servo size. beginner boat.
Thoughts on servos - Squaresails can get by with smaller servos than fore&aft sails require. Squaresails are balanced, to some extent, in a way completely foreign to fore&aft sails. Every time you haul a brace on a squaresail, needing to fight the wind forces, you are slackening a brace on the other end of the yard, and the wind forces on this half of the sail help you (and the servo). For example, my 3 ft hull barque uses Hitech's micro servo HS-82mg for braces. But the same servo is overpowered by my 1 ft hull sandbagger's fore&aft mainsail. btw, good shiphandling can allievate the forces on sails, both square and fore&aft, allowing men (and servos) some relief during a heavy haul. Spilling the wind from sails, usually by heading up, will allow overpowered servos to do their job.
This observation on servo size applies to those used in the "parallagram" bracing method. I can't comment, from experience, on winch-type servos. The balancing still exists, but servo current draws reported suggest those boats are needing lots more power than mine. They are bigger boats than mine; so, if you have a boat big enough for winches, maybe you are better off getting the strongest you can afford. Thoughts on dipping your toes in - A topsail schooner is an easy way for a sloop skipper to get some squaresail and multimast practice. The fore&aft sails of the schooner will allow good progress to windward (keeping you off the ever-pesky leeshore). The square topsails allow one to experiment with bracing on all points of the compass. They also allow experimentation with boat heading changes via backwinding the squares. The 2 masts allow you to practice balancing forces, between the masts, to achieve course desired, a mandatory skill, I would say, for the accomplished square-rigger skipper. My bottleboat topsail schooner only took a week to build. Topsail schooner bottle boat: http://www.rcgroups.com/forums/showt...9#post12548314 |
Real Brace Winches
Square Rigged is a site about real square rigged sailing. Click on Jarvis under the seagull for a very nice thesis on the Jarvis Patent Brace Winch. It's full of geometry for bracing winches using conical winch drums - on real ships - much of wich can translate to model square riggers.
Brace Travel, Yard Rotation Calculator
For calculating circle related geometry, this calculator is excellent because it calculates chords and central angles, giving good approximations of the straight line pull rewuired on a yard to rotate it thru a specific angle.
http://www.1728.com/circsect.htm An example is how much brace travel is necessary to rotate a 27" yard (distance between points of brace connections) thru 50 degrees (100 degrees total for both directions). Plugging in radius (13.5") and central angle of 100 degrees gives a chord of 20.7". The servo drum diameter can now be calculated. If the servo has 3.5 rotations, then the diameter of the drum needs to be a minimum of: 20.7 / 3.14 / 3.5 = 1.88" Always allow for extar pull length to make up for line stretch, other angles in the brace geometry and because a chord is only a close approximation of the line of travel. |
Servos for use on larger square rigger models
Servocity.com has an excellent selection of strong servos and robotic servo/gearbox combinations. They have a wide range of power, rotation options, etc etc and their website has excellent documentation and specification info. If you have any questions about an application, you can call them and you actually get very good tech support.
The servos aren't cheap, but I really think (but not sure) that their prices are as good as other internet sites and lower than a hobby shop. (I support buying from the local shop, but the range os specific options, etc and the super tech support/info make servo city my favorite source of specialty servos.) On each page for the specific servos, look for the little yellow information balloons, eg "How to select a servo" or "how servos work". Great info. Specific applications: For a Soling 50, 800 sq in of sail, I use this Robotzone servo/gearbox, with the 3:1 gearing option. I use about 160 deg of rotation for full sail control, but you can order a gearbox with as much max rotation as you need (just call them to work out the options): http://www.servocity.com/html/spg785a_top_mount.html For the brig Syren (5ft hull, 12 sq ft sail overall), I use the following servos: Mainmast and foremast sails, headsails - each uses a HS 785HB servo with 3.5 rotations (programmable to 4 full rotations with a Spektrum) and custom winch drums made from old CD's, etc: http://www.servocity.com/html/hs-785...rotations.html For driver sail - HS 805BB with the 180 deg option: http://www.servocity.com/html/hs-805bb_mega_power.html For 140deg rotation, there is the 815BB (same as the 805, but with 140 as std rotation). For the same $$'s, I"d get the 805 with 180deg for the extra rotation - why not? http://www.servocity.com/html/hs-815..._sail_arm.html Many of their servos can be ordered with either 60, 90, 140 180 and continuous rotation options. And the servo/gearbox "Robotzone" options are almost limitless. They also sell servo arms , drums, gears, chains, etc etc. Look through the spec tables and pretty soon you get an idea of what's what. Then call tech support for your app and they can zero you in on options. I know this sounds like a commercial, but they give great service, fast delivery and stand behind their products. |
Servos for large square rigger or similar models - part 2
Looking at the SevoCity Robotzone gearboxes, see the following links for what are likely the better servos to use for drum winches.
http://www.servocity.com/html/robotzone_servos.html http://www.servocity.com/html/tube_s...gearboxes.html http://www.servocity.com/html/bottom...wer_gearb.html For use in large sail area models, the above gearbox/servos are likely better than the 785HB's I'm currently using (The 785HB has one ball bearing, a brass bushing, and Karbonite gears.) The above have dual precision ball bearings, hardened SS shaft, precision mil spec pot, optional metal gearbox gears, the servos have metal gears and ball bearings, and the units are rated for 200lbs lateral load. And they are coming soon in a new "square tube" frame design that looks spectacular for secure mounting low in the hull along the keel. One specific unit has very high torque and 4 full rotations - should be ideal as a drum winch unit: http://www.servocity.com/html/spg805...-rotation.html |
Keel Calculation
Keel calculations method (depth and weight needed), post#9
http://www.rcgroups.com/forums/showthread.php?t=1096365 |
Web list of RC squareriggers
Jan Cocatre-Zilgien has compiled a list, with urls, of all the RC squareriggers he can find on the web.
http://www.cocatrez.net/Water/RC_Squ...reRiggers.html Neville Wade, who has several squarerigger articles in Marine Modelling International magazine, has 2 diagrams of his brace controls and photos of his yard hangers on Jan's website (along with photos of his beautiful models). Scroll down Jan's list till you get to Neville's name. |
Washington State
Joined Sep 2007
Thought I would include this link for technical back ground.
The element and practice of Rigging and Seamanship of 1794 Quit a Bit of information here. http://www.hnsa.org/doc/steel/index.htm Very nice Site you have going Dan, I am gonna have to make a set up for making Rope. |
| Thread Tools | |
| any good how to books for r/c helis? | adam_jorgensen | Electric Heli Talk | 4 | Mar 31, 2002 11:05 AM |
| Moderators needed for R/C Groups! | Andy W | Electric Plane Talk | 1 | Mar 21, 2002 05:44 AM |
| Pull/Pull System for r/c | Patrick in WI | Electric Plane Talk | 4 | Mar 18, 2002 01:18 PM |
| Rechargeable Alkaline batteries good for R/C packs??? | TopGun | Power Systems | 2 | Sep 27, 2001 11:03 PM |
