Old Apr 29, 2009, 02:40 PM
Mach61 is offline
Find More Posts by Mach61
Ottawa, ON. Canada
Joined Oct 2006
Advantage of a Circular Polarized Patch Ant?
I have two omnis (3dbi and 5dbi) and a 14dbi patch. I am using a single receiver so I thought I would try an 8dbi patch.
NGhobbies has three different types - right circular polarized, left circular polarized and vertical/horizontal 8dbi flat patch.
I understand that if I go with the third option, I need to have the tx ant pointing straight up with the patch ant pointed in the general direction of the plane with the coaxial coming out of the bottom for best reception.
If I go with the circular polarized patch, I understand that the orientation of tx ant is irrelevant and orientation of the patch is irrelevant provided it is pointed in the general direction of the plane but I will lose 3dbi relative to the non-circular polarized version. So the main advantage is I can do wild aerobatics with no signal strength loss but the disadvantage is that I will lose range. Is this correct?
Does it make a diff whether I choose right or left circular considering I only have one receiver?
If you were to use only one 8dbi patch and planned on flying in front of it, what would you choose? circular polorized? or linear?
thx
Mach61 is offline Find More Posts by Mach61
Old May 01, 2009, 07:51 PM
JIMOOO is offline
Find More Posts by JIMOOO
Joined Jul 2003
This is the best Thread i have found for circular polarization:
http://www.rcgroups.com/forums/showt...t=polarization
Doesn't matter which circular direction!
Post #26 sums it up nicely!
Recommended antenna lead length is under 12in to prevent signal loss.
Most of the FPV vendors who sell antennas stock them with the 4ft leads
I just ordered a pair (Rt/Lt) with custom 3" lead length for $47ea from: http://www.l-com.com/item.aspx?id=21787
Also picked up this 5 dBi omni with great angle specs but needs a SMA Male /N Female adapator:
http://www.l-com.com/item.aspx?id=22055
http://www.l-com.com/item.aspx?id=5349
Going to try the Oracle w/ vertical omni and circular patch facing up then try two circular patches facing slightly up and angled away
yeah ha
JIMOOO is offline Find More Posts by JIMOOO
Old May 01, 2009, 10:53 PM
Blaze.45 is offline
Find More Posts by Blaze.45
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
Originally Posted by Mach61
1) So the main advantage is I can do wild aerobatics with no signal strength loss but the disadvantage is that I will lose range. Is this correct?
2) Does it make a diff whether I choose right or left circular considering I only have one receiver?
3) If you were to use only one 8dbi patch and planned on flying in front of it, what would you choose? circular polorized? or linear?
thx
1) Yes.
2) No practical difference.
3) If both antennas are nearly identical in advertised specs, shape, and size.
Circular for close to med range where your antenna changes direction quite a lot, aka aerobatics or flying directly above, etc etc.
Linear for med to long(er) range where your antenna is on a gentle path, aka a glider flying long range, etc etc.
This is general info. There are many little "gotchas".
Blaze.45 is offline Find More Posts by Blaze.45
Discussion which way to mount the Patch Ant???? JustinONE FPV Talk 5 Oct 20, 2008 09:20 PM
Video Easy Star flying through null of patch ant PeteSchug Electric Plane Talk 1 Feb 19, 2007 09:01 AM
Questions/Help Hacking 2.4ghz rx For Patch Ant. Randy Due Aerial Photography 20 Jun 03, 2005 06:12 PM
