Old May 10, 2009, 10:10 PM
robh is offline
Find More Posts by robh
Good, fast or cheap, pick two
robh's Avatar
Napa, California
Joined Jul 2006
Help setting up v-tail function with Eclipse 7 - no ailerons
Hi,
I'm trying to figure out the best way to setup a v-tail on an electric sailplane with no ailerons. I want the motor on a switch, and to be able to use the right stick for controlling pitch and yaw attitude.
Any ideas are greatly appreciated!
Rob
robh is offline Find More Posts by robh
Old May 14, 2009, 10:29 AM
TOhm is offline
Find More Posts by TOhm
Hitec / Multiplex USA
Joined Apr 2004
You can set the Eclipse to glider mode/2-wing. Then go into the edit menus and select vtail. This will give you vtail on 2 and 4. Then go into A-R mix and enable it. This will mix the aileron to the rudder. No everything is on the right stick and the throttle is on a switch.
Tony Ohm
Hitec/Multiplex USA
TOhm is offline Find More Posts by TOhm
Old May 14, 2009, 08:24 PM
robh is offline
robh's Avatar
Napa, California
Joined Jul 2006
Tony Ohm
Hitec/Multiplex USA
Thanks very much for the info Tony. Also, if I have two spoiler servos, would they then go into channels 1 and 5, then set them up using Crow? I'll give it a try, and see if that works.
Rob
Old May 15, 2009, 10:51 PM
robh is offline
robh's Avatar
Napa, California
Joined Jul 2006
Tony...?
If I have two spoiler servos, would I wire them together and use a single connector on the receiver, or could I keep them separate and use which receiver plugs, based on your previous comment - use channels 2 and 4 for ruddervators?
How would I get the spoilers to function using the proportional throttle stick for variable control of them? Is there a way to do this, or would they have to be on a knob like VR1, or switch?
Thanks again for your help!
Rob
Old May 19, 2009, 01:46 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
It's best to call about programming as it's sometimes difficult to explain via the forums or e-mail.
(858) 748-6948
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old May 23, 2009, 09:56 AM
robh is offline
robh's Avatar
Napa, California
Joined Jul 2006
Hi Mike,
PM sent...
Rob
Discussion Setting up a motor glider with Eclipse 7 svenhaa Foamies (Kits) 2 Jul 07, 2008 02:50 PM
Whoops! converting slo-v to brushless need help setting up v-tail. eggic Electric Plane Talk 5 Mar 20, 2008 08:25 PM
Discussion Help setting up my new copterx with a 401 gyro. SteveCH Mini Helis 2 Dec 26, 2007 04:50 PM
Discussion help setting up trex tail bigjake Mini Helis 16 Feb 20, 2006 02:44 AM
Help setting up a Voyager E with a Schultz 45 pequeajim Electric Heli Talk 6 Oct 11, 2002 08:51 PM
