Old May 05, 2009, 06:08 PM
LNLP is offline
Find More Posts by LNLP
LNLP
Oak Harbor, Washington 98277
Joined Jan 2005
Sapac L-39 EDF Unit: How To Tighten Fan
Fellows, being unfamiliar with EDF units, how do you tighten the fan on
the motor shaft without breaking the fan? I slide the fan onto the motor
shaft, hold the fan with my fingers, then use small crescent wrench to
tighten --the adaptor turns but does not tighten.
Secondly, are you supposed to glue the long black cone onto the rear of
the motor mount?
Appreciate any help. Thanks, LNLP
LNLP is offline Find More Posts by LNLP
Old May 05, 2009, 08:41 PM
EDDIEGIGOWATTS is offline
Find More Posts by EDDIEGIGOWATTS
1.21 gigawatts
EDDIEGIGOWATTS's Avatar
Fort.lauderdale Florida
Joined Jul 2006
here ya go use a dremel or metal saw blade
this will aloud you to hold the shaft with a flat head screw driver while you tighten the bolt
happens with most fans also here is how I balance my fans post #27
http://www.rcgroups.com/forums/showt...1011309&page=2
EDDIEGIGOWATTS is offline Find More Posts by EDDIEGIGOWATTS
Old May 05, 2009, 09:45 PM
LNLP is offline
LNLP
Joined Jan 2005
Sapac L-39 EDF Unit Fan Installation
Thanks, Eddie, that helps a lot. LNLP
Old May 05, 2009, 09:59 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
That always works great!!!
lavochkin is offline Find More Posts by lavochkin
Old May 06, 2009, 12:18 AM
1.21 gigawatts
Joined Jul 2006
Lav,, learn it from ED,Waldrep long time ago
Lnlp if you have the 2842mb-1 motor it doesn't use the tail tube
you have to cut 1/4 inch of the back of the fan housing
so the blue part of the motor sticks out
Old May 06, 2009, 12:23 AM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
I'm amazed this part can't come from the manufacturer already machined. Same issue with the Wemotec mini fan. I don't have one but I've seen instructions for doing the same. That's why I liked the HET 6904 design with a collet and hex head screw. What about the cone? Wouldn't the motor get too hot enclosed within the cone?
kelvin is offline Find More Posts by kelvin
Old May 06, 2009, 12:30 AM
1.21 gigawatts
Joined Jul 2006
I opened my cone up a little,, with the tornado motor so far
tons of flight,s ,, no problems
I used a piece of Scotch tape to hold the cone
Old May 06, 2009, 01:18 AM
LNLP is offline
LNLP
Joined Jan 2005
Sapac L-39 Tornado outrunner
Eddie, my Sapac L-39 came with the Tornado 3200 KV motor. Does
anything need to be cut from the housing? If you cut off the end of the
housing for the motor, the cone does not fit.
What is the cone for? LNLP
Old May 08, 2009, 11:36 PM
1.21 gigawatts
Joined Jul 2006
don't cut it if you have that motor
I have the same motor with the tail cone so far no problems
the only thing I did was open the hole up more
as far as I know helps keep the turbulence down to give you better top end
Old Dec 26, 2010, 06:30 PM
gottafly1 is offline
Find More Posts by gottafly1
United States, NC, Hendersonville
Joined Dec 2009
I'm having trouble mounting my Neu 1112-1Y to the stock (I think) L-39 fan unit.
The 5 blade fan has a single screw at front center that tightens a collet around the motor shaft. However, I cannot get the collet small enough to tighten on the Neu shaft.
Anyone have any ideas or solutions?
Much appreciated.
gottafly1 is offline Find More Posts by gottafly1
Old Dec 26, 2010, 07:27 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
The Neu motor has a 3.17mm shaft. The collet that comes with the fan is a 4mm for a MB1 motor. That is why it won't tighten. Sapac sells 3.17mm collets for the Sapac fan.
rfodor is offline Find More Posts by rfodor
Old Dec 26, 2010, 07:32 PM
rfodor is offline
Joined Feb 2009
I like drilling a hole cross wise thru the shaft about a 1/8 inch diameter close to the end. That way you can hold the shaft with a equivalent size allen wrench. The screw driver slot isn't strong enough as the shaft is usually aluminium and quite soft.
Discussion Savex L-39 EDF Doug Bateman Electric Ducted Fan Jet Talk 1 Nov 03, 2009 03:03 PM
Discussion Electrifly L-39 EDF redtail Foamy EDFs 16 Jun 14, 2009 02:10 PM
Video 8'' L-39 EDF in Action! Chris T Electric Plane Talk 10 Sep 01, 2007 03:39 AM
Sold L-39 EDF w/ fan, motor, contoller TomFlyer Aircraft - Electric - Jets (FS/W) 8 May 29, 2006 10:29 AM
f/s l-39 edf FASTBEN Electric Ducted Fan Jet Talk 1 Sep 20, 2002 04:14 PM
