Espritmodel.com Heli Air
Old May 05, 2009, 01:49 AM
bluemeane's Avatar
Joined Apr 2007
THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!!
Let the modding begin!!! (Even if just in our heads for now )
I started this thread for the simple purpose of starting conversations on how to mod this sweet little plane...
First off, how about a micro brushless motor??
I haven had much exp with the little buggers, but they seem simple enough, My question is, is it possible to have a "plug-n-play" way of doing this? Can we just plug the BL ESC into the Sukhoi brick and then into the motor? Or will there be soldering needed? It looks like the JST connector in the middle of the board could be an alternate channel for the throttle... What do you guys reckon?
****Hehehehe just had to change the title... Didn't want to be sued by lightspeeddud... *****
bluemeane is offline Find More Posts by bluemeane
Old May 05, 2009, 04:24 AM
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
Probably be the same or a very similar proceedure to the other miniums, ie, solder a convertor from 'the steve' to the board and to an esc and you're good to go. Does add a fair bit of weight though, mainly from the esc. You will get a lot more power so if you can handle the plane having a higher stall speed from the extra weight then it'd be feasable, esp as you can run a 2s lipo.... Best mod I did on a minium though was to swap the brass bushes in the gearbox for tiny ball races. This added another minute or two to the flight time on my citabria and allowed it to loop from level flight, also allowed flights in higher winds than before, and all for a couple of quid and no appreciable weight gain.
thewildweasel is offline Find More Posts by thewildweasel
Old May 05, 2009, 08:05 AM
ForceFedDSM's Avatar
Massachusetts
Joined Jun 2008
You won't need a converter to run a brushless esc, the rx has a built in "x-port" to connect a esc too. Should be easy to add more power with that setup.
ForceFedDSM is offline Find More Posts by ForceFedDSM
Old May 05, 2009, 10:22 AM
Plymouth, Devon
Joined May 2007
Cool, that saves a few quid and a little tricky soldering
Old May 05, 2009, 11:26 AM
Make the best of all you have
beetyii's Avatar
Essen/Germany
Joined Dec 2006
Here is what i did for my Edge and it will certanly become a part of my Sukhoi - ballbearing ...
Rolf
beetyii is offline Find More Posts by beetyii
Old May 05, 2009, 12:48 PM
Plymouth, Devon
Joined May 2007
Makes a big difference doesn't it? As I said above my citabria was a much better plane after doing this
Old May 07, 2009, 09:23 PM
TP 1.21 Gigawatt Needed
MikeBiv's Avatar
Hendersonville, NC
Joined Jul 2005
I love the idea of a drop in replacement Brushless Motor, wish it was released at launch I really would like a High Quality one like a E-flite Motor but hopefully Hacker or Axi will have something soon.
The Motor used in the Raptor GS might have potential:
http://www.elemodel.com/shopen/html/product_1532.html
What is the Highest C lipos in this size I remember RCG had a AD for a 20 or 25 C lipo but can't remember.
I also may like to see what using an additional Servo on the Wing.
Hopefully some manufactors will add Some new Prop Selections.
MikeBiv is offline Find More Posts by MikeBiv
Old May 07, 2009, 10:09 PM
qman's Avatar
Wanaka, NZ
Joined Mar 2009
they are not even out yet and you are already changing them
qman is offline Find More Posts by qman
Old May 08, 2009, 07:08 AM
Plymouth, Devon
Joined May 2007
Isn't this hobby great?
Old May 08, 2009, 11:14 AM
Lawn Dart Specialist
SixDeuces's Avatar
United States, PA, Williamsport
Joined Jun 2006
Rolf
Rolf,
Being that I'm one of the lucky few who have access to a Sukhoi now, I'd like to try this mod. What size is the bearing? (in English)
Looks to be 4x1.5x2mm according to the photo, with the prop shaft/I.D. being the 1.5mm measurement. Correct?
Also, I'll need to find a US retailer... I remember a place specializing in small bearings, but I'm blanking on the name.
Thanks!
Jesse
SixDeuces is offline Find More Posts by SixDeuces
Old May 08, 2009, 11:28 AM
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
So when are the dang things coming out???????????
kenstogie is offline Find More Posts by kenstogie
Old May 11, 2009, 05:47 PM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
I've been having great results with my 20C Zippy packs in my micro stuff.
Make a huge difference!
Hyperion G3 just started selling a 120mAh 25C 1S that can be charged at 5C.
I've just got to give it a shot.
http://www.windrider.com.hk/product.asp?id=172
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Jul 14, 2009, 12:14 AM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Looks like our modding wait is almost over!
Seems that all systems are "go" for July.
I've got a Zippy 100mAh 20C pack that is ready. AUW with wire and Deans micro is 5g. Stock pack appears to be around 4g.
I"ve seen amazing power increases with these 20c packs in my micro helis.
Looking forward to trying the same on the Sukhoi!
I'll get some tach readings for ya'll.
Let's fly,
rc
Old Jul 17, 2009, 09:26 AM
..·`·.><((((º>.·`·.><((((º>
Sl0flyer's Avatar
Traverse City, Michigan
Joined Nov 2008
Post moved to "Official thread"
Sl0flyer is offline Find More Posts by Sl0flyer
Old Jul 17, 2009, 09:27 AM
Up Up and Away!
lightspeeddud's Avatar
Joined May 2008
please keep all the sukhoi stuff in this thread,
http://www.rcgroups.com/forums/showthread.php?t=1081070
sorry but you should lock this thread
lightspeeddud is offline Find More Posts by lightspeeddud
Gallery POST your parkzone warbird mods Citabria86614 Electric Warbirds 165 May 16, 2013 02:38 AM
Discussion Official Parkzone Vapor Mods thread !! glenn2626 Indoor and Micro Models 1645 Mar 13, 2013 09:41 PM
Discussion parkzone sukhoi ??? MJ-MERLIN Micro RTF 571 Sep 20, 2009 02:06 PM
Discussion ParkZone FW190 mods dmackie Electric Warbirds 8 Jan 17, 2007 12:54 PM
wattage sukhoi mods?? buzzsaw 46 Parkflyers 7 May 06, 2002 09:27 AM
