Old May 08, 2009, 02:19 PM
Eyefly is offline
Find More Posts by Eyefly
Eyefly's Avatar
United States, NC, Charlotte
Joined Apr 2004
Question
Using a BEC as a voltage regulator?
Dont know if it has been asked before but can a BEC be used as a voltage regulator? Here is the situation. I have a large molded sailplane which I will be running a separate battery pack to power the on-board electronics. The battery is a 2 cell Lithium ion pack (8.2 volts). I need to use a regulator to bring it down to 5 volts and was thinking of using a castle BEC or a park bec. Seeing that the servos and receiver will be the only draw on the pack, will using this BEC as strictly a regulator be ok?
Thanks for the input...
Eyefly is offline Find More Posts by Eyefly
Old May 08, 2009, 04:43 PM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
That is exactly what a BEC is, a Voltage Regulator. This is exactly what they are designed to do, so it would be a perfect use for the BEC circuit.
Lucien
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old May 08, 2009, 04:47 PM
Eyefly is offline
Eyefly's Avatar
Joined Apr 2004
Specifically, i have one of these and I want to use it as a voltage regulator for a two cell lithium ion pack. However it says that the input voltage has to be 9volts a two cell pack will be 8.2 volts. I am assuming this will not be enough and I will have to use a three cell pack or another BEC.
http://www.dimensionengineering.com/SportBEC.htm
Old May 08, 2009, 05:08 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Odd that it indicates 9V minimum input. You might send a correspondence to Dimension to see whether it's been tested for lower input voltage before proceeding. Testing in the air is something that is generally discouraged.
FWIW, I've had nothing but success with these inexpensive BEC's and have used them in several high performance models. They work down to 5.5V input, to which I can attest.
http://www.hobbycity.com/hobbycity/s...idProduct=3735
http://www.hobbycity.com/hobbycity/s...idProduct=4319
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old May 08, 2009, 06:21 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Have you considered running 2S A123 cells direct?
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old May 08, 2009, 06:56 PM
Eyefly is offline
Eyefly's Avatar
Joined Apr 2004
Yep, I will be looking into it before it is in the air. Works great on the ground though. I have it in an electric big Ceres and there is no way I will experiment with it in something so expensive. I can not fit the A123 cells in the fuse with all of the other stuff in it.
Old May 09, 2009, 07:10 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
A 2s pack goes down to 6v not 8.2v so not even close to working.
rich smith is offline Find More Posts by rich smith
Old May 09, 2009, 07:14 AM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
eyeFly,
Not sure what size or how many servos you're powering, but there's the BAC range of BECs which do what you want for smaller setups, including voltage reading and charge/on/off plug and socket.
http://nqrc.com/?vp=PLD-BAC-ESJ
and the BEC + alarm only
http://nqrc.com/?vp=PLD-BAC-004
Paul.
Inflexo is offline Find More Posts by Inflexo
Old May 09, 2009, 11:09 AM
Joespeeder is offline
Find More Posts by Joespeeder
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hi Eyefly,
Dimension has a ParkBEC that works with 2s-8s so input voltage is 6v and up.
Joe
www.thecaterhamproject.com
Joespeeder is offline Find More Posts by Joespeeder
BEC == Voltage Regulator? TMP00283 Electric Heli Talk 25 Nov 23, 2008 04:26 AM
Discussion voltage regulator for using extra cells? chevell Sailplane Talk 6 Nov 07, 2007 03:24 PM
Question Using separate ESC as BEC tailslide5_0 Power Systems 6 Sep 26, 2007 03:47 PM
Question What's everyone using as a voltage regulator? NumbSkull Sport Planes 26 Dec 21, 2006 06:34 PM
Voltage regulator as BEC? Tuomas Pietinen High Performance 1 Mar 10, 2002 06:32 AM
