Old Jul 16, 2001, 08:07 AM
Grimlok75 is offline
Find More Posts by Grimlok75
Cleveland, OH USA
Joined Mar 2000
Combat Models F-16 or F-15?
I am thinking about one of these models and i want to put a brushless motor in it instead of the .46ic engine. Can anyone suggest a motor/prop/battery combo that would make this jet go like stink? Any help is appreciated.
Grimlok75 is offline Find More Posts by Grimlok75
Old Jul 16, 2001, 01:17 PM
cosmo is offline
Find More Posts by cosmo
Buenos Aires, Argentina
Joined May 2001
I dont have motocalc, but I think two 480`s in each motor ( a la TwinJet) will work in the F-15. I you keep light without landing gear, etc.
cosmo is offline Find More Posts by cosmo
Old Jul 16, 2001, 02:29 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
erm.. a couple of 480's (80W motors) to replace a 46? I think not..
..a
Old Jul 16, 2001, 03:33 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Without benefit of *.calc, and having seen one of those 46 powered deltas from Balsa USA - Enforcer? - with the prop in a slot, I'd say you're looking at 16 - bare minimum - to 20 cells, running an Aveox brushless, with a 9 or 10" pusher prop.
If you go to Aveox's site, they have a motor estimator page, where you can stick in the stuff you can change - cells, prop, motor model # - and figure things out. Look for a combo that will turn a typical glow prop of the usual size for those models at near matching revs. Stay under 35A - 40A max current for decent flight times and being kind to gear and batteries, and learn to really use that throttle lots.
You'll almost certainly want to stay out of geared motors, as they need huge props and those models are pushers and won't stand much over 10".
Points in your favour - if those models need nose ballast to counter a tail full of engine, you won't. A CG pays attention to a 20 cell nicad pack, plus a direct e-motor is lighter than a glow lump. Another is your fuel tank doesn't change weight between full and empty.
Okay, maybe it does, but not as you'd measure on kitchen scales!
I'd be inclined to look at a no UC catapult launch,for simplicity. I recall an F16 fitted with trike fixed gear and it looked ridiculous flying around with the huge fat tyres needed to cope with grass.
OTOH, Robert W at the Electric Jet Factory converted a Combat Models A10 to twin EDF with retracts and it flew really awesome. Very much a tarmac bird though.
Good luck, you could end up with an impressive sports jet.
Dereck
[This message has been edited by Dereck (edited 07-16-2001).]
Dereck is offline Find More Posts by Dereck
Question Combat Models F-16/18 pusher Eddie P Fuel Jet Talk 35 Nov 28, 2012 03:26 PM
Wanted RTF F-16 and/or F-22 and/or F18 aalhait Aircraft - Electric - Jets (FS/W) 2 Dec 14, 2006 07:50 PM
Combat Models F-18 or F-16, can it be done as an EDF or Pusher electric. Jackspt28 Electric Ducted Fan Jet Talk 3 Mar 07, 2005 06:31 PM
Combat Models F-15 AMTJIM Foamies (Kits) 6 Jul 11, 2003 02:26 PM
Combat Models F-16 or F-15? Grimlok75 Electric Ducted Fan Jet Talk 0 Jul 10, 2001 11:48 PM
