Old May 04, 2009, 10:22 AM
dlesnick is offline
Find More Posts by dlesnick
United States, IA, Des Moines
Joined Apr 2003
Help with a power system for a Super Falcon 120
I am going to convert a Super Falcon 120 to an electric pusher config. I have seen some threads on EDF but nothing really showed up in a search for a basic electric conversion.
I have narrowed it down to two likely power systems but I want to get some feedback on which would be the better path. I am not sure if I should go for more RPMs and a smaller prop or a little bigger diameter prop and lower RPMs. I think conventional wisdom is larger props are better from an efficiency viwpoint.
I expect to be in the 17-18lbs range RTF
The two power systems I am looking at are 10S based.
System 1:
Scorpion 4035-380 swinging a 12.5x10
Amps 69
Watts in 2400 and change
RPM 12700
Pitch speed 120mph
Static thrust 300 oz
System 2:
Scorpion 4035-460 swinging a 11x9
Amps 68
Watts in 2380
RPM 15500
Pitch Speed 133mph
Static thrust 285oz
I know these are "calculated" not measured performance numbers but with that in mind which way would you go? Most discussions seem to be based around 3d style power systems. I am looking for something geared to a decent speed in a sport style plane. I am going to use the Falcon as a "jet" trainer with retracts and flaps.
dlesnick is offline Find More Posts by dlesnick
Old May 04, 2009, 09:51 PM
Merlin1205 is offline
Find More Posts by Merlin1205
USA, FL, Winter Haven
Joined May 2006
Judging by the numbers I doubt that you would be able to tell a difference between the 2 setups. They are very similar, so do you want 15oz more thrust or 13mph pitch speed ?
Guess that's the question hehe
Good Luck,
Tim
Merlin1205 is offline Find More Posts by Merlin1205
Discussion HELP puting together power system for skateboard, plz Nek Power Systems 8 Jul 18, 2008 10:36 PM
Help! Power system for a Super Sportster 40 MkII methos Power Systems 6 Mar 09, 2008 08:12 AM
Help needed selecting power system for F1A conversion. Lancer31 Electric Sailplanes 0 Jun 20, 2005 09:19 AM
SOme help with a power system pequeajim Power Systems 8 Mar 05, 2004 08:37 PM
Help with GWS power system DavidMC Scratchbuilt Indoor and Micro Models 1 Jan 06, 2004 09:52 AM
