Old Jul 19, 2012, 12:07 PM
Joined Dec 2008
I was trying to set up Eagle Eyes using my radio and via the usb cable. Both. I left the plane outside to have gps signal but nothing happened again. When the pan angle is changing there is no servo moving. Only a buzzing noise inside the servo. I try many type of servo like 360 rotation and standard too!!! Nothing happened. I sent a message to Bill Parry days ago but no responce yet. Only once the servo saw moving.
Originally Posted by N485TG View Post
So you have everything hooked up and your getting signal from the Sats as well as getting video on your monitor.... And how are you trying to setup your Eagle Eyes? I did mine threw USB on the computer connected to the V4 vs the TX for the plane.
billybo is offline Find More Posts by billybo
Old Jul 19, 2012, 12:29 PM
United States, OR, Medford
Joined Nov 2011
ummmm i know for me once i got video signal to the Eagle Eyes with the GPS I got it working but it did take me a lil bit to play with it first to get it working though. Im not sure how much more i can be of help. Maybe try readying from Post 1 and go from there maybe some of the other posts can help. Sorry I wasnt able to help. Best of luck to you. Maybe even try emailing Eagle Tree as well......
N485TG is offline Find More Posts by N485TG
Old Jul 19, 2012, 08:21 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
billybo,
I wonder if you are thinking like I was at first.
The EE is only as smart as it is trained.
It does not recognize the servo positions until you tell it where the positions are.
You need to power everything up, and have EE and the OSD plugged into the computer. Then you need to move the servos intp position by choosing + & - in the computer program .
After the antenna is in the position that you desire for the angle that you are setting, you hit save.
Go through each angle and set them accordingly, then do it for maximum and minimum tilt.
be sure to save each setting, then you can test it in the flight simulator to make sure that it is following the plane in the simulator.
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Jul 20, 2012, 02:06 AM
Joined Nov 2011
Originally Posted by m_beeson View Post
billybo,
-Mike
TY you, you explained on how to do it alot better then I did
Old Jul 20, 2012, 01:07 PM
Joined Dec 2008
Thanks guys!!!!!
I will try to callibrate on that way!!!!!! EE and OSD connected with the pc during the callibration. Greetings from Greece!!!
Old Jul 21, 2012, 01:03 AM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by billybo View Post
Thanks guys!!!!!
billybo,
FWIW, I blow a fan across my VTx while I am calibrating so it doesn't over heat.
This way you can leave it transmitting for an extended period of time if needed.
-Mike
Old Jul 29, 2012, 04:12 PM
kreu01
Joined Oct 2008
Hy Bill.
Any way to record the telemetry on SD card ?
kreu01 is offline Find More Posts by kreu01
Old Aug 01, 2012, 06:40 PM
billpa's Avatar
Joined Nov 2003
Hi Kreu, we have not completed the firmware to support telemetry logging to SD card, but that is still in our plans. Sorry it is taking so long!
billpa is offline Find More Posts by billpa
Site Sponsor
Old Aug 02, 2012, 05:37 AM
kreu01
Joined Oct 2008
No Problem Billpa.
I am waiting anxious.
Old Aug 08, 2012, 02:11 AM
Aviation industry participant
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Hi Guys,
I set up and flew my EE groundstation using the diversity function for the first time today. Dead simple really. Update the firmware, plug in power and receivers, and off I go.
One question as this is the first time I've used a diversity setup, how do you know which receiver is in use at a particular time? I'd love to have an on-screen display option to depict this, or even a "beep" low or high to tell me which is active. Is this possible? Would many find this useful?
Sub
subsonic is offline Find More Posts by subsonic
Old Aug 08, 2012, 02:23 AM
eroeder's Avatar
United States, HI, Kailua
Joined Jan 2004
There is a setting to do diversity beeps in one of the menus I believe. I was reading about it tonight in the manual.
eroeder is offline Find More Posts by eroeder
Old Aug 08, 2012, 02:59 AM
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Sub
This is on the future list of Bill.
But so far you could change the volume on input/channel 2 with the pot.
mr..speed is offline Find More Posts by mr..speed
Old Aug 08, 2012, 08:39 PM
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Got the beeps working today. I was looking for an option in the PC setup screen, but should have read the manual that says to use the OSD menus. Sorry about that
In the end I used the volume change method mentioned above, and it works, but is a bit of a work around.
Anyway, I'd still like a feature that tells me which receiver is active. Something like a double beep for antenna two, or a high / low beep. I find it pretty hard to hear the beeps too, since I'm not exactly right on top of my Ground station, and I am listening to the flight audio. Could anything be added to the OSD to tell me, or is that too hard? I guess that would mean the GS has to be an OSD too, which is isn't.
Cheers all.
Sub.
Old Aug 08, 2012, 09:12 PM
eroeder's Avatar
Joined Jan 2004
Vendicated!
Old Aug 09, 2012, 06:07 AM
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
Looks very nice!
Subscribed.
pavn is offline Find More Posts by pavn
Build Log My home made FPV system: OSD+diversity+telemetry+tracking antenna+autopilot+IMU+PC Zbig Video Piloting (FPV/RPV) 102 Sep 25, 2011 01:15 AM
Discussion Eagle Tree GPS unit, live tracking? JustinONE Video Piloting (FPV/RPV) 10 Jan 11, 2009 03:27 PM
FS: Eagle Tree Systems RC Car Data Recorder hankster Cars - Cars and Parts (FS/W) 0 Dec 27, 2003 09:50 AM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
