Go Back   RC Groups > Aircraft - Electric - Airplanes > Electric Warbirds
Old May 03, 2009, 04:19 PM   #1
Baa baa baa *thump!*
ugly john's Avatar
I've seen it, I've flown it. My impressions on the new PZ Mustang
So there I was at SEFF, carrying my trusty T-28 to the line, when I saw John Redman flying the new Mustang. I had talked with him and Dave about this plane several times over the weekend, so he knew me.
I said to him "It's really not fair that you are sitting here flying this new Mustang when it's not available for the rest of us yet."
His reply? "You want to fly it? Here..."
No shite. I flew it.
But first, what I saw on the plane. This is from looking at it, and (like I said before) spending a lot of time talking to the Horizon guys.
The first picture below is just an overall shot. Yup - it's a Mustang and yup - it's Z foam. It looks nice, but this is not a plane you get because you want perfect scale realism. This is a plane you get because you want something that will look good in the air, but more importantly, fly good.
The second pic shows the inside of the fuselage. Note that there is a space pre-molded for the rudder servo.
The 3rd shows the lower part of the rudder. To add rudder control, you would need to cut out around the counter balance, and cut the small pieces of foam on each side of the lower portion. All that is required is an exacto knife and 5 minutes. The hole for the push rod is in the fuselage, and with the PnP model, all required hardware (except the servo) is included.
The fourth pic shows the underside, including the plastic skid plates, and the spar.
Picture 5 shows the battery install. It is pretty much just like the Corsair (but without that pesky screw poking through ).
Finally picture 6 shows the wing. Notice the washout, as well as the airfoil shape - semi-symmetrical near the root and flat bottomed towards the tip.
Talking with Dave, a lot of the design decisions for this plane were to keep the price below $200. Thus the lack of a rudder servo and the 27MHz radio. To keep the price down, they also went with a smaller battery. To get decent flight times with the smaller battery, they propped down and used a smaller ESC. So a 1350 mah battery is providing 10 minute flights.
Now, my opinions:
The 18 amp ESC? Whoop-dee-do. I will probably change it out for a 30 amp before the first flight. This was a big concession for the price point, but minor for those of us that want speed. I would say most folks on this site have a spare ESC or five floating around. Or, grab the ESC out of your Corsair or T-28 to throw in the Mustang, and get a bigger one so you can put a big honking motor on the older planes. Put a 30 amp ESC and an 11x7 APC on the Mustang and she will be a rocket!
The 1350 mah battery? Again, this will probably never fly in my mustang. It will work great in my Super Cub though. The Mustang will hold an 1800 or 2200 lipo no problem.
Rudder - if you want it, it is a piece of cake to add it. 5 minutes and a spare servo and you are in business.
27MHz radio - this is only on the RTF. Honestly, who is going to buy this RTF except someone new to the hobby? Those of us that are into the Parkzone planes are going to already have a Spektrum radio.
Landing gear - I love the gear on my Trojan. Touch and Goes with that plane are a blast. But on my Corsair - I belly flop it. It just seems to fly a lot better without the gear. I see this one as better without gear. I imagine someone will eventually figure out how to put retracts on her.
Finally - I got to fly her. Now, I'm a hack in the air to begin with, but with someone else's plane, I am taking it easy. So I stayed high and didn't do anything crazy. Loops and rolls were fine. (John Redman loved doing the inverted low passes - no way I was trying that). Speed was OK, but not great. Again, it will be wicked easy to get a large increase in speed on this bird.
What really sold me on this plane was slowing her way down. I had maybe a quarter throttle, and the elevator all the way back and she wouldn't break. She would try to lower her nose a bit, but that was it. AND, plodding along with max elevator and slow speed, I still had roll authority. She was just rock freaking solid.
So, my bottom line - am I going to get this plane? YOU BET I AM!!! I think she is just an amazing value. A Z-foam 'Stang like everyone wanted, with a very good rx, easily made into a very fast plane, and rock solid. Backing out the $50 rx, you are getting an airframe, motor, servos, and ESC for only $129. Wow.
John and Dave- thanks guys! I really appreciate you taking the time to talk with me about this plane everytime I came by. And the chance to fly it - WOW!!! Can't wait to see what is coming up next. I have a couple ideas but I promised I wouldn't say anything.
I will say to everyone here - If you are not stoked on this Mustang, give it another look. I think she is going to be a real winner. I'm going to be planning my paint scheme for her, because there are going to be a lot of them out there.
