RocketJoe,
StealthWorkx, thanks for the RCV922 update. I suspect that this is something we can fix easily, as long as we can get it reproed. I have ordered an RCV922. Hopefully the circuitry/firmware in the one I ordered is not different than the one you have. |
RE: Bill
If the panning is not correct when the flight sim is being used, assuming the telemetry light is blinking and the simulated plane is flying around in circles, I think the problem is your pan calibration. If the problem persists, I'd recommend the "Reset pan/tilt" option under the pan/tilt calibration, and recalculating the pan and tilt. I'd calibrate 270, 90, 0, and then click "finalize pan angles" and then calibrate tilt. OK ill try it again...let you know wattz up then..tkx |
Have a good one, Rob |
I see readymaderc have the $89 OSD Pro Expander but I also see the they have the 10Hz GPS Expander Module for $79. http://readymaderc.com/store/index.p...5937dc9184aab7 This is what I was going to get but I also see a combined unit OSD Pro Pkg with 100A eLogger/Integrated Connectors and GPS for $239. Will the cheaper stuff do or is the $239 one better remembering I have the elogger 3. I see DPC.AF have the EagleEyes but there must be somewhere that has all the stuff? Thanks |
Hey guys,
A while back some people were talking about shorter a/v cables and that there didn't seem to be much available. Well, I made an investment and had some quality cables with right angle connectors custom made. ![]() http://readymaderc.com/store/index.p...roducts_id=211 Although I had asked for 15", they messed up the order and gave me 12". Well, it turns out that 12" works perfectly on my pan/tilt setup and the Eagle Eyes. I still am ordering some slightly longer ones for people that want to use them with their own pan/tilt setups and the Eagle Eyes (40cm (15.6")instead of 30cm(12")). |
Solihull, England
Joined Jun 2004
Peter |
Later; D.W. |
Central Connecticut
Joined Jan 2010
I am guessing that Peter is indeed referring to the braided outer conductor, the shield.
Here's a snippet from Wikipedia's page on ground loops: Quote:
France
Joined Sep 2009
Good news Tim !
J'ai essayé un câble plus court possible avec un angle et c'est ce que j'ai trouvé! here it's my station : My next order will these cables when you receive your tx 1.3 GHz (for a second station) ++ |
Solihull, England
Joined Jun 2004
Peter |
Mr. Pibb and fjnetcom, What exactly are the LC filters feeding in your setups? I do not have any filters at my base station, but I have been wondering about adding some.
| Thread Tools | |
| Build Log My home made FPV system: OSD+diversity+telemetry+tracking antenna+autopilot+IMU+PC | Zbig | Video Piloting (FPV/RPV) | 102 | Sep 25, 2011 01:15 AM |
| Discussion Eagle Tree GPS unit, live tracking? | JustinONE | Video Piloting (FPV/RPV) | 10 | Jan 11, 2009 03:27 PM |
| FS: Eagle Tree Systems RC Car Data Recorder | hankster | Cars - Cars and Parts (FS/W) | 0 | Dec 27, 2003 09:50 AM |
| New USB data logger accessories and Holiday specials from Eagle Tree Systems | billpa | Product Announcements | 0 | Nov 08, 2003 12:51 PM |
