Old Jul 04, 2001, 10:55 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Large aerobatic model - Edge 540 or similar
Curious..
I have this little F27 sitting around..
I figure on 30 cells I can get over 11 lbs thrust (peak) with a 14" prop.. 30 RC cells weigh 3.75 lbs, motor/controller less than 1lb, is there a large aerobatic (ARF) model that weighs 4lbs or so dry?
Anyone else tackled a project like this?
Is it worthwhile?
Affordable?
Probably not going to jump into this for a while, but I keep thinking, I have the motor sitting there.. probably a little large for my Somethin' Extra kit..
..a
Old Jul 05, 2001, 12:38 AM
Dave Grife is online now
Find More Posts by Dave Grife
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
Hi Andy,
I've been flying a Hanger 9 Edge 540 for several months now. I had to do a little extra work on the wing because of a recall that happened after I had already been flying it.
I'm using an Astro 60 (11t) with a superbox, 40 Nimh 2000mah cells. The plane weighs about 14 lbs. Performance is quite good and I'll be bringing to Mid-Am this comming weekend.
Converting it to electric was simple and it is a really nice looking plane.
Dave
Dave Grife is online now Find More Posts by Dave Grife
Old Jul 05, 2001, 01:15 AM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
What is the current on that estimated setup?
I believe the F27 is really a 1412/2Y which "only" has a current rating of 43A for more continous use. I know it is pushed much harder in gliders, but that is mostly on/off and normally with 1250 cells. When I looked at it in ecalc it seemed more like 24 cells and maybe a .60-90 aircraft type motor.
I would be interested to see if it can handle your proposed setup, it would be a very power setup.
ScottS is offline Find More Posts by ScottS
Old Jul 05, 2001, 08:27 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Yes, it is CAPABLE of that kind of power but that's why I put "(peak)" in therem. I wouldn't dream of running it wide open much.
I love the way the large models just idle off the runway.. I'm wondering if that's something we could do with a large model on a power system like this.
Dave, what is/was the dry weight of the 540? At 14lbs total with your power system, looks like it's 9lbs or so? Yikes! I wonder if the Lanier kits are any better..
..a
Old Jul 05, 2001, 08:49 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
The E-verted H9 PT-19 written about in S&E a few months back used an 1415/3Y and 30/32 cells w/16x10 APC"E".
Also thought I read here that someone used the same set-up in an H9 Edge 540.
jrb is offline Find More Posts by jrb
Old Jul 05, 2001, 10:02 AM
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
My current draw is only about 33 Amps intitially(2000 NiMh are happy there). I think that the weight was about 9 lbs. without the power system.
Old Jul 08, 2001, 10:43 PM
DogmanMex is offline
Find More Posts by DogmanMex
Tenancingo, Mexico
Joined Jan 2000
Hi Andy,
Look into the Aeroworks 1/4 scale Edge 540. I have one with a YS 140, 6 heavy Futaba digital Servos and Smoke system and it only weighs 9 pounds. I have also contemplated converting it to Electric. I think it would work very well with your system.
Regards,
Ricardo
DogmanMex is offline Find More Posts by DogmanMex
Old Jul 09, 2001, 01:02 AM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
Ricardo,
Your 9 pound weight - is that with fuel and liquid for smoke, or "dry" weight?
Terry
temacc is offline Find More Posts by temacc
Old Jul 09, 2001, 10:41 AM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
andy,
it is not too large for your something extra. i have a something extra with f-27 on 20 cells and 14 x -- prop. it flies great. (just flown at mid america) about 7.5 pounds.
do not run this motor on 30 cells and a 14 inch prop , unless in lmr, 7 seconds at most.
mine heats up plenty on 20 cells over 5 minutes.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old Jul 10, 2001, 01:40 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I already have the SE so perhaps I should just build the darned thing.. sigh.. another project..
..a
Old Jul 10, 2001, 12:01 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Andy: My Goldberg Sukhoi is roughly the same size as a 1/4 Edge-72" span. At 12 1/2 lbs RTF, it flies to my satisfaction(!) with a Pro Zinger 18x10 turning about 7500 RPM. (Roughly 23 lbs thrust) If you can find the power to do this, or close to it, go for it. Otherwise, I'm afraid you'd be doing it for the sake of saying you could. E-power just might not be the best for this plane and type of flying.
BTW, mine has a Brison 2.4. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Jul 10, 2001, 02:08 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Wow Sabrejock/Tex, 2000+ watts!
The S&E PT-19 used 1000+/32 cells and Dave has over 1200.
Bring on those fuel cells; will that make us gassers again?
Old Jul 10, 2001, 09:40 PM
Tenancingo, Mexico
Joined Jan 2000
Terry,
The Aeroworks Edge weight is Dry, without fuel or smoke. I think it is the lightest of all these type of models.
Ricardo
Old Jul 10, 2001, 09:53 PM
kevin is offline
kevin's Avatar
Joined Aug 1999
e-power is fine for this plane, trust me, mine flies great. ill shoot you some pictures after i borrow a digital camera.
Old Jul 11, 2001, 07:40 PM
Norm is offline
Find More Posts by Norm
Oak Harbor, Washington, United States
Joined Jan 2001
27% Staudacher, 14.5 lbs. 78.5" wingspan, Actro 40-5 motor, Actronic 70-32 controller, 30xRC2400 zapped cells, 18x10 APC-E prop, 60 amps off of Fresh charge. I'll let you do the math, 60 amps on 30 cells. Has slightly less power than when the gas Quadra 40 was installed.
Data & pictures were posted here a few weeks back.
Norm
Norm is offline Find More Posts by Norm
Discussion Art Tech Edge 540 or Christen Eagle rigger Electric Plane Talk 9 Jul 13, 2006 05:51 AM
!!!!! Edge 540 Or The Typhoon !!!!!! Mattster Electric Plane Talk 12 Oct 12, 2005 04:12 AM
WTB: Radical Edge 540 or MiniFlash oex Aircraft - Electric - Airplanes (FS/W) 2 Jan 15, 2003 05:06 PM
radical edge 540 or mini ifo? easy2fly Sport Planes 6 Nov 20, 2002 09:13 PM
