Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old May 08, 2009, 11:58 PM   #1
Nico Hobbies
crxmanpat's Avatar
BMKDesigns F6F Hellcat profile park fighter
BMK Designs is putting out a line of flat foamy park fighters. The P-51 Mustang is already done, and next out is an F6F Hellcat. I was lucky enough to be selected for the beta build, and here is my build thread.
For anyone that's built a profile foamy, the builld is pretty much similar as most of what's on the market today.
The first set of pics shows how the kit is received, all of the parts removed from the cut sheets, and a few dry fit pics.
Pat
  • Name: Hellcat Build Pics 001.jpg
Description: Removed from the bag. Removed from the bag. 29.1 KB · Views: 100
  • Name: Hellcat Build Pics 002.jpg
Description: Parts removed from the cut sheets. Parts removed from the cut sheets. 59.6 KB · Views: 49
  • Name: Hellcat Build Pics 003.jpg
  • Name: Hellcat Build Pics 004.jpg
crxmanpat is offline Find More Posts by crxmanpat   Reply With Quote
Old May 09, 2009, 12:09 AM   #2
Nico Hobbies
crxmanpat's Avatar
Step one is to remove the cutout for the wing spar and glue the CF spar in. Here is the method I use to secure the wing spar. First, take a piece of scotch tape and completely cover the spar channel. Then flip the wing over and frame out the slot with scotch tape (leaving the channel open). Then mix your epoxy (30-minute works best) and, working from the open side, drizzle a thick bead into the spar channel. Insert the CF spar and drizzle more epoxy on top of the spar. Now take a scraper (old credit card or other scraper) and smooth out the epoxy. Once the epoxy sets up you can remove the tape.
Pat
  • Name: Hellcat Build Pics 005.jpg
Description: Tape over the channel. Tape over the channel. 56.7 KB · Views: 35
  • Name: Hellcat Build Pics 006.jpg
Description: Flip the wing over and frame with tape to prevent epoxy overflow. Flip the wing over and frame with tape to prevent epoxy overflow. 59.2 KB · Views: 35
  • Name: Hellcat Build Pics 007.jpg
Description: Ensure the spar is the proper length. Ensure the spar is the proper length. 69.5 KB · Views: 36
  • Name: Hellcat Build Pics 008.jpg
Description: After inserting the spar, fill top with epoxy then smooth out with a scraper. I've also marked a centerline for the bottom fuse. After inserting the spar, fill top with epoxy then smooth out with a scraper. I've also marked a centerline for the bottom fuse. 76.1 KB · Views: 38
Old May 09, 2009, 12:20 AM   #3
Nico Hobbies
crxmanpat's Avatar
Pay close attention to this next section so that you get the aileron servo installed properly. First, you will need to mark the center of the wing in order to make sure the bottom fuse piece is installed correctly. At this point, DO NOT glue the bottom fuse piece on. In order to help, you can lightly tack it in place temporarily.
Next, line up the flat fuse section with the bottom and glue it to the wing, ensuring proper alignment. Then center your aileron servo and attach the control arm. It's also a good idea to have the quick connects installed if that's how your going to set it up. Then insert the servo so that the control arm is on the opposite side of the wing from the flat fuse section. Then secure the servo in place.
Next, glue the lower fuse section in place.
Pat
  • Name: Hellcat Build Pics 015.jpg
Description: Place the bottom fuse piece on the mark. DO NOT GLUE THIS ON YET! Place the bottom fuse piece on the mark. DO NOT GLUE THIS ON YET! 72.2 KB · Views: 35
  • Name: Hellcat Build Pics 016.jpg
Description: Glue the flat fuse section to the wing using the bottom fuse and servo pocket as a guide. Glue the flat fuse section to the wing using the bottom fuse and servo pocket as a guide. 72.1 KB · Views: 31
  • Name: Hellcat Build Pics 017.jpg
Description: Insert the aileron servo, then glue on the bottom fuse section. Insert the aileron servo, then glue on the bottom fuse section. 75.7 KB · Views: 43
Old May 09, 2009, 12:34 AM   #4
Nico Hobbies
crxmanpat's Avatar
Next I prepped all control surfaces for hinging. I'm tired of the tape hinges peeling up on my foamy planes, so I have started using traditional hinges on these. I use either left over GWS paper hinges, or strips of thin plastic ("fake" credit cards, plastic packing material, etc). First I beveled the leading edges of the control surfaces, then cut hinge slots and glued in the hinges.
Next I cut hinge slots in the wing and the vertical and horizontal stabilizers and glued them into place.
Before gluing in the elevator, I identified the center connecting section as a potential failure point, so I reinforced that with a piece of flat CF stick. I cut it to the length I want then simply epoxied it in place.
Finally, glue the horizontal stab in place, and then glue the top fuse section on.
Pat
  • Name: Hellcat Build Pics 010.jpg
Description: Rudder prepped for hinging. Rudder prepped for hinging. 78.2 KB · Views: 37
  • Name: Hellcat Build Pics 011.jpg
Description: Ailerons prepped for hinging. Ailerons prepped for hinging. 77.7 KB · Views: 32
  • Name: Hellcat Build Pics 009.jpg
Description: Flat CF stick reinforcement added. Elevator prepped for hinging. Flat CF stick reinforcement added. Elevator prepped for hinging. 63.9 KB · Views: 36
  • Name: Hellcat Build Pics 013.jpg
  • Name: Hellcat Build Pics 014.jpg
  • Name: Hellcat Build Pics 012.jpg
  • Name: Hellcat Build Pics 018.jpg
Description: Horizontal stab and top fuse section glued in place. Horizontal stab and top fuse section glued in place. 52.3 KB · Views: 40
Old May 09, 2009, 12:52 AM   #5
Nico Hobbies
crxmanpat's Avatar
Final construction consists of installing the motor mount (foam disc glues in first, then the ply piece second), installing the control horns, and installing the electronics.
