Old May 08, 2009, 04:30 PM
dman777 is offline
Find More Posts by dman777
Joined Mar 2009
whats the fastest 70mm edf foam jet??
i modded a hl f5e trying to get the fastest speeds out of it....
I swapped out all electronics and upgraded everything including the servos to hs 65's. The electronics are :
125 amp cc esc
1400 watt js 1400 motor
70mm wemotec fan
4500mah 30c 5s polyquest lipo
airpower 260 micro air retracts
With an mph gauge( eagletree) i was only able to hit 86 mph...
Now my question is what is holding back this jet? the weight, the foam, the airframe design itself?
Anyways, the jet is totaled after a high speed pass where one wing folded...Im now looking into a fiberglass / balsa composite jet thats more durable and faster, unless someone can point me out another foam airframe that can handle the above setup and hit 100mph or more....any suggestions appreciated.
dman777 is offline Find More Posts by dman777
Old May 08, 2009, 04:34 PM
Wefinance01 is offline
Find More Posts by Wefinance01
RCMafia
Wefinance01's Avatar
United States, GA, Roswell
Joined Jun 2008
Sapac F16 hits that speed with stock setup on 4S battery give or take wind speed and direction. The the airframe is tougher than that Starmax soft crapp foam and can be modded to fit a 6cell easy.
Wefinance01 is offline Find More Posts by Wefinance01
Old May 08, 2009, 04:39 PM
head-wind is offline
Find More Posts by head-wind
Joined Mar 2009
125 amp cc esc
70mm wemotec fan
for the record:
The foamy Phase 3 F-16 flew at 170+mph?
Can you handle this speed?
BTW, F-5E is a draggy airframe
head-wind is offline Find More Posts by head-wind
Old May 08, 2009, 04:40 PM
RCMafia
Joined Jun 2008
was that Phase 3 converted to 70 MM EDF?
Old May 08, 2009, 04:58 PM
SmoothCruizer2 is offline
Find More Posts by SmoothCruizer2
Eggs @ Tea
Dover DE USA
Joined Feb 2007
125 amp cc esc
70mm wemotec fan
you answered most of your questions.....this plane is designed more towards a intermediate beginner and not designed for the high dollar parts you put in..... geez i still get upset guys you spend 3 times on more amp hungry parts on a flimsy floater airplane, Get you a airframe designed for speed ok? HET does that, you got a nice powerplant..... I got my EDO F-15 going that fast on 3s, BECAUSE its LIGHT and thats is key
SmoothCruizer2 is offline Find More Posts by SmoothCruizer2
Old May 08, 2009, 05:27 PM
PerlAddict is offline
Find More Posts by PerlAddict
PerlAddict's Avatar
USA, TN, Murfreesboro
Joined Sep 2006
Yep, the F-5E airframe is draggy. I'm going to see how my JS-1400 / Wemo setup does it in on 4S. I've contemplated even sticking the stock motor back in, but I think the extra thrust from the JS-1400 and Wemo will be worth keeping them in there. Did you have any extra reinforcements done to your wing that folded?
I'm hoping the F-16 I have from H/L will go a bit faster than the F-5E, but I think I'm going to start looking towards composite airframes to put my 70mm Storm in and run off a 5S pack. I'd like to be able to hit 100mph+, and out of the F-5E, F-4, and F-16, the F-16 is probably the only one with a shot of getting there, if any.
I've been meaning to give that Sapac F-16 another look, but I've got too many jets as it is. Holding out for new RC Lander planes!
PerlAddict is offline Find More Posts by PerlAddict
Old May 08, 2009, 05:36 PM
bulldog2 is offline
Find More Posts by bulldog2
Kuala Lumpur ,Malaysia
Joined Nov 2008
And with the new stockmotors u can do 5s as well too!!!guess my wattage on WOT.............. 1560 at 81 amps!!!
bulldog2 is offline Find More Posts by bulldog2
Old May 08, 2009, 06:03 PM
Eggs @ Tea
Dover DE USA
Joined Feb 2007
extra cells are overrated!!! Watts is power!!! not Volts lol aka my blizzard, runs with the best at 3S.... "its nasty fast"
Old May 08, 2009, 06:18 PM
dman777 is offline
Joined Mar 2009
heres a vid of the f5e modded jet ....notice the wings bending during banks and loops. I know i should have reinforced it to prevent the wing folding, but subconsciously i think i wanted to plant this thing into the ground so id have an excuse for a faster airframe! lol
edf jet modded from stock f5e (1 min 12 sec)
Old May 08, 2009, 06:37 PM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
Discussion - whats the fastest 70mm edf foam jet??
One in the back seat of someone's Ferrari.
Sorry, I know that was a useless answer.
I wonder why the Starmax HE162 has not been used much, by folks on the speed kick. I was amazed at the speed, considering the relatively low power in mine. Seems to be a clean airframe for speed.
WTFLYR is offline Find More Posts by WTFLYR
Old May 08, 2009, 06:40 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Not trying to be a wiseass, but this is basically a meaningless question. Any jet with any size fan can be made to go faster with more power, less weight, better aerodynamics, better airflow in and out, etc, etc.
To go fast, get a smooth, light airframe with well designed inlet and outlet ducts, and put as many watts in it as you can fit, with battery and motor.
Notwithstanding that, in my own opinion there is such a thing as too fast. I don't like a model that is flying at 2500 scale MPH. (unless it's an SR-71). Not realistic, and can't really see it. When I was younger and full of testosterone, I felt differently.
kelberts is offline Find More Posts by kelberts
Old May 08, 2009, 08:38 PM
RCMafia
Joined Jun 2008
i dont think people has caught on how good the new Sapac is...yet.....but they will. This one blows away the HL 70mm F-16 mod for mod...
Old May 09, 2009, 06:12 PM
D B Cooper is offline
Find More Posts by D B Cooper
Targeted and... FIRING !
D B Cooper's Avatar
United States, MI, Eastpointe
Joined Aug 2007
That power set would be really nice in a HET F18. Not the fastest airframe in the world, but it would still hand launch easily and be fast enough to be fun, but still very flyable.
Or a HET F16...
D B Cooper is offline Find More Posts by D B Cooper
Old May 09, 2009, 06:15 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
I'm sure this is hard to beat:
Phase 3 F-16 Speed Run, 177mph! (0 min 53 sec)
brati4 is offline Find More Posts by brati4
Old May 10, 2009, 12:37 AM
squirrlybird is online now
Find More Posts by squirrlybird
squirrlybird's Avatar
Greenville, SC
Joined Feb 2007
I sure would like to know what fan/motor/esc/battery combo was used in that jet.
That thing is amazing.
squirrlybird is online now Find More Posts by squirrlybird
Discussion AirPower & AFA F-20 70mm EDF Jet Video !! AirPower RC Electric Ducted Fan Jet Talk 328 Jul 08, 2015 08:35 PM
Discussion Glassing a EDF foam jet Jet Freak Foamy EDFs 23 Mar 05, 2010 12:25 PM
Discussion Exceed RC F/A-18C 70mm EDF RC Jet nitroplanes Nitro Planes 22 Oct 19, 2009 03:08 PM
Discussion Need suggestions for EDF system for 30oz foam jet arshish1612 Foamy EDFs 6 Sep 04, 2007 04:51 PM
Discussion F-14 1/16 Scale ARF For Twin 70mm EDF Jet Video AirPower RC Electric Ducted Fan Jet Talk 0 May 25, 2007 12:59 PM
