Old Apr 27, 2009, 12:41 PM
mtdoramike is offline
Find More Posts by mtdoramike
Mt. Dora, Florida
mtdoramike's Avatar
USA, FL, Mt Dora
Joined Dec 2006
Flightmax 3s 25c 2200mah vs Zippy R 3s 20c 2300mah................
For those interested and who have not bought these batteries and are interested in size difference, here are pictures with both batteries side by side. the Zippy R is quite a bit bigger than the Flightmax pack.
mtdoramike is offline Find More Posts by mtdoramike
Old Apr 27, 2009, 12:50 PM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
It looks like the R's have spacers that make them fatter?
Bigster is offline Find More Posts by Bigster
Old Apr 27, 2009, 01:19 PM
Mt. Dora, Florida
mtdoramike's Avatar
USA, FL, Mt Dora
Joined Dec 2006
Yes they do and believe it or not, they claim the Zippy R is heavier than the Flight max pack. But to me, the flightmax seems to be heavier.
Old Apr 27, 2009, 02:58 PM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
Oh! Well that's a good sign. I saw the R's were bigger and heavier and I was beginning to regret my decision to buy some.
Old Apr 28, 2009, 09:07 PM
anatoly is online now
Find More Posts by anatoly
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
FWIW, my FlightMax 2200 25C packs came in around 171g +- 2g, which was just what I needed for balancing my Trex 450. Performance is good so far, but I don't have a lot of cycles on them yet.
anatoly is online now Find More Posts by anatoly
Old Apr 28, 2009, 09:18 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
I got the flightmax2200 25C and 20C versions and I really can't tell that much difference in how they perform on my exi450. Fit great and just sligtly warm after a 5minute flight of light 3D. But I orded more of the 25C and plan on using them for the heli's and the two 20C's for parkflyer airplanes.
HugoCraft is offline Find More Posts by HugoCraft
Old Apr 28, 2009, 11:31 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Mike -- Thanks for starting this thread.. Do you believe it should be moved to the batteries forum. I would like this thread to continue with everyones feedback. I will be testing these out on my 450 and my extreme flight yak pending good weather.
How many cycles of break in are you guys doing ?
Are you doing the basic break in 1/2 the Rated C continuous Rating for about 3 minutes and then recharge at 1C...
2200 mAh Discharge between 8.8A and 15.4A to 3.0 volts per cell
livinma1 is offline Find More Posts by livinma1
Old Apr 29, 2009, 11:02 AM
RoadKingAl is offline
Find More Posts by RoadKingAl
RoadKingAl's Avatar
United States, IL, Chicago
Joined Aug 2008
Not Spacers, but internal venting for the cells.
RoadKingAl is offline Find More Posts by RoadKingAl
Old Apr 29, 2009, 11:14 AM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
internal venting? What is that? Hard to vent when they're wrapped in shrinkwrap.
Old Apr 29, 2009, 11:23 AM
RoadKingAl's Avatar
Joined Aug 2008
Flightmax 3s 2200mah 20C, 25C, 30C Comparison
Battery Prices are about $8.00 difference from the 20C - 30C per pack - Your Choice ?
Z22003S-30
ZIPPY Flightmax 2200mAh 3S1P 30C
Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today!
Spec.
Capacity: 2200mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 30C Constant / 40C Burst
Weight: 194g (including wire, plug & shrink wrap)
Dimensions: 108x36x24mm
Balance Plug: JST-XH
Discharge Plug: T-Connector (Deans Type)
Capacity(mAh) 2200
Config(s) 3
Discharge(c) 30
Max Charge Rate (C) 2
Z22003S-25
ZIPPY Flightmax 2200mAh 3S1P 25C
Spec.
Capacity: 2200mAh
Discharge: 25C Constant / 35C Burst
Weight: 171g (including wire, plug & shrink wrap)
Dimensions: 106x36x25mm
Capacity(mAh) 2200
Config(s) 3
Discharge(c)
25
ZIPPY22003S20C
ZIPPY Flightmax 2200mAh 3S1P 20C
Spec.
Capacity: 2200mAh
Discharge: 20C Constant / 25-30C Burst
Weight: 176g (including wire, plug & shrink wrap)
Dimensions: 100x34x27mm
Old Apr 29, 2009, 11:34 AM
RoadKingAl's Avatar
Joined Aug 2008
I will try to get you an answer again. I asked in a tech forum, I was told each cell is separately vented to carry the heat out. Who knows, maybe these cells get too hot next to each other.
I will try to find the response, but it has been almost a month. No more......
Al
Old Apr 29, 2009, 12:15 PM
Block is offline
Find More Posts by Block
Syracuse, NY (USA)
Joined Dec 2004
2300-R's weigh a full 7 ounces...I weighed mine.
Block is offline Find More Posts by Block
Block is offline
Syracuse, NY (USA)
Joined Dec 2004
PS: It would be great if the first poster tested them on a wattmeter with a demanding load!
Old Apr 29, 2009, 12:37 PM
Mt. Dora, Florida
mtdoramike's Avatar
USA, FL, Mt Dora
Joined Dec 2006
Send me a watt meter and I'll be more than happy to do a side by side test for you.
Old Apr 29, 2009, 12:39 PM
Mt. Dora, Florida
mtdoramike's Avatar
USA, FL, Mt Dora
Joined Dec 2006
Your right, this would have been better to be in the Battery forum, but I figured placing it here would give the guys an idea of size comparason. If they were on the fence about which battery they wanted as far as size wise.
Alert Flightmax 3s 25c 2200mah lipos back at Hobbycity 4/20/09 mtdoramike Hot Online Deals 15 May 03, 2009 09:23 AM
Sold SOLD 4x zippy flightmax 3s 2200 25c SOLD jongam0 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 25, 2009 07:55 PM
Sold Zippy Flightmax 3s-2200mAh 30C rsasaki Aircraft - Electric - Batteries & Chargers (FS/W) 3 Apr 18, 2009 09:43 PM
Sold Tenergy 25C 2200mah 3S lipo *Brand New With Deans* sircrashesallot Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jun 27, 2008 12:41 AM
Sold 2 x Thunder Power 3s 25C 2200mah cwhite Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jun 01, 2008 04:12 PM
