| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
New firmware posted May 8, 2009
* Complete rewrite of governor mode algorithms *
o Provides less 'pulsing' behavior, even at high gains o Facilitates easier gain setup o Lower gains are now available o Governor mode has faster response o *Note: Your governor gain value will likely need to be changed from your current setting. * Added ability to change the 'Auto-Lipo' cutoff voltages to values other than 3.0 volts per cell. Use this setting to change the Auto Lipo cutoff voltage to the value recommended by your battery manufacturer/vendor. Settings now include 3.0, 3.1, 3.2, 3.3, 3.4, & 3.5 volts per cell. Controller will initiate Low Voltage Cutoff behavior once the controller detects voltage dropping below this value times the number of cells detected in the power up sequence. User is always responsible for ensuring that packs are properly & fully charged prior to connection to Castle ESC and for ensuring that ESC has detected the proper number of cells. Failure to fully charge cells or to ensure that controller has detected the proper number of cells may result in discharge below the pre set limit. This may damage any and all components in your system. * Added ability to turn off the power-on reminder beep. * Added outrunner PWM rate option to improve efficiency and reduce harmonics when running fast commutation outrunners. Unfortunately this mode is only available on Phoenix ICE and Phoenix HV controllers manufactured after May 2007. * Improved motor run routine for better performance on fast commutating outrunners * Added Phoenix ICE features and support Bug fix: Setting throttle response to 0 would not allow motor to run to full RPM Bug fix: Setting voltage cutoff to 4V on Phoenix HV would cause error message Bug fix: Stick programming when governor mode was selected could change start power |
#2 |
MaxiR SE~E620SE
Just downloaded it... hopefully tighten up the head speed on my E620...
Thanks CC for great products and support! |
#3 |
Sounds good. Ill try it this weekend if possible.
Do we still need to set only 2 headspeeds in "Set RPM" gov mode or is OK to set it up with 3 different headspeeds now? Thanks. Jimmy Last edited by jamesppp; May 08, 2009 at 10:54 AM. |
#4 |
Team SCHC
Any new instructions or guidelines to best set up the new governor?
#5 | |
A man with too many helicopter
The default gain is a good starting point. On my Raptor E550 with a Scorpion motor and an A123 battery I am running a gain of between 17 and 20. I am still fine tuning but now it has started raining so I will have to wait until later.
#6 |
Pesky Landings!
The new software looks great!
Can I suggest one minor improvement though? Increase the number of cutoff voltages (per cell) for the Auto Lipo, so that the voltage can be set below 3.0v too. The reason I would like this feature, so so I can use A123 packs, and not have to manually set the cutoff voltage when switching between a 3s and 4s pack (for example). In effect it would be an Auto A123 mode. Cheers Andy |
#7 | |
You could do the same at a lower voltage. Most importantly fly with a timer! |
#8 |
Looking forward to using governor again, thanks for the update...!!!
#9 |
[quote=RC Man]I just upgraded my ESC this morning and the three headspeeds work great. I set my throttle curves to a constant value for three flight modes (30 for normal, 65 for Idle1, 100 for Idle 2). I am using a Futaba radio.
The default gain is a good starting point. On my Raptor E550 with a Scorpion motor and an A123 battery I am running a gain of between 17 and 20. I am still fine tuning but now it has started raining so I will have to wait until later. RC Man, is the default Gov Gain still 7? Did ytou have yours set below the 17 and 20 before. Mine is at defaut and with the same headspeed in Idle 1 and Idle 2(slightly lower HS in normal mode) the gov is holding solid in ver 2.0. Just want to make sure before I change it. I have only my Raptor 620 running Gov right now but am anxious to get 3 other Castle powered helis set up in Gov mode.hanks, I cant get a grasp of how simple gov is supposed to work but if set rpm will give me 3 solid headspeed settings Ill be happy. Jimmy T |
#10 |
Governor Gain
The new default is 15 on my ESC. With the old software I was running about 5. The governor is different so you will probably have to try a few settings to find the optimum for your helicopter. I like the Set RPM mode with the three headspeeds best myself also. It works great. |
#11 |
Really Dear, only $150...
I just flew the new software in an HV85 running high governor mode with the gain set to default (15 I think?). Bottom line is that I am VERY impressed. No more hunting and wag.
In the past, especially running lower head speeds, when pitch pumping, the ESC would wag the tail and over speed when recovering from hard collective. This is ALL gone now. Nice and smooth! Great Job Patrick! This is on a Trex 600 running12s A123 with a Scorpion HK4025-740 and a 16 tooth pinion. Now I need to update my 4 other Phoenix ESCs! Bill |
#12 |
"Each Day Is A Lesson"
Anyone having problems downloading this?
Tried on Vista(As Admin.) and XP and both say install package will not work with Windows. Any comments. I see several have installed it. Thanks, Don |
#13 |
I had no trouble downloading on Vista Home Premium.
#14 |
In set RPM mode the new software wouldnt allow the same headspeeds that the 2.0 ver was using. For instance on my 10S Raptor with a CC HV 85, I was using 2000 as the Idle up settings (a lower speed for normal) only setting 2 different speeds.
The new software only allows 1898rpm Higher settings give the message"too fast for proper govorning" Hey, Ill regear. as long as this works well I happy. I have several 550-600 helis with Castle ESCs that need to be govorned... I selected Outrunner Mode for the PWM setting. This is a CC HV 85 made in November 07 so it should be good Jimmy |
#15 |
X-Era Motors
The software is probably capping the upper RPM so the governor doesn't reach voltage saturation. Saturation will play havok with any control loop.
| Thread Tools | |
| Alert New PHOENIX FIRMWARE POSTED | lestingoy | Castle Creations | 256 | Jan 26, 2009 06:46 AM |
| New Articles Posted | Hascal | Site Chat | 1 | Jul 24, 2001 01:27 AM |
| New Gallery Page and New Reviews Posted | Steven Horney | Site Chat | 0 | Jun 26, 2001 01:37 AM |
| New Articles Posted | Steven Horney | Site Chat | 6 | May 24, 2001 01:20 AM |
| :cool: SR X250 Just Finished - New Photos Posted | costath | Electric Plane Talk | 6 | Apr 27, 2001 07:33 PM |