  • Name: SDC10093.jpg
  • Name: SDC10082.jpg
Description: Inside of the Fuselage Inside of the Fuselage 84.1 KB · Views: 390
  • Name: SDC10086.jpg
Description: At the bottom of the rudder is the small piece of foam that needs to be cut out, as well as around the counterbalance area near the top. At the bottom of the rudder is the small piece of foam that needs to be cut out, as well as around the counterbalance area near the top. 49.4 KB · Views: 365
  • Name: SDC10089.jpg
Description: Lower view with skid plates. Lower view with skid plates. 68.4 KB · Views: 420
  • Name: SDC10084.jpg
Description: Battery install - just like the Corsair Battery install - just like the Corsair 66.8 KB · Views: 366
  • Name: SDC10094.jpg
Description: Notice the washout and the airfoil shape. Notice the washout and the airfoil shape. 73.1 KB · Views: 577
ugly john is offline Find More Posts by ugly john   Reply With Quote
Old May 03, 2009, 04:43 PM   #2
Long live the Nuge!!!
skywarp1's Avatar
Not neccessarily. I love PZ airplanes and want this one, I would have liked a RX ready version but I understand they tie it to their brand name of radio gear. No sweat, I can always replace it.
skywarp1 is offline Find More Posts by skywarp1   Reply With Quote
Old May 03, 2009, 04:49 PM   #3
A BITE or two?
guapoman2000's Avatar
They do have a RX Ready version.
It's called the BLIND-N-PLAY (BNF).
Part Number: PKZ1880
http://www.horizonhobby.com/Products...ProdID=PKZ1880
guapoman2000 is offline Find More Posts by guapoman2000   Reply With Quote
Old May 03, 2009, 04:52 PM   #4
A BITE or two?
John,
Thanks for that wonderful report from SEFF!
Old May 03, 2009, 04:57 PM   #5
Horizon
To avoid any confusion... the BNF (Bind N Fly) includes an installed AR500 Rx (and a battery and charger). Just bind it to your Tx (DSM2 Full Range) and fly.
At some point, the replacement airframe (arf'ish) will appear.
http://www.horizonhobby.com/Products...ProdID=PKZ1870
Have Fun,
David
dribbe is offline Find More Posts by dribbe   Reply With Quote
Old May 03, 2009, 04:59 PM   #6
skywarp1's Avatar
That's what I was thinking and just swap out the RX. I would imagine then that for BNF the servos are 3 wire not 5 as in RTF? When I get mine I will give someone my RX who can use it. Where I fly I there is really no need for me to have 2.4 so I just don't bother to switch.
Old May 03, 2009, 05:00 PM   #7
A BITE or two?
Originally Posted by dribbe
To avoid any confusion... the BNF (Bind N Fly) includes an installed AR500 Rx (and a battery and charger. Just bind it to your Tx (DSM2 Full Range) and fly.
Have Fun,
David
Confusion? Sounds like one of those KUN FU movies
Hey, I did not think my post was confusing but, please go to my thread as I thought I captured all the versions that this model is coming in.
Please go to:
http://www.rcgroups.com/forums/showthread.php?t=1042799
Old May 03, 2009, 05:02 PM   #8
A BITE or two?
See this picture and it answers your question. BNF Version!
Old May 03, 2009, 05:06 PM   #9
Horizon
Please go to:
Above, you said it was receiver ready (GP speak for NO Rx) it includes an Rx.
Have Fun,
David
Old May 03, 2009, 05:09 PM   #10
Trash Hauler emeritus
herk1's Avatar
Just having a Spektrum isn't enough. Unfortunately, the whole bind-and-fly concept ignores those of us who are still happy with our DX6 radios, even though it "is" a Spektrum. No biggie though...about the only way I build anymore is from airframe-only ARF.
herk1 is offline Find More Posts by herk1   Reply With Quote
Old May 03, 2009, 05:11 PM   #11
A BITE or two?
Have Fun,
David
Thanks! Hope my thread over in the Electric Warbirds section is all right and if not, let me know.
Thanks!
carlos
Old May 03, 2009, 05:11 PM   #12
Horizon
Hmmm... The airframe only ARF is on offer, so you guys are not ignored...
(I did say DSM2, not Spektrum).
Have Fun,
David
Old May 03, 2009, 05:13 PM   #13
A BITE or two?
There you go.....
Various versions of this model to suit almost everyone with various equipment setup thoughts and needs.
Hip Hip Hooray for Park Zone / Horizon Hobby!
Old May 03, 2009, 05:13 PM   #14
Horizon
Thanks!
carlos
Peeked at that one... looks pretty accurate at a glance....
Regards,
David
Old May 03, 2009, 05:24 PM   #15
skywarp1's Avatar
Sweet!! Sorry for not studying the posts and pics better. This is on my get list, in fact I think it will be my very next one as I don't currently have a mustang of any type or brand. STOKED!!!!
Post the Worst Conditions You've Flown In!! beafraid8 Electric Plane Talk 28 Mar 10, 2004 05:41 AM
Whats the max weight you've flown a slow stick? BigShark Parkflyers 3 Sep 23, 2003 01:58 PM
You know you've flown too much when... RCFlybry Parkflyers 20 Nov 12, 2001 09:00 PM
How hard can it be?! I've Flown a cessna before! Augeredin Electric Plane Talk 24 Jun 06, 2001 12:49 PM
What's the highest you've flown? CoClimber Parkflyers 9 May 12, 2001 10:02 AM
Congratulations SimpleM!
