Go Back   RC Groups > Vendors > Castle Creations
Closed Thread Post New Thread  Previous Thread Next Thread
Old May 20, 2009, 10:46 PM   #61
jamesppp's Avatar
Originally Posted by Spidious
Here is mine now !
Swift 16 w/ "Z" 800 12t pinion and 60cc esc
# Castle Link Data File
# Created: Monday, May 18, 2009
# Do Not Edit This File By Hand
Hex55: 85
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 59
Direction: Reverse
PWM Rate: 12 Khz (*)
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 16
Initial Spool-Up Rate: 3
Head Speed Change Rate: 5
Auto Rotate Enabled: True
Governor Mode Type: Fixed
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 6
Vehicle Setup - Battery Voltage: 22.2000
Vehicle Setup - Gear Ratio: 8.000
Vehicle Setup - Motor Kv: 800
Vehicle Setup - Motor Number of Poles: 10
Desired Head Speed 1: 1701
Desired Head Speed 2: 1701
Desired Head Speed 3: 1701
Current Limiting: Insensitive
Cutoff Voltage: 180
Motor Timing: 5
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*)
Spidious, how did you find that tiny window setting to enable the autorotate bailout feature??. I dont know where to start and I sure would like to be able to prove it works on the bench
My Gov mode is working great! I love it
jamesppp is offline Find More Posts by jamesppp
Old May 20, 2009, 11:59 PM   #62
Need Help with selecting the right PWM rate
I have a CC 85HV and I tried to set the PWM rate to outrunner, but its not one of he choices. Thought I bought it after the noted date, but I guess not, as per the Castle information:
"Added outrunner PWM rate option to improve efficiency and reduce harmonics when running fast commutation outrunners. Unfortunately this mode is only available on Phoenix ICE and Phoenix HV controllers manufactured after May 2007."
So, given the PWM choices available, since I have an outrunner, what PWM rate should I choose? I'm considering the highest available...
Motor is a Thunder Tiger OBL 49/08 (780 or 800 KV).
The ESC seems to run very cool, but the motor runs rather hot. Application is a Swift w/ 10S A123.
Running the new gov mode in RPM mode and gov works well, before updating the firmware, in heli fixed end point mode the motor was hot as well.
--David
dwelch is offline Find More Posts by dwelch
Old May 21, 2009, 07:43 AM   #63
jamesppp's Avatar
--David
Your ESC has a small, round, white sticker w/ the mfg. date on it.
I wouldnt set the PWM rate as high as it will go. Start at 8 and move up 1 setting if you feel the need. It should run cooler unless something is in a bind.
Old May 21, 2009, 09:33 AM   #64
A man with too many helicopter
--David
For outrunners use I PWM = 8 if outrunner is not on the menu. It works for Scorpion and Z-Power (Z-Power is the actual manufacture of most TT and Century outrunner motors).
For most outrunners I also run a timing setting of between 0 and 2. Any higher makes some motors run hot but I have some that are happy at 5. I would say to start at 2 and adjust from there.
RC Man is offline Find More Posts by RC Man
Old May 21, 2009, 03:36 PM   #65
RC Man, good info how did you come to this conclusion, PWM = 8 if outrunner is not on the menu?
Thank you
gww528 is offline Find More Posts by gww528
Old May 21, 2009, 04:20 PM   #66
Thank you
Trial and error. You are not going to hurt anything by trying different settings. The only time I have a problem was by running too much timing on a large outrunner causing it to loose sync and stripping the gears.
I don’t want to speak for CC so you may want to contact CC Tech support and see what they say.
Old May 21, 2009, 04:47 PM   #67
I did talk to CC Tech support and they did state, that the "Out Runner Mode (which I do not have), starts out at 8, then when it senses a fixed RPM, it goes into a Variable rate which best fits the motor".
Thanks again
Old May 21, 2009, 06:30 PM   #68
Anyone with Airplane setup on CC 85HV ??
I looked through all 5 pages. Everyone had heli setting.
I am using the setup with E-Flite Power 110, 2x 4S5000mAh TP Extreme (V1 & V2).
Been working on the setting since last Friday, but still can't get the Solid LED at full throttle. During the setting, I have beep when the ATV reaches the top and bottom ends, but no LED or anything indicating the Full throttle.
leaving the stick at full throttle position for more than 30 seconds still doesn't change anything (motor running or not).