For paint, I used water-based acrylic paints that you can get from the usual craft stores (Michael's, Jo-Ann's, Wal-Mart craft section, Hooby Lobby crafts, etc), and the decals were created in Paint and Word and using water slide decal paper printed on a color laser printer (BMK may be offering decal sets with the kits for an additional charge, but that has not yet been decided).
It flies like a typical profile foamy plane. The ailerons are not huge so it doesn't 3D as well as other kits, but this is really more of a park flyer sport plane than a 3D ship. Roll rate is good and it will perform a typical pattern routine.
Here's my setup for this particular plane:
Hobby-Lobby 400XT motor (920kv, 120W)
APC 8X6 Slow Fly prop
Scorpion 15A ESC
3X GWS Naro servos
XPS 6-ch parkflyer 2.4GHz RX
3S 1350 Rhino lipo
Dry weight (no lipo): 9.6oz/273g
AUW: 14oz/398g
Pat
  • Name: Hellcat Build Pics 019.jpg
  • Name: BMKDesigns F6F Hellcat 001.jpg
  • Name: BMKDesigns F6F Hellcat 002.jpg
Old May 09, 2009, 01:02 AM   #6
Nico Hobbies
crxmanpat's Avatar
Here's some in-flight pics. Video will be posted soon as well.
Pat
  • Name: BMKDesigns F6F Hellcat 003.jpg
  • Name: BMKDesigns F6F Hellcat 004.jpg
  • Name: BMKDesigns F6F Hellcat 006.jpg
  • Name: BMKDesigns F6F Hellcat 007.jpg
  • Name: BMKDesigns F6F Hellcat 008.jpg
  • Name: BMKDesigns F6F Hellcat 010.jpg
  • Name: BMKDesigns F6F Hellcat 011.jpg
  • Name: BMKDesigns F6F Hellcat 012.jpg
  • Name: BMKDesigns F6F Hellcat 016.jpg
  • Name: BMKDesigns F6F Hellcat 018.jpg
Old May 09, 2009, 01:36 AM   #7
You sabotaged my plane.
eliworm's Avatar
Hey Pat, here are a few photos from Today. I sure like your paint job.
edit: Doh! I just noticed some are the same. Tina must have e-mailed them over to you.
Jim
  • Name: May 8 2009 048.jpg
  • Name: May 8 2009 050.jpg
  • Name: May 8 2009 051.jpg
  • Name: May 8 2009 055.jpg
eliworm is offline Find More Posts by eliworm   Reply With Quote
Old May 09, 2009, 10:21 AM   #8
Nico Hobbies
crxmanpat's Avatar
Jim,
I stole them from our forum.
I deleted the two I had from Tina so that we don't have duplicates. Maybe I can get Mike to post up the video too.
Pat
Old May 09, 2009, 11:14 AM   #9
AZcrashpro's Avatar
Working on the video but I will post it when it is done.
AZcrashpro is offline Find More Posts by AZcrashpro   Reply With Quote
Old May 09, 2009, 12:55 PM   #10
AZcrashpro's Avatar
Here is the video of the P-51, I am waiting for the Hellcat to finish.
http://www.vimeo.com/4300875
Old May 11, 2009, 08:07 PM   #11
AZcrashpro's Avatar
http://www.vimeo.com/4563134
Old May 14, 2009, 11:20 PM   #12
N827TM's Avatar
I flew the Mustang and it is fun sport machine. I cannot wait to see this bird and hopefully fly it. Watching the video, it is nice stable bird.
Tom
N827TM is offline Find More Posts by N827TM   Reply With Quote
Old May 14, 2009, 11:38 PM   #13
Nico Hobbies
crxmanpat's Avatar
Tom,
When are you in town again? I'm at Nichols every Friday now, so if I'm there you can fly it. Mike and I want you to out it through the wringer! The video is of Jim flying. Says he likes it better than the Mustang.
Pat
Old Jul 16, 2009, 05:10 PM   #14
AZcrashpro's Avatar
Got to like that picture with the bird in it, Tina always gets some great shots.
Old Jul 16, 2009, 05:32 PM   #15
Nico Hobbies
crxmanpat's Avatar
Yes, she has a nack for getting pics of my planes with birds in the shot.
I will be tossing around the Hellcat at Beat The Heat up in Flagstaff this weekend. I have a Mustang at the house and need to get that put together real soon.
Pat
Foam Profile F6F Hellcat Eplane Foamies (Kits) 23 Feb 09, 2008 07:58 PM
Discussion Great Planes F6F Hellcat EP Park Flyer ARF p-w Electric Warbirds 13 Dec 09, 2007 11:23 AM
Hobby Lobby F6F Hellcat Greg Covey Foamies (Kits) 33 Sep 30, 2004 11:16 AM
Nice F/G 46"WS F6F-HELLCAT on E-Bay speedo Aircraft - Electric - Airplanes (FS/W) 2 Oct 01, 2002 11:28 PM
For Sale- F.f.x. Park Fighter Kits Mr Biggie Aircraft - Electric - Airplanes (FS/W) 3 Aug 28, 2002 02:56 PM
11
