Old May 03, 2009, 07:01 AM
Harpye is online now
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Contest
1:10 EPP Hawker Typhoon for FWSC
Phase "A"
Target
As the gathering process is just in progress, we decided to do the
planes definition per entry - every competitant will join with his
own plane for built of the WII aera.
SpecificationRevision 0.1 without gear
Parameter__________Original______________Built____ __________________
Plane Type_________Hawker TyphoonMK1B____Hawker Typhoon MK1b_________
Wingspan___________12.6m_________________1.26m____ __________________
Scale______________1:1___________________1:10_____ __________________
Material___________Aluminium_____________EPP Foam____________________
Motor______________24 zyl Napier Sabre___Dual Sky Outr. 1200KV 200W__
Servo____________________________________3x 9 Gram Modelcraft________
RX_______________________________________Robbe FASST 2.4GHz__________
Accu_____________________________________RockAmp Heli Performance____
As I decided for a 1:10 Hawker Typhoon built for the Foamy Warird
Scratchbuilt Contest, I now try to prepare for "B"
Harpye is online now Find More Posts by Harpye
Old May 03, 2009, 07:20 AM
Harpye's Avatar
Germany
Phase "B" Design, Construction and Drawings
Sources
So I started with gathering some blueprints out of the web:
http://www.airwar.ru/other/draw/typhoon.html
http://www.airwar.ru/other/draw/typhoon-2.html
http://www.airwar.ru/other/draw/hawkertyphoonsol.html
Old May 03, 2009, 07:31 AM
Harpye's Avatar
Germany
CAD Basics And Preparance
For to get a rather good base to setup the construction I imported the
blueprints projections into CAD and scaled them up to a normed size
Old May 03, 2009, 07:39 AM
Harpye's Avatar
Germany
CAD Creating Basic Skeleton
Spacers and rips are now copied using SPLINES ( polynomes of higher order)
and arranged to a first raw skeleton
Old May 03, 2009, 07:46 AM
Harpye's Avatar
Germany
CAD Inter-/ Extrapolation Additional Informations
As the informations content in the blueprints is rather low for a -not structure identical- built I had to interpolate some additional information ...
the "mill" is intersected with the spacers arrangement and so gives a cloud of additional points for stringer allocation.
Old May 03, 2009, 09:59 AM
Harpye's Avatar
Germany
CAD Wings and Raw Mesh
Ok, I meshed the skeleton and lofted a pair of wings for the raw surface model... That is all for today!!
Old May 03, 2009, 10:08 AM
Harpye's Avatar
Germany
CAD First Shaded Rendering
Here is just another perspective shade....
Next will be to get a proposal from this data...
Old May 03, 2009, 12:00 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Subscribed... Interesting project.
Foamenator is offline Find More Posts by Foamenator
Old May 03, 2009, 12:03 PM
Harpye's Avatar
Germany
Illustration - Shaded, Mapped Rendering
I wasn't able to stop progress, yet
Now here a first rendered proposal with a kind of primitive skin!
Old May 03, 2009, 02:54 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I'm betting this will be a sweet flyer.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old May 03, 2009, 02:57 PM
Harpye's Avatar
Germany
Thanks to both of you -that's what I hope for
Hansjoerg
Old May 03, 2009, 03:02 PM
Harpye's Avatar
Germany
CAD - Discretization for Hot Wire Cut
Next step was to separate the spherical curves into straight elements - to be hot wire cut!!
Here is an exploded assembly drawing with the 1st level parts to create ...
Old May 03, 2009, 05:15 PM
tvcasualty is offline
Find More Posts by tvcasualty
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Alright Harpye, your on! I'm already learning, looks like I'm gonna do a Typhoon as well, but mine is gonna be a bubble top version. Should I start a new thread?
tvcasualty is offline Find More Posts by tvcasualty
Old May 04, 2009, 11:33 AM
Harpye's Avatar
Germany
A new thread would be nice!
After all participants have opened a thread for each I will gather them all together by links into a lead thread which will be closed after entry to everyones way to find all threads is the same...
Good luck on yours!!!
Hansjoerg
Old May 04, 2009, 03:37 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Looks great Hans!
kram242 is offline Find More Posts by kram242
Help! Retracts for Hawker Typhoon jhspring Scale Kit/Scratch Built 3 Sep 13, 2007 12:00 PM
Hawker Hunter for Midi fan Jones Boy Electric Ducted Fan Jet Talk 237 Oct 17, 2006 03:58 AM
FS: Stein Model 1/12 Hawker Typhoon JPHen Aircraft - Electric - Airplanes (FS/W) 2 Jan 17, 2005 10:20 PM
Just another Hawker Typhoon Helge Sondresen Scale Kit/Scratch Built 8 Nov 04, 2002 09:37 AM
18 cell Hawker Typhoon flies! Ron Daniels Scale Kit/Scratch Built 5 Jul 03, 2002 12:02 PM
