Old Jun 12, 2001, 02:30 PM
crashnburn
crashnburn
Guest
n/a Posts
Herr Engineering Pitts Special
Has anybody out there successfully built and flew this plane?? Any suggestions for a power plant, building tips, etc.
I've tried a Speed 400 geared 3.5:1 but it doesn't have much zip.
Any help would be appreciated.
Old Jun 12, 2001, 03:12 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Built stock with only mod being the motor mount and the landing gear. Powered with Brushless Kontronik Drive 150 with Mini-olympus gear on 9x6 and 12 AAA NiMH cells with fantastic results. Long flights and aerobatic.
I would suspect a 480 geared would make one scoot well with 10 nicads.
Good luck - it is a nice plane to build and fly.....just does not do barb wire fences well
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jun 12, 2001, 03:13 PM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
I have the Pitts, and a buddy of mine out here did one as well. We both flew ours on Graupner 480 geared 3.4.5:1 and ran it on an 8x800AR with an 11x7 APC E-prop. Worked pretty well for us. ROG in about 20 feet and 5-6 minutes of aerobatic flight. Search around in this forum and you should find a lot of threads.
Slope Nut is offline Find More Posts by Slope Nut
Old Jun 28, 2001, 09:53 AM
crashnburn
crashnburn
Guest
n/a Posts
Thanks for your replies Steve and Slope Nut.
I'll try your suggestion, Slope Nut, as it seems fairly easy to duplicate.
Nice lookin' bioe, BTW.
Don
Old Jul 03, 2001, 07:19 AM
jschrader is offline
Find More Posts by jschrader
jschrader's Avatar
Munich area, Germany
Joined Jan 2000
Seems I'll need one too
Would anybody be so kind and post the weight of his (Pitts )
juergen
jschrader is offline Find More Posts by jschrader
Old Jul 03, 2001, 10:04 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Jimmy Best, my flying buddy out here, stated his was 33 ounces with the e-conversion (not much of a conversion for this kit is needed). Mine is around the same weight if not lighter (my battery didnt have to go as far forward and we built ours exactly the same). They fly really well, and look great in the sky when all trimmed out with the starburst scheme.
Greg
Old Jul 03, 2001, 03:36 PM
King Kong is offline
Find More Posts by King Kong
King Kong's Avatar
los alamitos ca
Joined Jun 2001
Where is a cheap place to buy one of these?
King Kong is offline Find More Posts by King Kong
Old Jul 05, 2001, 10:06 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
A note of caution. Make sure your rudder is set exactly neutral for flight (hand launched this time) or your in for a real short flight!
My buddy handlaunched it for me (just to see if it would get away), and the rudder was offset for some reason. It spun in from about 40 feet nose in. Suprisingly little damage though. The cowl took most of the beating.
Greg
Sold NIB HERR Engineering PITTS SPECIAL KIT punkindrublik Aircraft - Electric - Airplanes (FS/W) 3 Jan 09, 2007 12:29 AM
Electric conversion - Herr Engineering Pitts Special SJN Electric Plane Talk 2 Jun 12, 2005 01:09 PM
Herr Engineering Pitts Special crashnburn Sport Planes 9 Aug 16, 2003 12:41 PM
Herr Engineering PITTS SPECIAL KIT 24" Gerald Aircraft - Electric - Airplanes (FS/W) 2 Mar 19, 2003 08:23 PM
Article The Herr Engineering Pitts Special jbest Electric Plane Talk 0 Mar 16, 2001 12:00 AM
