YogiRaw's FSD Segway Buildy Logy
http://www.futureslopedesigns.com/Segway.html
Curious as to how this small bird will fly. Has good roll rate. Great vid of it available. Though I have been watching Paige's gliders for a while, this will be my first building/flying of one.
Yogi...
Thanks for posting the build log. It was about time someone did. The Spackle is important (at least to me) for two reasons. One is purely aesthetic because I never liked the way cover looked over raw foam. The other is to give the smoothest surface possible. I do think it effects the flow of air over the wing. Remember that you are sanding off nearly 90% of the Spackle. There are times when I will apply a thinner second coat to get the ultimate smooth finish. I prefer a glue gun as opposed to Goop because of speed. I know that some have claimed that the hot glue does not hold up in cold weather. This may be true for some. However, I haven't had that problem. An inexpensive duel temperature glue gun can be purchased at ACE Hardware. Be sure to get the proper duel temperature glue sticks. Thanks again for the build thread. I will step back and watch. What do you think of the DVD? Do you think it is better than written instructions? Just curious. -Paige |
Latest blog entry: Freestyle Flight - The Last Frontier
To be honest, I can't say whether fuselages and wings benefit for the same reason, but I've never worried about the slightly bumpy surface I end up with when I apply film over bare foam and my planes seem to fly as well or better than the spackled ones. Pete (who believes in the concept of "to each his own") |
LOL Pete....You make a good point. In fact the whole "turbulation" (sp) thing is hotly debated. It just goes to show that things that appear on the surface as intuitive are not always so.
-P |
Portland Intl, Oregon, United States
Joined Jul 2003
I remember back in the day when some guys painted their planes with a rough bumpy spatter type paint, thinking it made them fly better.
I didnt try it cause I just didnt like the look, but they seemed to fly OK from what I remember. Looking forward to the rest of your build thread Yogi, thanks for doing it. TIM |
Not sure how fluid dynamics relates to aerodynamics, but Hondo Boats experimented with a shark skin surface on the bottom of a few flat bottoms back in the mid-70s. It substantially improved their performance, but they never figured out how to make it economically feasible. Pete |
Absolutely. I have used Mac's video editing/DVD making as well and I like it. The only thing I would improve is to see if you can cut out the transition time when going from chapter to menu. It takes like 10 seconds. I want instant. There may be a "skip animated transition" button that I don't know about. Will commence with build tomorrow. Busy today. |
So I'm also building a Segway from FSD,
I've just started to use goop on the fuse (which I've never used before) so its an interesting process. I decided to use the 'new stuff' on the wings. Screw spackle I say I tacked the wings together with 5 minute epoxy, then used 30 minute to put in the two spars. After that, I made sure my electronics fit in the wings. I've made the mistake of not checking that before ![]() Once that was done, I took the servo's out, and layed an entire piece of laminating film over the top, trimed it closely, and used some 3m77 spray on the wing first, let it try for 2 mins, then put it down. Then ironed it on, perfect! The entire top of the wing is one piece of film, and I'll do the same for the bottom, ca'ing the edges together. Should make for a pretty solid wing. It isn't super smoother, but its pretty good. |
| Thread Tools | |
| Discussion YogiRaw's WildBird 52 EPP Sketch | yogiraw | Slope | 22 | Jun 18, 2008 01:59 AM |
| Discussion YogiRaw's TW: the "Thinneron" | yogiraw | Slope | 69 | May 24, 2008 06:13 AM |
| Discussion YogiRaw's Moth60 Build | yogiraw | Slope | 95 | May 13, 2008 04:59 AM |
| Discussion YogiRaw's Speedo Crash + Rebuild | yogiraw | Slope | 13 | May 06, 2008 04:20 AM |
| Build Log YogiRaw's BobCat (Scratchbuilt Plank) | yogiraw | Slope | 19 | Apr 12, 2008 03:01 AM |
