Old May 11, 2009, 12:28 PM
jonesjj is offline
Find More Posts by jonesjj
Rockford IL U.S.A.
Joined Sep 2000
Glider Stands at the field
Greetings All,
I am wondering what guys are using at the field to hold and put together there ships with, I have seen some with what looks like a camera tripod but never seen what is on top of it to hold the plane.
If any one has any suggestions or pics that would be great.
Thanks for any feedback on this.
jonesjj is offline Find More Posts by jonesjj
Old May 11, 2009, 01:16 PM
peterkim2 is offline
Find More Posts by peterkim2
Joined May 2003
glider stand
http://www.amazon.com/gp/product/ima...sporting-goods
wings go on arm rest. nose fits under back rest.
and you can sit on it too. Plus it folds up.
peterkim2 is offline Find More Posts by peterkim2
Old May 11, 2009, 01:49 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
The foam blocks that come out of desktop computer boxes.
rdeis is offline Find More Posts by rdeis
Old May 11, 2009, 02:20 PM
jonesjj is offline
Rockford IL U.S.A.
Joined Sep 2000
this way I only bring one chair, like that idea.
Old May 11, 2009, 04:15 PM
StevenatorLTFO is offline
Find More Posts by StevenatorLTFO
AKA - The "Flywheel"
StevenatorLTFO's Avatar
SOAR Chicago!!!
Joined Jan 2005
Chair works great
At a contest last week, there was a feller that had boxes, that could be mounted on a tripod, was giving them away for a handshake, I brought one home with me, am in the process of painting it, and modifying it a bit, then I'll post up pictures and some more information.
StevenatorLTFO is offline Find More Posts by StevenatorLTFO
Old May 11, 2009, 06:19 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I came back from a contest flight one day and found the back on my chair bent. Removed the back uprights and placed a board across the arms and use Midwest's Stand-In: http://www.midwestproducts.com/item_...asp?item_id=57
tk
tkallev is offline Find More Posts by tkallev
Old May 11, 2009, 06:37 PM
wsmorton is offline
Find More Posts by wsmorton
United States, AZ, Prescott
Joined Aug 2006
Hi!
I just posted a great and really inexpensive glider stand that I made. The post is just a few pages back.
http://www.rcgroups.com/forums/showthread.php?t=1040937
Scott M.
wsmorton is offline Find More Posts by wsmorton
Old May 11, 2009, 11:27 PM
VegasRay is offline
Find More Posts by VegasRay
VegasRay
USA, NV, Las Vegas
Joined Oct 2005
Camera Tripod Field Stand
jonejj
I found my old video tripod that was tucked away for years. I used 1 x 3 for the base and 1 x 4 for the uprights. Two 10x32 bolts and wing nuts attach the wooden mount to the tripod deck (Topaz-S setting on the stand in the photos). The stand is almost more useful in the shop than at the field - turns/twist/angle up/down, etc. The telescoping legs are great for fitting in the trunk of my car. Dolled it up with some paint and an AMA decal.
Ray
VegasRay is offline Find More Posts by VegasRay
Old May 12, 2009, 01:29 AM
dlobbster is offline
Find More Posts by dlobbster
dlobbster
Snohomish Wa
Here is what I use.
dlobbster is offline Find More Posts by dlobbster
Old May 12, 2009, 02:21 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
This glider stand has become very popular at our field. It is made of PVC pipe and can be made to any height. Mine is about 40" tall and is made of 3/4" PVC pipe. Others are using 1/2" pipe.
It will accomodate anything from a DLG to a 4M glider. There is a drop area so you can work on your trailing edges while the plane is on the stand. You can face the plane one way and the fuse is supported. Good for putting on the wings.
Then reverse it and rest the plane on the wings for greater stability.
The lower legs can come off for easy storage and transport. The top "X" section can be used as a bench stand.
It REALLY works great! About $20 in materials.
http://www.lisfsoar.proboards.com/in...play&thread=12
aeajr is offline Find More Posts by aeajr
Old May 12, 2009, 07:06 AM
jonesjj is offline
Rockford IL U.S.A.
Joined Sep 2000
These are some great ideas, all seem storable easly which is what I am looking for also.
Nice to see what others are using Thanks for sharing.
Old May 13, 2009, 12:24 PM
Rick Lederman is offline
Find More Posts by Rick Lederman
Toledo, Ohio
Joined Aug 2005
Glider stand
I use a military issue Mark 1-A blanket ... with a stand all you need is a good thermal to come along and your sailplane and stand take a hike ... the blanket has never flipped over on me.
Rick Lederman
rick@soaringsoftware.com
Rick Lederman is offline Find More Posts by Rick Lederman
Old May 13, 2009, 03:31 PM
nuevo is offline
Find More Posts by nuevo
nuevo's Avatar
United States, AL, Madison
Joined May 2002
I've seen planes fall out of lawn chairs and mess up the tail or a wingtip, if the wind direction changes.
nuevo is offline Find More Posts by nuevo
Old May 13, 2009, 04:03 PM
soarx4 is offline
Find More Posts by soarx4
United States, IL, New Lenox
Joined Feb 2005
Years ago, there was a guy at the NATS, from Minnesota I believe, that had a very neat sailplane stand. It was cut out of a single sheet of plywood, and the sides and top were all interlocking (no screws) so that it could be taken apart and lay flat. It would hold two planes and had a top work surface. If I remember correctly, I think RCM even did an article on the stand. Does anyone else remember this stand? I would like to find the information on it.
Ron
SOAR Chicago
soarx4 is offline Find More Posts by soarx4
Old May 13, 2009, 05:38 PM
wsmorton is offline
Joined Aug 2006
soarx4: Something like this??
I have been taking pics of glider stands at the last two South West Classics. There's a few pics of different stands in the SWC 2008 and SWC 2009 albums.
CASL Photo Albums
Scott M.
How are gliders treated at your field? rc4metoo Electric Sailplanes 11 May 13, 2009 08:47 PM
heckled at the field tic Electric Plane Talk 60 Sep 29, 2006 12:25 AM
Ignored at the Field! R. Green Electric Plane Talk 103 Sep 18, 2006 06:02 PM
Why is it that you'll hit the one thing sticking up at your field? slowflyer Electric Plane Talk 33 Oct 19, 2005 01:41 PM
I just had a great morning at the field! Al P Electric Plane Talk 9 Jun 27, 2001 12:33 AM
