That last one looks like it ends up being an over engineered version of simple springs - like I'm using in Constellation.
Maintaining tension isn't difficult to set-up, especially in larger models using rubber, springs, weights, or cones (Jarvis winch), A little slack won't hurt anything so long as you consider it in your set-up - running things so that slack isn't a potential problem. On the real boats, the hands on the cast-off braces let them run. One person will be there to watch for snags, and then take up slack and belay when each yard is set. To replicate that you need the off-side winch to be free-wheeling with a little friction to let the braces out - then you need it to become rigid when its it's turn to haul braces in. What you want is something like this YouTube thing, but that reverses the "rigid" and "sprung" drums when bracing the other way.
All that is multiplied where you're controlling multiple yards per mast. They each have their own geometry, and the larger the model, the more yards should be actively controlled - course and tops'l yards at the very least. |
Hey guys! Been traveling - just home and saw this.
If starting from scratch, I believe a very good (robust and simple) design is to use a spring-loaded sliding servo. Worked very well on a board mock-up. I was planning to re-engineer Syren, but to make room for the slide travel would require a major demolition of the existing mechanicals. Here are reference posts: http://www.rcgroups.com/forums/showp...&postcount=131 http://www.rcgroups.com/forums/showp...&postcount=139 http://www.rcgroups.com/forums/showp...&postcount=142 http://www.rcgroups.com/forums/showp...&postcount=144 |
Scale Rigging Line - Excellent Source
Pondsailor and others now building SC&H brigs have asked about rigging material. I twisted all mine on a ropewalk, but then learned of an excellent commercial - and super-cheap - source: memphis Net and Twine.
Check out the following two posts I made earlier covering the source, sizing for different scales, etc. http://www.rcgroups.com/forums/showp...&postcount=109 http://www.rcgroups.com/forums/showp...&postcount=110 Also, teh PDF showing the sizes of twine available and the scale sizing. |
External Drive Motors for 1/24 scale RC Sailing Ships
Have been asked about the external "drive pods"
Some detail in this old post, and some pictures too. http://www.rcgroups.com/forums/showp...&postcount=747 The latest, final design was simple - PVC pipe endcaps were epoxied over the two ends of the motor. One cap sealed the open end of the motor. The other cap was drilled for a model submarine shaft seal. The wires were passed through a hole in the endcap and also sealed with epoxy. No water gets to the motor. The motors I used were from a surplus store. They are made by Faulhaber. Dimensions approx. 25mmD x 50mmL. They are sealed motors and run with very low current (they are high efficiency). Here is the Faulhaber motor product page: http://www.faulhaber.com/servlet/com...66/i86089.html The drive shaft seals are from a RC submarine parts supplier: Mikes' Subworks. http://www.mikessubworks.com/page1.html |
Carronade Information
Pics of 32 pounder carronade on Brig Niagara, an accurate replication of a brig from the War of 1812. It's a working carronade.
Also pics of a 1/12 scale model I built from the pics and measurements when onboard Niagara. Short clip of the model carronade firing its black powder charge. The clip:
| Thread Tools | |
| any good how to books for r/c helis? | adam_jorgensen | Electric Heli Talk | 4 | Mar 31, 2002 11:05 AM |
| Moderators needed for R/C Groups! | Andy W | Electric Plane Talk | 1 | Mar 21, 2002 05:44 AM |
| Pull/Pull System for r/c | Patrick in WI | Electric Plane Talk | 4 | Mar 18, 2002 01:18 PM |
| Rechargeable Alkaline batteries good for R/C packs??? | TopGun | Power Systems | 2 | Sep 27, 2001 11:03 PM |
