it does have to be snug. Set the end you want to turn down on the belt sander with both the drill and sander running and it turns down the ends nicely. You have to wear gloves because the dowel gets HOT and also to keep from sanding your fingers off plus it is only 10 degrees here today. I used a router to make the octagon (8 Lands) center area of the new yards. Just set it up with a straight router bit, set the fence to take off the amount that would equal each of the 8 lands, and run it through. Mine turned out equal and a nice touch to an otherwise dull looking tree trunk yard that I made before.
New forecourse and maincourse sail rigging
Shipmates: I have completed the new main and fore course sail rigging. Here are a few photos.
Now I just have to wait for some weather to try them out but with the use of the fan in the drydock I think they will work fine. Trev--if you rig your main course in a similar fashion you need to remember to put some clips in on the end of the sheets so that sail can be struck if necessary. I have never had to strike the forecourse sail so I did not bother with putting clips on those clews. ![]() I have not yet rigged a wire and loop to run the sheets through to keep them from getting blown away when I fire on Syren. The gun fight is just a few months away now. Stay tuned!
| Thread Tools | |
| any good how to books for r/c helis? | adam_jorgensen | Electric Heli Talk | 4 | Mar 31, 2002 11:05 AM |
| Moderators needed for R/C Groups! | Andy W | Electric Plane Talk | 1 | Mar 21, 2002 05:44 AM |
| Pull/Pull System for r/c | Patrick in WI | Electric Plane Talk | 4 | Mar 18, 2002 01:18 PM |
| Rechargeable Alkaline batteries good for R/C packs??? | TopGun | Power Systems | 2 | Sep 27, 2001 11:03 PM |
