Old Apr 28, 2009, 07:11 AM
EQMOD is offline
Find More Posts by EQMOD
EQMOD's Avatar
Joined Mar 2008
4CH Sub Micro Coaxial: Converting a 3CH to 4CH
To make a 3CH Coaxial helicopter 4CH, simply add another small upright rotor on the aileron axis;
Obviously, the added rotor needs to be counter-balanced and this was done using the lipo battery. The idea here is to use any 'existing' component as a balancer such that only a minimal weight is added for the aileron channel;
view of the aileron rotor;
and the counter balance lipo;
* Test flight video to follow....
EQMOD is offline Find More Posts by EQMOD
Old Apr 28, 2009, 02:58 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
here she is with the presence of the aileron movements;
4 CH 4 Channel Sub Micro Coaxial with two added rotors for aileron and elevator control - 1 (1 min 47 sec)
Old Apr 29, 2009, 01:15 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
i forgot to mention that the bar and motor on the aileron axis were from a picooz tail.
Old May 01, 2009, 06:24 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
a short video from a different angle emphasizing sideways (roll) movement;
4 CH 4 Channel Sub Micro Coaxial with two added rotors for aileron and elevator control - 3 (1 min 9 sec)
Old May 01, 2009, 10:07 PM
Greg_Vincent is offline
Find More Posts by Greg_Vincent
RTF only for now!!!
Greg_Vincent's Avatar
Jacksonville, FL
Joined Mar 2007
Cool experiment! Did you add the 4th channel to the existing system? Or did you replace the 3-channel electronics with 4-channel?
Greg_Vincent is offline Find More Posts by Greg_Vincent
Old May 02, 2009, 07:23 AM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
electronics was replaced with a walkera 4#3 2.4ghz 4-in-1. This allowed me to accomodate a 4th channel plus a gyro for the yaw channel.
Old May 02, 2009, 10:06 AM
thesteelcube is offline
Find More Posts by thesteelcube
She black, she fly fast.
thesteelcube's Avatar
London
Joined Feb 2009
How about moving both fan booms around to the back with 120degree separation?
You would need to do some mixing to translate your elevator and aileron control into cumulative and differential thrust from those fans, but then I reckon you'd also have better symmetry with the cyclic pitch control. A kind of quasi-tricopter if you will.
Just an idea.
thesteelcube is offline Find More Posts by thesteelcube
Discussion 3CH Sub Micro Coaxial Mania : "Gyro-ed" Flights EQMOD Coaxial Helicopters 1 Mar 29, 2009 09:55 PM
Discussion Sub MICRO Coaxial: Using a Logitech Wireless PC USB as a 2.4Ghz Reciever Module EQMOD Coaxial Helicopters 8 Mar 12, 2009 06:54 PM
Discussion Sub Micro Coaxial "Handsfree" Hover EQMOD Coaxial Helicopters 5 Feb 14, 2009 11:00 AM
Discussion A possible 4 channel head cyclic design for a Sub Sub Micro Coaxial EQMOD Coaxial Helicopters 2 Jan 05, 2009 01:45 PM
New Product Blue Arrow Sub-micro Coaxial, looks like smaller Micron CX CaptainIglo Coaxial Helicopters 28 Oct 22, 2007 11:44 AM
