Old Jul 26, 2001, 02:06 AM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
Best servos for the Sig Rascal?
Hey everyone!
HAd my dad pick up the Rascal ARF in violet the other day so hed have something sweet to fly at the schoolyard. Plus it means I get to build and test it =0)
My question is, what servos are best suited? They suggest Hitec HS55s...that just seems too small to me! BUT, going to HS 81s means I have to cut the openings out and add almost 3/5 ounces of weight and hassle. Ive got a pair of JR 241s....same weight and size as the 55s, but a little more torque. Is 17 ounces of torque enough for this plane when itll be flown at times looping and rolling? Ive actually got a pair of CS21s I could go with too....whatcha guys think? JR 241s, Cirrus CS-21BBs or Hitec HS-81s?
Thanks guys!
Jason
Jason M is offline Find More Posts by Jason M
Old Jul 26, 2001, 08:08 AM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
I'm putting HS55s in mine, but I haven't finished or flown it yet. The HS55s are plenty strong for the X-250 - they should be fine in the Rascal. My only reservation is the tail wheel/skid, but we'll see.
If I were you, I'd go with the JR 241s - 17 oz should be more than enough and the Rascal begs to be kept light.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Jul 26, 2001, 08:31 AM
Frank Hurd is online now
Find More Posts by Frank Hurd
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
Jason, the 241's are the best sub micros that I've found. Would you believe that I'm using two for ailerons on my Fun 700 10 cell Endo powered plane? The reason that I'm not using all 241's is that the tail wheel is steerable and attached to the rudder and the weight and the rough field that I fly from may strip the gears. On the Rascal, you don't have to worry, just go ahead and enjoy.
Frank Hurd is online now Find More Posts by Frank Hurd
Old Jul 27, 2001, 12:09 AM
Rod is offline
Rod
Find More Posts by Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
I fly my Rascal with HS-55's and they have enough power for this model. Mine weighs 25 oz. with a Speed 400 6 volt, a 2:1 gear box and an APC 9 x 6 (electric prop), on 7 cells.
Rod is offline Find More Posts by Rod
Old Jul 27, 2001, 05:00 AM
RICKinFL is offline
Find More Posts by RICKinFL
Palm Bay ,FL. USA
Joined Jul 2001
Hi folks This is my first post and I'm still relitivly new at flying models. I have been practicing with a Hitech Sky Scooter. I just purchased the ARF Rascal last night and will be using the the Hitech radio components with hs 55 servos Hope I made a good choice for my second plane Any advice would be much apreciated...Rick
RICKinFL is offline Find More Posts by RICKinFL
Old Jul 27, 2001, 03:05 PM
quintav02 is offline
Find More Posts by quintav02
Rosepine, La.
Joined Jan 2001
Using HS-81MG's on mine,should be adequate.
quintav02 is offline Find More Posts by quintav02
Old Jul 27, 2001, 11:33 PM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
The 55's will work great. You don't need anything bigger on that plane. Rudder/Elevator torque requirements on a Rascal are very small even for loops and rudder rolls.
Regards,
Jeff
http://home.earthlink.net/~jsmeyers/index.html
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Jul 28, 2001, 03:23 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Welcome to the Ezone Rick! Those servos should be fine. I use smaller ones than that it my 93 MPH pylon racer without any problems.
GregG is offline Find More Posts by GregG
Question Best price for Sig Rascal 110 yaha-tinda Hot Online Deals 3 Dec 27, 2006 03:37 PM
Best Li-Poly setup for Sig Rascal 400? Tlh Batteries and Chargers 2 Apr 13, 2004 11:55 PM
What is the absolute best setup for the SIG Rascal, plain and simple... e-sailpilot86 Sport Planes 2 Jul 23, 2002 08:18 AM
Best Servos for HLG? rlt55 Electric Sailplanes 1 Oct 27, 2001 01:08 PM
WTB: Wheel pants for Sig Rascal! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2001 01:55 AM