Ihncheol
# Created: Thursday, May 21, 2009
Hex55: 85
Brake Strength: 0
Brake Delay: No Delay
Brake Ramp: Slow
Motor Start Power: 39
Direction: Forward (*)
Vehicle Type: Airplane
Throttle Type: Fixed Endpoints
Governor Gain: 1
Initial Spool-Up Rate: 5
Auto Rotate Enabled: False
Governor Mode Type: Simple
Current Limiting: Normal (*)
Cutoff Voltage: 264
Motor Timing: 5
PatternFlyer is offline Find More Posts by PatternFlyer
Old May 23, 2009, 02:10 AM   #69
garytskuah's Avatar
new CC software solve tail oscillation.
Hi folks. Just to share with you guys. The New Software has solve my tail from oscillating. RPM sound smoother and consistant. Tail holds great. Apparently, i just need to set my governor gain at 10 on set rpm governor mode. (Previously governor gain at 2 on governor mode high). Here's the setup for my CC85HV.
Trex 600 - Scorpion 4025-740KV(18t) with CC85HV
Brake Strength: 0 (grey out)
Brake Delay: .6 sec (Delayed) (*) (grey out)
Brake Ramp: Soft (grey out)
Current Limiting: Disabled
Cutoff Voltage: Auto Li-Po (*)
Motor Timing: 5(*)
PWM Rate: 12 Khz
Governor Gain: 10
Governor Mode Type: Set RPM mode
Vehicle Setup - Number of Cells: 8
Vehicle Setup - Pinion: 18t
Vehicle Setup - Main Gear: 170t
Vehicle Setup - Motor Kv: 740
Vehicle Setup - Motor Number of Poles: 8
Desired Head Speed 1: 2100
Desired Head Speed 2: 2100
Desired Head Speed 3: 2200
Great work from Castle Creation engineers...
garytskuah is offline Find More Posts by garytskuah
Old May 24, 2009, 11:00 PM   #70
Yes that is my Agusta A109
Spidious's Avatar
Well not sure what happened. I put in the below settings and the tail twitch was totally gone. Was flying it around and about 20' up all power was lost ? Auto down, lipo popped out (undamaged !) dingled tail boom and pulled threads on one link.
But the main problem was that the controller was smoking hot and the motor also. I had hit the hold switch as soon as I saw it lost power. But when I got up to the copter the controller was still smoking and then it made a Pifft sound and shot out smoke !
Strange that I have been flying for almost a year with it and had no problems till now. Was running a "Z" 800 motor, 6S lipo, 12t pinion and 60cc esc. I use to run a 10t pinion but was suggested by CC that in order to get the governor to work correct the gearing might have to be changed. Which I did and the settings looked OK on the screen.
I sent it back to CC for repairs/warranty ? And will see what they say. In the mean time I will be going back to a 10t pinion, since I ever had any problems running with it, and the motor was always cool after flights..
Hex55: 85
Brake Strength: 0
Direction: Reverse
Governor Gain: 16
Cutoff Voltage: 180
Motor Timing: 5
Spidious is offline Find More Posts by Spidious
Old May 29, 2009, 12:51 AM   #71
Trex 600E 8S, MSH Protos
Glad to hear the new firmware helps governor mode. I had major issues with the last firmware on my 8S Trex 600 and sold it to get the Kontronik Jazz-55 which worked great. Next time I need a ESC again I'll try out the new firmware!
moshen is offline Find More Posts by moshen
Old May 29, 2009, 07:30 PM   #72
Spidious's Avatar
But now another problem.. And a lot worse than a tail twitch !
http://www.rcgroups.com/forums/showt...2#post12345660
Old May 29, 2009, 07:55 PM   #73
I never got a response from anyone at Castle for my questions above, either here, or by emailing Castle directly. I'm beginning to to really wonder what's up... Where is one recommended to go for timely answers to simple questions?
Old May 29, 2009, 08:43 PM   #74
RC Boat Addict
Raydee's Avatar
Send a message via AIM to Raydee
Try calling them...always works for me.
Raydee is offline Find More Posts by Raydee
Old May 30, 2009, 05:40 PM   #75
SlowlyAgingVeryHipOldGuy
jbrowne's Avatar
I have CastleLink version 3.12.
When I download and run the 3.13 install, i complains about not finding an ".msi" file then says that it can't remove the existing version.
Any help would be appreciated
jbrowne is offline Find More Posts by jbrowne
Alert New PHOENIX FIRMWARE POSTED lestingoy Castle Creations 256 Jan 26, 2009 06:46 AM
New Articles Posted Hascal Site Chat 1 Jul 24, 2001 01:27 AM
New Gallery Page and New Reviews Posted Steven Horney Site Chat 0 Jun 26, 2001 01:37 AM
New Articles Posted Steven Horney Site Chat 6 May 24, 2001 01:20 AM
:cool: SR X250 Just Finished - New Photos Posted costath Electric Plane Talk 6 Apr 27, 2001 07:33 PM
Bored? Want to fight?
Join the RCGroups clan!
