Old May 10, 2009, 02:37 PM
flying jeep is offline
Find More Posts by flying jeep
Brownsburg, Indiana
Joined Aug 2005
Question
Power supply for DC charger?
I've been looking for a dual input, A/C and D/C, lipo charger without much luck. I did stumble across a Vista X-RD 12v power supply in my barn today. It has 13.8v dc output at 10amps with 1% regulation. Can you run a D/C lipo charger off this type of power supply? Or do you have to have a lead acid battery and an AC charger? I hate having to use a car to charge batteries.
flying jeep is offline Find More Posts by flying jeep
Old May 10, 2009, 03:08 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
That power supply should work fine for chargers up to about 100 watts output. If you need more power you can buy a deep cycle RV battery then connect the power supply and charger to the battery at the same time. Some people even use a 13.8 volt power supply for lead acid battery charging.
SteveM732 is offline Find More Posts by SteveM732
Old May 10, 2009, 06:47 PM
Brownsburg, Indiana
Joined Aug 2005
I'm trying to avoid the battery on the workbench. They have a tendency to freeze and crack in the winter. Makes a huge mess. For my little 3S 1100ma batteries, do you think I can run just the power supply?
Thanks, Jay
Old May 10, 2009, 06:50 PM
SteveM732's Avatar
Joined Feb 2008
For chargers up to about 100 watts output power, yes.
Old May 11, 2009, 05:32 AM
jooNorway is offline
Find More Posts by jooNorway
jooNorway's Avatar
Norway
Joined Jul 2005
For your batteries, charging at 1C you need only appr 15-20 Watt from the supply.
Btw: Bantam BC6 is a nice AC/DC charger!
jooNorway is offline Find More Posts by jooNorway
Old May 11, 2009, 07:18 AM
DeadStick Dave is offline
Find More Posts by DeadStick Dave
I AM Smiling
DeadStick Dave's Avatar
Joined Dec 2007
I have the BANTAM BC6 AC/DC charger and the ACCU-CYCLE AC/DC chargers for home use. In the field, I use a 400 amp booster starter battery (Husky from Home Depot. It comes with a wall wart charger and has a light and Cigarette lighter outlet in addition to the booster cables.) I use a BANTAM BC6-10 (DC only) charger in the field.
The ACCU-CYCLE is from Tower Hobbies and will charge 2 batteries at once but only goes up to 3-cell Lipo's. The Bantam's will charge up to 6-cell batteries and can also balance and charge at the same time.
DeadStick Dave is offline Find More Posts by DeadStick Dave
Old May 11, 2009, 07:40 AM
terrorsound is offline
Find More Posts by terrorsound
United States, IL, Lockport
Joined Apr 2009
I'm curious on this myself.. I have a schumacher battery companion
6 volt/12volt 1.5A slow charge battery charger/maintainer model WM-1562A.
I'm curious if this charger will work with charging lipo batteries using a lipo balancer with gator clips.. Would this be safe or should I not even try this setup?
Thanks..
terrorsound is offline Find More Posts by terrorsound
Old May 12, 2009, 03:10 AM
jooNorway's Avatar
Norway
Joined Jul 2005
Thanks..
If you say you would like to charge LiPoes using a charger not meant for LiPo the answer is NO NO NO. Flying Jeep would like to use a supply to power his LiPo-charger. Please don`t use a non LiPo-charger.
Old May 12, 2009, 01:11 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Unless you use the 'Dapter. They work fine. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old May 13, 2009, 11:46 PM
Joined Apr 2009
I talked to a few RC guys locally and they said as long as the schumacher power supply is connected to the 3 cell lipo charger\balancer I should be ok. I'm still going to get a power supply designed for RC, this power supply is only temporary.
Thanks for the replies everyone..
Old May 14, 2009, 02:22 PM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
That power supply may not be able to deliver the amount of current needed for charging. Give it a try and see but get the "right-stuff."
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
AC Power Supply for DC Charger glider34 Batteries and Chargers 8 Nov 07, 2007 02:14 PM
DC Power Supply for Triton Charger? aeronca Batteries and Chargers 171 Jun 02, 2005 06:41 PM
Power supply for WES Charger? ScotY Batteries and Chargers 6 Jan 03, 2003 02:10 PM
Using a computer power supply for DC power for charger... T-Bo Electric Plane Talk 13 May 11, 2002 01:45 AM
Power Supply for Battery Charger AstroNut Power Systems 2 Oct 13, 2001 09:53 PM
